(je viens de lire pas mal de pages)
[quote=“rodmov”]Combien de techniciens de chez Microsoft faut-il pour changer une ampoule électrique?
et bien trois.
Deux pour tenir l’échelle et un pour visser l’ampoule dans le robinet.
En fait il en faut aucun. Il suffit que Bill Gates déclare l’obscurité comme standard !
Avec celle-ci des fois que vous connaissiez pas :
http://www.yann-ollivier.org/Humour/voitures_MS
Dans le même genre que "sudo make me a sandwich"
http://www.siteduzero.com/uploads/fr/files/5001_6000/5313.gif
Pour fran.b !! sujet à soumettre pour l’aggreg (reçu ce matin) :
A Customer calls a UNIX consultant with a question.
Customer: What is the command that will tell me the revision code of a program?
Consultant: Yes, that’s correct.
Customer: No, what is it ?
Consultant: Yes.
Customer: So, which is the one ?
Consultant: No. which is used to find the program.
Customer: Stop this. Who are you ?
Consultant: Use who am i not who r yoo. You can also finger yoo to get information about yoo.
Customer: All I want to know is what finds the revision code ?
Consultant: Use what.
Customer: That’s what I am trying to find out. Isn’t that true ?
Consultant: No. true gives you 0.
Customer: Which one ?
Consultant: true gives you 0. which programname.
Customer: Let’s get back to my problem. What program? How do I find it?
Consultant: Type find / -name it -print to find it. Type what program to get the revision code.
Customer: I want to find the revision code.
Consultant: You can’t find revisioncode, you must use what program.
Customer: Which command will do what I need?
Consultant: No. which command will find command.
Customer: I think I understand. Let me write that.
Consultant: You can write that only if that is a user on your system.
Customer: Write what?
Consultant: No. write that. what program.
Customer: Cut that out!
Consultant: Yes. Those are valid files for cut. Don’t forget the options.
Customer: Do you always do this ?
Consultant: du will give you disk usage.
Customer: HELP!
Consultant: help is only used for SCCS.
Customer: You make me angry.
Consultant: No, I don’t make me angry but I did make programname when I was upset once.
Customer: I don’t want to make trouble, so no more.
Consultant: No more? which will help you find more. Every system has more.
Customer: Nice help! I’m confused more now!
Consultant: Understand that since help is such a small program, it is better not to nice help. And more now is not allowed but at now is. Unless of course now is a file name.
Customer: This is almost as confusing as my PC.
Consultant: I didn’t know you needed help with pc. Let me get you to the Pascal compiler team.
Pas mal, il m’a fallut voir “Use What” pour comprendre, et relire depuis le début.
J’ai l’impression que le consultant a suivi les cours à l’école du parti. Ça ne serait pas Juni le consultant ?
Un type arrive chez son médecin pour un résultat d’examens:
Ah monsieur michu content de vous voir!
Bon, alors vos examens, il y a du bon et du mauvais.
Le mauvais: vous avez un cancer.
Le bon: vous avez un alzheimer.
:smt003
Un laptop pour Trader:
clubic.com/actualite-165134- … 3-000.html
bonjour,
Attention Dédé va te la couper nette…
ca-va-couper.fr/index.php/ca-va-couper/
« Un élément de l’ENIAC compte 18000 tubes à vide et pèse 30 tonnes, mais les
ordinateurs du futur pourraient ne plus contenir que 1000 tubes, et peser une
tonne et demi. » (Popular Mechanics, Mars 1949)
Un policier voit un homme marchant avec un pingouin.
- Vous devriez l’amener au zoo.
- Vous avez raison.
Mais quelques jours plus tard, même rencontre… - Vous ne l’avez pas emmené au zoo?
- Mais si! Et cela lui a plu. Alors maintenant je l’amène au ciné.
Dans France 3 régional, un journaliste parlant d’une réunion de coopération interrégionale Haute/Basse Normandie:
“Lors de cette réunion, quatre points d’importance seront évacués… évoqués, pardon…”
pour les fans de mario kart !!! : dailymotion.com/relevance/se … illard_fun
On n’arrête pas le progrès.
Franchement si c’est pas de l’abus
je l’offre direct à un pote qui adore mario :smt003
Je vous invite à suivre le Blog de Maester
Un génie du dessin et du bon mot.
maester.over-blog.com/
hello
Devinette: Quelle est la différence entre un pingouin (manchot), une pomme et une fenêtre ?
Et voilà le nouveau Mac
