désolé pour ce retard problème de connexion
bref;
dmesg
[ 31.180491] EISA bus registered
[ 31.180496] ACPI: bus type pci registered
[ 31.180716] PCI: Using configuration type 1
[ 31.180718] Setting up standard PCI resources
[ 31.182889] ACPI: EC: Look up EC in DSDT
[ 31.186544] ACPI: BIOS OSI(Linux) query ignored via DMI
[ 31.186547] ACPI: If “acpi_osi=Linux” works better, please notify linux-acpi@vger.kernel.org
[ 31.188629] ACPI: Interpreter enabled
[ 31.188632] ACPI: (supports S0 S3 S4 S5)
[ 31.188650] ACPI: Using IOAPIC for interrupt routing
[ 31.189891] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 31.242940] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 31.242943] ACPI: EC: driver started in interrupt mode
[ 31.243005] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 31.245263] PCI quirk: region 0400-047f claimed by ICH6 ACPI/GPIO/TCO
[ 31.245270] PCI quirk: region 0500-053f claimed by ICH6 GPIO
[ 31.248223] PCI: Transparent bridge - 0000:00:1e.0
[ 31.248347] ACPI: PCI Interrupt Routing Table [_SB.PCI0.PRT]
[ 31.248711] ACPI: PCI Interrupt Routing Table [_SB.PCI0.P32_.PRT]
[ 31.248885] ACPI: PCI Interrupt Routing Table [_SB.PCI0.EXP2.PRT]
[ 31.249056] ACPI: PCI Interrupt Routing Table [_SB.PCI0.EXP3.PRT]
[ 31.249225] ACPI: PCI Interrupt Routing Table [_SB.PCI0.EXP4.PRT]
[ 31.249408] ACPI: PCI Interrupt Routing Table [_SB.PCI0.PEGP._PRT]
[ 31.258324] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[ 31.258483] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12)
[ 31.258639] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
[ 31.258794] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
[ 31.258949] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 31.259105] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 *10 11 12)
[ 31.259259] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 *11 12)
[ 31.259418] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 *11 12)
[ 31.259617] Linux Plug and Play Support v0.97 © Adam Belay
[ 31.259649] pnp: PnP ACPI init
[ 31.259657] ACPI: bus type pnp registered
[ 31.283734] pnp: PnP ACPI: found 10 devices
[ 31.283737] ACPI: ACPI bus type pnp unregistered
[ 31.283740] PnPBIOS: Disabled by ACPI PNP
[ 31.283965] PCI: Using ACPI for IRQ routing
[ 31.283968] PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
[ 31.303393] NET: Registered protocol family 8
[ 31.303395] NET: Registered protocol family 20
[ 31.303435] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 31.303440] hpet0: 3 64-bit timers, 14318180 Hz
[ 31.304477] AppArmor: AppArmor Filesystem Enabled
[ 31.307258] Time: tsc clocksource has been installed.
[ 31.307276] Switched to high resolution mode on CPU 0
[ 31.307381] Switched to high resolution mode on CPU 1
[ 31.320245] system 00:01: ioport range 0x164e-0x164f has been reserved
[ 31.320250] system 00:01: ioport range 0x600-0x60f has been reserved
[ 31.320253] system 00:01: ioport range 0x610-0x610 has been reserved
[ 31.320256] system 00:01: ioport range 0x800-0x80f has been reserved
[ 31.320259] system 00:01: ioport range 0x810-0x817 has been reserved
[ 31.320261] system 00:01: ioport range 0x400-0x47f has been reserved
[ 31.320264] system 00:01: ioport range 0x500-0x53f has been reserved
[ 31.320268] system 00:01: iomem range 0xe0000000-0xefffffff could not be reserved
[ 31.320271] system 00:01: iomem range 0xfed1c000-0xfed1ffff could not be reserved
[ 31.320274] system 00:01: iomem range 0xfed14000-0xfed17fff could not be reserved
[ 31.320277] system 00:01: iomem range 0xfed18000-0xfed18fff could not be reserved
[ 31.320281] system 00:01: iomem range 0xfed19000-0xfed19fff could not be reserved
[ 31.320284] system 00:01: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 31.320287] system 00:01: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 31.320290] system 00:01: iomem range 0x32000000-0x320000ff could not be reserved
[ 31.350765] PCI: Failed to allocate mem resource #6:20000@90000000 for 0000:01:00.0
[ 31.350768] PCI: Bridge: 0000:00:01.0
[ 31.350771] IO window: 5000-5fff
[ 31.350775] MEM window: 90000000-92ffffff
[ 31.350779] PREFETCH window: 80000000-8fffffff
[ 31.350783] PCI: Bridge: 0000:00:1c.0
[ 31.350788] IO window: 4000-4fff
[ 31.350801] MEM window: 9a300000-9b2fffff
[ 31.350810] PREFETCH window: 93000000-93ffffff
[ 31.350823] PCI: Bridge: 0000:00:1c.1
[ 31.350828] IO window: 3000-3fff
[ 31.350838] MEM window: 99300000-9a2fffff
[ 31.350848] PREFETCH window: 94000000-94ffffff
[ 31.350861] PCI: Bridge: 0000:00:1c.2
[ 31.350866] IO window: 2000-2fff
[ 31.350879] MEM window: 98200000-992fffff
[ 31.350888] PREFETCH window: 95000000-95ffffff
[ 31.350901] PCI: Bridge: 0000:00:1c.3
[ 31.350906] IO window: 1000-1fff
[ 31.350919] MEM window: 97100000-981fffff
[ 31.350929] PREFETCH window: 96000000-96ffffff
[ 31.350942] PCI: Bridge: 0000:00:1e.0
[ 31.350944] IO window: disabled.
[ 31.350954] MEM window: 97000000-970fffff
[ 31.350963] PREFETCH window: disabled.
[ 31.350988] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 31.350994] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 31.351048] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 31.351059] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 31.351116] ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 17 (level, low) -> IRQ 17
[ 31.351125] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 31.351183] ACPI: PCI Interrupt 0000:00:1c.2[C] -> GSI 18 (level, low) -> IRQ 18
[ 31.351191] PCI: Setting latency timer of device 0000:00:1c.2 to 64
[ 31.351249] ACPI: PCI Interrupt 0000:00:1c.3[D] -> GSI 19 (level, low) -> IRQ 19
[ 31.351258] PCI: Setting latency timer of device 0000:00:1c.3 to 64
[ 31.351291] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 31.351305] NET: Registered protocol family 2
[ 31.388230] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 31.388470] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 31.388930] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 31.389150] TCP: Hash tables configured (established 131072 bind 65536)
[ 31.389153] TCP reno registered
[ 31.400298] checking if image is initramfs… it is
[ 32.184501] Freeing initrd memory: 7687k freed
[ 32.185278] audit: initializing netlink socket (disabled)
[ 32.185291] audit(1218838098.648:1): initialized
[ 32.185502] highmem bounce pool size: 64 pages
[ 32.187617] VFS: Disk quotas dquot_6.5.1
[ 32.187697] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 32.187844] io scheduler noop registered
[ 32.187846] io scheduler anticipatory registered
[ 32.187848] io scheduler deadline registered
[ 32.187860] io scheduler cfq registered (default)
[ 32.188267] Boot video device is 0000:01:00.0
[ 32.188389] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 32.188433] assign_interrupt_mode Found MSI capability
[ 32.188469] Allocate Port Service[0000:00:01.0:pcie00]
[ 32.188504] Allocate Port Service[0000:00:01.0:pcie02]
[ 32.188602] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 32.188749] assign_interrupt_mode Found MSI capability
[ 32.188865] Allocate Port Service[0000:00:1c.0:pcie00]
[ 32.188898] Allocate Port Service[0000:00:1c.0:pcie02]
[ 32.189105] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 32.189252] assign_interrupt_mode Found MSI capability
[ 32.189368] Allocate Port Service[0000:00:1c.1:pcie00]
[ 32.189400] Allocate Port Service[0000:00:1c.1:pcie02]
[ 32.189614] PCI: Setting latency timer of device 0000:00:1c.2 to 64
[ 32.189762] assign_interrupt_mode Found MSI capability
[ 32.189877] Allocate Port Service[0000:00:1c.2:pcie00]
[ 32.189910] Allocate Port Service[0000:00:1c.2:pcie02]
[ 32.190114] PCI: Setting latency timer of device 0000:00:1c.3 to 64
[ 32.190263] assign_interrupt_mode Found MSI capability
[ 32.190376] Allocate Port Service[0000:00:1c.3:pcie00]
[ 32.190408] Allocate Port Service[0000:00:1c.3:pcie02]
[ 32.190774] isapnp: Scanning for PnP cards…
[ 32.548509] isapnp: No Plug & Play device found
[ 32.575121] Real Time Clock Driver v1.12ac
[ 32.575338] hpet_resources: 0xfed00000 is busy
[ 32.575401] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 32.576705] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 32.576773] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 32.576879] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
[ 32.609885] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 32.609890] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 32.630561] mice: PS/2 mouse device common for all mice
[ 32.630673] EISA: Probing bus 0 at eisa.0
[ 32.630682] Cannot allocate resource for EISA slot 1
[ 32.630685] Cannot allocate resource for EISA slot 2
[ 32.630687] Cannot allocate resource for EISA slot 3
[ 32.630689] Cannot allocate resource for EISA slot 4
[ 32.630691] Cannot allocate resource for EISA slot 5
[ 32.630693] Cannot allocate resource for EISA slot 6
[ 32.630709] EISA: Detected 0 cards.
[ 32.630712] cpuidle: using governor ladder
[ 32.630714] cpuidle: using governor menu
[ 32.630799] NET: Registered protocol family 1
[ 32.630827] Using IPI No-Shortcut mode
[ 32.630856] registered taskstats version 1
[ 32.630990] Magic number: 4:538:148
[ 32.631012] hash matches device ttyp2
[ 32.631053] hash matches device device:19
[ 32.631060] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 32.631063] EDD information not available.
[ 32.631259] Freeing unused kernel memory: 364k freed
[ 32.650963] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 33.875235] fuse init (API version 7.9)
[ 33.900622] ACPI: SSDT 7FE7AE10, 01A8 (r1 PmRef Cpu0Ist 3000 INTL 20051117)
[ 33.900918] ACPI: SSDT 7FE79610, 05D7 (r1 PmRef Cpu0Cst 3001 INTL 20051117)
[ 33.902894] Monitor-Mwait will be used to enter C-1 state
[ 33.902897] Monitor-Mwait will be used to enter C-2 state
[ 33.902900] Monitor-Mwait will be used to enter C-3 state
[ 33.903025] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 33.903030] ACPI: Processor [CPU0] (supports 8 throttling states)
[ 33.903288] ACPI: SSDT 7FE7CD10, 00C4 (r1 PmRef Cpu1Ist 3000 INTL 20051117)
[ 33.903562] ACPI: SSDT 7FE7CC10, 0083 (r1 PmRef Cpu1Cst 3000 INTL 20051117)
[ 33.904616] ACPI: CPU1 (power states: C1[C1] C2[C2] C3[C3])
[ 33.904622] ACPI: Processor [CPU1] (supports 8 throttling states)
[ 33.907977] ACPI: Thermal Zone [TZ01] (40 C)
[ 34.060279] usbcore: registered new interface driver usbfs
[ 34.060306] usbcore: registered new interface driver hub
[ 34.069712] usbcore: registered new device driver usb
[ 34.074377] USB Universal Host Controller Interface driver v3.0
[ 34.074431] ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 34.074448] PCI: Setting latency timer of device 0000:00:1a.0 to 64
[ 34.074455] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 34.074676] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 34.074723] uhci_hcd 0000:00:1a.0: irq 16, io base 0x000060a0
[ 34.074874] usb usb1: configuration #1 chosen from 1 choice
[ 34.074900] hub 1-0:1.0: USB hub found
[ 34.074905] hub 1-0:1.0: 2 ports detected
[ 34.181755] ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 20
[ 34.181774] PCI: Setting latency timer of device 0000:00:1a.1 to 64
[ 34.181781] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 34.181809] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 34.181855] uhci_hcd 0000:00:1a.1: irq 20, io base 0x00006080
[ 34.181992] usb usb2: configuration #1 chosen from 1 choice
[ 34.182020] hub 2-0:1.0: USB hub found
[ 34.182026] hub 2-0:1.0: 2 ports detected
[ 34.285677] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 21
[ 34.285694] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 34.285701] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 34.285726] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 34.285772] uhci_hcd 0000:00:1d.0: irq 21, io base 0x00006060
[ 34.285898] usb usb3: configuration #1 chosen from 1 choice
[ 34.285923] hub 3-0:1.0: USB hub found
[ 34.285929] hub 3-0:1.0: 2 ports detected
[ 34.389653] ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
[ 34.389671] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[ 34.389678] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 34.389703] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 4
[ 34.389750] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00006040
[ 34.389874] usb usb4: configuration #1 chosen from 1 choice
[ 34.389901] hub 4-0:1.0: USB hub found
[ 34.389907] hub 4-0:1.0: 2 ports detected
[ 34.448069] SCSI subsystem initialized
[ 34.493550] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
[ 34.493569] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[ 34.493576] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 34.493602] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 5
[ 34.493653] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00006020
[ 34.493785] usb usb5: configuration #1 chosen from 1 choice
[ 34.493812] hub 5-0:1.0: USB hub found
[ 34.493817] hub 5-0:1.0: 2 ports detected
[ 34.528357] libata version 3.00 loaded.
[ 34.597652] ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
[ 34.597666] PCI: Setting latency timer of device 0000:00:1a.7 to 64
[ 34.597673] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 34.597705] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 6
[ 34.601642] ehci_hcd 0000:00:1a.7: debug port 1
[ 34.601654] PCI: cache line size of 32 is not supported by device 0000:00:1a.7
[ 34.601661] ehci_hcd 0000:00:1a.7: irq 18, io mem 0x9b304400
[ 34.629403] usb 3-1: new low speed USB device using uhci_hcd and address 2
[ 34.641385] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 34.641510] usb usb6: configuration #1 chosen from 1 choice
[ 34.641537] hub 6-0:1.0: USB hub found
[ 34.641544] hub 6-0:1.0: 4 ports detected
[ 34.745452] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 21
[ 34.745472] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 34.745478] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 34.745504] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 7
[ 34.749425] ehci_hcd 0000:00:1d.7: debug port 1
[ 34.749439] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 34.749446] ehci_hcd 0000:00:1d.7: irq 21, io mem 0x9b304000
[ 34.765316] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 34.765422] usb usb7: configuration #1 chosen from 1 choice
[ 34.765448] hub 7-0:1.0: USB hub found
[ 34.765454] hub 7-0:1.0: 6 ports detected
[ 34.869405] ACPI: PCI Interrupt 0000:07:00.0[A] -> GSI 20 (level, low) -> IRQ 22
[ 34.869420] PCI: Setting latency timer of device 0000:07:00.0 to 64
[ 34.922913] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[22] MMIO=[97000000-970007ff] Max Packet=[2048] IR/IT contexts=[4/4]
[ 34.928136] tg3.c:v3.86 (November 9, 2007)
[ 34.928225] ACPI: PCI Interrupt 0000:05:00.0[A] -> GSI 18 (level, low) -> IRQ 18
[ 34.928243] PCI: Setting latency timer of device 0000:05:00.0 to 64
[ 34.974209] eth0: Tigon3 [partno(BCM95787m) rev b002 PHY(5787)] (PCI Express) 10/100/1000Base-T Ethernet 00:1b:38:5f:49:72
[ 34.974217] eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] WireSpeed[1] TSOcap[1]
[ 34.974220] eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 34.986074] ata_piix 0000:00:1f.1: version 2.12
[ 34.986098] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 18
[ 34.986147] PCI: Setting latency timer of device 0000:00:1f.1 to 64
[ 34.987203] scsi0 : ata_piix
[ 34.987613] scsi1 : ata_piix
[ 34.988244] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x60e0 irq 14
[ 34.988247] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x60e8 irq 15
[ 35.103068] APIC error on CPU0: 00(40)
[ 35.177094] usb 3-1: device not accepting address 2, error -71
[ 35.305524] ata1.00: ATAPI: MATSHITADVD-RAM UJ-850S, 1.61, max UDMA/33
[ 35.477372] ata1.00: configured for UDMA/33
[ 35.532890] Clocksource tsc unstable (delta = -9065712980 ns)
[ 35.536883] Time: hpet clocksource has been installed.
[ 35.559337] scsi 0:0:0:0: CD-ROM MATSHITA DVD-RAM UJ-850S 1.61 PQ: 0 ANSI: 5
[ 35.559448] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 35.572339] ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
[ 35.572398] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 35.572529] scsi2 : ata_piix
[ 35.572716] scsi3 : ata_piix
[ 35.584955] usb 7-3: new high speed USB device using ehci_hcd and address 3
[ 35.718360] usb 7-3: configuration #1 chosen from 1 choice
[ 35.865293] ieee1394: Host added: ID:BUS[0-00:1023] GUID[c7416ee000023f79]
[ 35.879877] usb 7-4: new high speed USB device using ehci_hcd and address 4
[ 35.896390] ata3: SATA max UDMA/133 cmd 0x60f8 ctl 0x6114 bmdma 0x60d0 irq 19
[ 35.896394] ata4: SATA max UDMA/133 cmd 0x60f0 ctl 0x6110 bmdma 0x60d8 irq 19
[ 36.018072] usb 7-4: configuration #1 chosen from 1 choice
[ 36.057260] ata3.00: ATA-7: Hitachi HTS541616J9SA00, SB4OC70P, max UDMA/100
[ 36.057268] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (not used)
[ 36.074265] ata3.00: configured for UDMA/100
[ 36.164554] scsi 2:0:0:0: Direct-Access ATA Hitachi HTS54161 SB4O PQ: 0 ANSI: 5
[ 36.177603] Driver ‘sr’ needs updating - please use bus_type methods
[ 36.179066] usb 3-1: new low speed USB device using uhci_hcd and address 4
[ 36.179115] sr0: scsi3-mmc drive: 62x/62x writer dvd-ram cd/rw xa/form2 cdda tray
[ 36.179119] Uniform CD-ROM driver Revision: 3.20
[ 36.179171] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 36.184523] Driver ‘sd’ needs updating - please use bus_type methods
[ 36.184598] sd 2:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 36.184611] sd 2:0:0:0: [sda] Write Protect is off
[ 36.184614] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 36.184632] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 36.184683] sd 2:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 36.184694] sd 2:0:0:0: [sda] Write Protect is off
[ 36.184696] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 36.184714] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 36.184718] sda:<5>sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 36.186348] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 36.347553] usb 3-1: configuration #1 chosen from 1 choice
[ 36.365829] usbcore: registered new interface driver hiddev
[ 36.380747] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1:1.0/input/input2
[ 36.403035] input,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-0000:00:1d.0-1
[ 36.403055] usbcore: registered new interface driver usbhid
[ 36.403060] /build/buildd/linux-2.6.24/drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
[ 36.608327] sda1 sda2 < sda5 >
[ 36.631509] sd 2:0:0:0: [sda] Attached SCSI disk
[ 36.824754] Attempting manual resume
[ 36.824758] swsusp: Resume From Partition 8:5
[ 36.824759] PM: Checking swsusp image.
[ 36.824995] PM: Resume from disk failed.
[ 36.878076] kjournald starting. Commit interval 5 seconds
[ 36.878124] EXT3-fs: mounted filesystem with ordered data mode.
[ 44.211618] APIC error on CPU0: 40(40)
[ 45.116161] iTCO_vendor_support: vendor-support=0
[ 45.184259] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 45.244906] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 45.280158] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 45.312052] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.02 (26-Jul-2007)
[ 45.312145] iTCO_wdt: Found a ICH8M TCO device (Version=2, TCOBASE=0x0460)
[ 45.312190] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 45.398581] Linux agpgart interface v0.102
[ 45.553435] ACPI: WMI-Acer: Mapper loaded
[ 45.584456] input: Power Button (FF) as /devices/virtual/input/input4
[ 45.635810] ACPI: Power Button (FF) [PWRF]
[ 45.635889] input: Power Button (CM) as /devices/virtual/input/input5
[ 45.667767] ACPI: Power Button (CM) [PWRB]
[ 45.667830] input: Lid Switch as /devices/virtual/input/input6
[ 45.683866] ACPI: Lid Switch [LID0]
[ 45.683935] input: Sleep Button (CM) as /devices/virtual/input/input7
[ 45.747728] ACPI: Sleep Button (CM) [SLPB]
[ 45.799209] acer_acpi: Acer Laptop ACPI Extras version 0.11.1
[ 45.799216] acer_acpi: Detected Acer WMID interface
[ 45.980054] input: PS/2 Mouse as /devices/virtual/input/input8
[ 46.068350] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input9
[ 46.133315] sdhci: Secure Digital Host Controller Interface driver
[ 46.133319] sdhci: Copyright© Pierre Ossman
[ 46.133361] sdhci: SDHCI controller found at 0000:07:00.1 [1180:0822] (rev 22)
[ 46.133403] ACPI: PCI Interrupt 0000:07:00.1[B] -> GSI 22 (level, low) -> IRQ 23
[ 46.133426] sdhci:slot0: Will use DMA mode even though HW doesn’t fully claim to support it.
[ 46.133437] PCI: Setting latency timer of device 0000:07:00.1 to 64
[ 46.133507] mmc0: SDHCI at 0x97000a00 irq 23 DMA
[ 46.181990] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:34/LNXVIDEO:00/input/input10
[ 46.202479] ACPI: AC Adapter [AC] (on-line)
[ 46.243451] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 46.353478] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input11
[ 46.376350] iwl3945: Intel® PRO/Wireless 3945ABG/BG Network Connection driver for Linux, 1.2.0
[ 46.376353] iwl3945: Copyright© 2003-2007 Intel Corporation
[ 46.376501] ACPI: PCI Interrupt 0000:06:00.0[A] -> GSI 19 (level, low) -> IRQ 19
[ 46.376517] PCI: Setting latency timer of device 0000:06:00.0 to 64
[ 46.376542] iwl3945: Detected Intel PRO/Wireless 3945ABG Network Connection
[ 46.387336] ACPI: Video Device [OVGA] (multi-head: yes rom: no post: no)
[ 46.720962] APIC error on CPU0: 40(40)
[ 46.763201] ACPI: Battery Slot [BAT0] (battery present)
[ 47.077904] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 23
[ 47.077932] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 47.080495] Linux video capture interface: v2.00
[ 47.109695] hda_codec: Unknown model for ALC268, trying auto-probe from BIOS…
[ 47.159950] em28xx v4l2 driver version 0.0.1 loaded
[ 47.159989] em28xx new video device (eb1a:2820): interface 0, class 255
[ 47.159996] em28xx #0: Alternate settings: 8
[ 47.159998] em28xx #0: Alternate setting 0, max size= 0
[ 47.160000] em28xx #0: Alternate setting 1, max size= 1024
[ 47.160002] em28xx #0: Alternate setting 2, max size= 1448
[ 47.160005] em28xx #0: Alternate setting 3, max size= 2048
[ 47.160007] em28xx #0: Alternate setting 4, max size= 2304
[ 47.160009] em28xx #0: Alternate setting 5, max size= 2580
[ 47.160011] em28xx #0: Alternate setting 6, max size= 2892
[ 47.160013] em28xx #0: Alternate setting 7, max size= 3072
[ 47.343358] APIC error on CPU0: 40(40)
[ 47.907763] saa7115 0-0025: saa7113 found (1f7113d0e100000) @ 0x4a (em28xx #0)
[ 48.133978] iwl3945: Tunable channels: 13 802.11bg, 23 802.11a channels
[ 48.135475] wmaster0: Selected rate control algorithm ‘iwl-3945-rs’
[ 48.993824] registered VBI
[ 49.005746] em28xx #0: V4L2 device registered as /dev/video0 and /dev/vbi0
[ 49.005751] em28xx #0: Found MSI VOX USB 2.0
[ 49.005786] usbcore: registered new interface driver em28xx
[ 49.005823] uvcvideo: Found UVC 1.00 device Acer CrystalEye webcam (064e:a101)
[ 49.007551] usbcore: registered new interface driver uvcvideo
[ 49.007555] USB Video Class driver (v0.1.0)
[ 49.206926] lp: driver loaded but no devices found
[ 49.343102] Adding 6072528k swap on /dev/sda5. Priority:-1 extents:1 across:6072528k
[ 49.745977] EXT3 FS on sda1, internal journal
[ 50.509552] ip_tables: © 2000-2006 Netfilter Core Team
[ 51.028560] No dock devices found.
[ 52.054328] apm: BIOS not found.
[ 52.185145] ppdev: user-space parallel port driver
[ 52.347437] audit(1218838130.027:2): type=1503 operation=“inode_permission” requested_mask=“a::” denied_mask=“a::” name="/dev/tty" pid=5287 profile="/usr/sbin/cupsd" namespace=“default”
[ 53.331222] APIC error on CPU0: 40(40)
[ 54.329026] Bluetooth: Core ver 2.11
[ 54.329510] NET: Registered protocol family 31
[ 54.329514] Bluetooth: HCI device and connection manager initialized
[ 54.329564] Bluetooth: HCI socket layer initialized
[ 54.389820] Bluetooth: L2CAP ver 2.9
[ 54.389826] Bluetooth: L2CAP socket layer initialized
[ 54.455783] Bluetooth: RFCOMM socket layer initialized
[ 54.455799] Bluetooth: RFCOMM TTY layer initialized
[ 54.455802] Bluetooth: RFCOMM ver 1.8
[ 54.763310] NET: Registered protocol family 17
[ 59.981260] APIC error on CPU0: 40(40)
[ 60.200165] APIC error on CPU0: 40(40)
[ 65.425467] NET: Registered protocol family 10
[ 65.426193] lo: Disabled Privacy Extensions
[ 65.427260] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 65.428945] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 71.040441] CPU0 attaching NULL sched-domain.
[ 71.040447] CPU1 attaching NULL sched-domain.
[ 71.072341] CPU0 attaching sched-domain:
[ 71.072347] domain 0: span 03
[ 71.072350] groups: 01 02
[ 71.072354] CPU1 attaching sched-domain:
[ 71.072356] domain 0: span 03
[ 71.072358] groups: 02 01
[ 72.052502] APIC error on CPU0: 40(40)
[ 72.972317] APIC error on CPU0: 40(40)
[ 74.877943] UDF-fs: No VRS found
[ 74.883177] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 74.884041] ISOFS: changing to secondary root
lsmod
Module Size Used by
isofs 36388 1
udf 88612 0
ipv6 267780 10
af_packet 23812 2
rfcomm 41744 2
l2cap 25728 13 rfcomm
bluetooth 61156 4 rfcomm,l2cap
ppdev 10372 0
acpi_cpufreq 10796 1
cpufreq_ondemand 9740 1
cpufreq_stats 7104 0
cpufreq_powersave 2688 0
cpufreq_conservative 8712 0
freq_table 5536 3 acpi_cpufreq,cpufreq_ondemand,cpufreq_stats
cpufreq_userspace 5284 0
container 5632 0
dock 11280 0
sbs 15112 0
sbshc 7680 1 sbs
iptable_filter 3840 0
ip_tables 14820 1 iptable_filter
x_tables 16132 1 ip_tables
sbp2 24072 0
parport_pc 36260 0
lp 12324 0
parport 37832 3 ppdev,parport_pc,lp
arc4 2944 2
ecb 4480 2
blkcipher 8324 1 ecb
joydev 13120 0
tuner 42912 0
tea5767 6788 1 tuner
tda8290 12420 1 tuner
tuner_simple 10248 1 tuner
mt20xx 13192 1 tuner
tea5761 6020 1 tuner
saa7115 16656 0
uvcvideo 58116 0
em28xx 48936 0
compat_ioctl32 2304 2 uvcvideo,em28xx
ir_common 36100 1 em28xx
videodev 29440 2 uvcvideo,em28xx
snd_hda_intel 344600 3
v4l1_compat 15492 3 uvcvideo,em28xx,videodev
v4l2_common 18304 5 tuner,saa7115,uvcvideo,em28xx,videodev
tveeprom 16656 1 em28xx
snd_pcm_oss 42144 0
snd_mixer_oss 17920 1 snd_pcm_oss
snd_pcm 78596 2 snd_hda_intel,snd_pcm_oss
snd_page_alloc 11400 2 snd_hda_intel,snd_pcm
snd_hwdep 10500 1 snd_hda_intel
snd_seq_dummy 4868 0
snd_seq_oss 35584 0
snd_seq_midi 9376 0
battery 14212 0
snd_rawmidi 25760 1 snd_seq_midi
iwl3945 89844 0
iwlwifi_mac80211 219108 1 iwl3945
snd_seq_midi_event 8320 2 snd_seq_oss,snd_seq_midi
ac 6916 0
snd_seq 54224 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
sdhci 19076 0
cfg80211 15112 1 iwlwifi_mac80211
video 19856 0
output 4736 1 video
i2c_core 24832 9 tuner,tea5767,tda8290,tuner_simple,mt20xx,tea5761,saa7115,em28xx,tveeprom
snd_timer 24836 2 snd_pcm,snd_seq
snd_seq_device 9612 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
serio_raw 7940 0
acer_acpi 18112 0
led_class 6020 1 acer_acpi
mmc_core 51460 1 sdhci
intel_agp 25492 0
button 9232 0
wmi_acer 9644 1 acer_acpi
snd 56996 17 snd_hda_intel,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_hwdep,snd_seq_dummy,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
agpgart 34760 1 intel_agp
psmouse 40336 0
evdev 13056 8
iTCO_wdt 13092 0
pcspkr 4224 0
shpchp 34452 0
pci_hotplug 30880 1 shpchp
soundcore 8800 1 snd
iTCO_vendor_support 4868 1 iTCO_wdt
ext3 136712 1
jbd 48404 1 ext3
mbcache 9600 1 ext3
usbhid 31872 0
hid 38784 1 usbhid
sg 36880 0
sd_mod 30720 3
sr_mod 17956 1
cdrom 37408 1 sr_mod
pata_acpi 8320 0
ata_piix 19588 3
ata_generic 8324 0
ohci1394 33584 0
libata 159344 3 pata_acpi,ata_piix,ata_generic
ieee1394 93752 2 sbp2,ohci1394
scsi_mod 151436 5 sbp2,sg,sd_mod,sr_mod,libata
tg3 116228 0
ehci_hcd 37900 0
uhci_hcd 27024 0
usbcore 146028 6 uvcvideo,em28xx,usbhid,ehci_hcd,uhci_hcd
thermal 16796 0
processor 36872 4 acpi_cpufreq,thermal
fan 5636 0
fbcon 42912 0
tileblit 3456 1 fbcon
font 9472 1 fbcon
bitblit 6784 1 fbcon
softcursor 3072 1 bitblit
fuse 50580 3
ls /lib/modules/‘uname -r’/kernel/drivers/media/video*
adv7170.ko hexium_orion.ko sn9c102 v4l2-common.ko
adv7175.ko ir-kbd-i2c.ko stradis.ko v4l2-int-device.ko
bt819.ko ivtv stv680.ko videobuf-core.ko
bt856.ko ks0127.ko tcm825x.ko videobuf-dma-sg.ko
bt866.ko meye.ko tda7432.ko videobuf-dvb.ko
bt8xx msp3400.ko tda8290.ko videobuf-vmalloc.ko
btcx-risc.ko mt20xx.ko tda9840.ko videocodec.ko
bw-qcam.ko ov7670.ko tda9875.ko videodev.ko
cafe_ccic.ko ovcamchip tea5761.ko vivi.ko
compat_ioctl32.ko pms.ko tea5767.ko vp27smpx.ko
cpia2 pvrusb2 tea6415c.ko vpx3220.ko
cpia.ko pwc tea6420.ko w9966.ko
cpia_pp.ko saa5246a.ko tlv320aic23b.ko w9968cf.ko
cpia_usb.ko saa5249.ko tuner-3036.ko wm8739.ko
c-qcam.ko saa6588.ko tuner.ko wm8775.ko
cs53l32a.ko saa7110.ko tuner-simple.ko zc0301
cx2341x.ko saa7111.ko tvaudio.ko zr36016.ko
cx23885 saa7114.ko tveeprom.ko zr36050.ko
cx25840 saa7115.ko tvp5150.ko zr36060.ko
cx88 saa7127.ko upd64031a.ko zr36067.ko
dabusb.ko saa7134 upd64083.ko zr364xx.ko
em28xx saa7185.ko usbvideo
et61x251 saa7191.ko usbvision
hexium_gemini.ko se401.ko v4l1-compat.ko
ls -lh /dev/video
crw-rw----+ 1 root video 81, 0 2008-08-15 23:08 /dev/video0
crw-rw----+ 1 root video 81, 1 2008-08-15 23:08 /dev/video1
voila en gros ce que sa donne
merci
