Non, ça doit être plutôt la fatigue
De mon côté, pas de souci avec la commande monitor.
La lancer sur une console hors session (CTRL ALT F1), se déconnecter, se reconnecter et lire sur la console plein de lignes.
Monitoring signals from all objects owned by org.freedesktop.login1
The name org.freedesktop.login1 is owned by :1.1
/org/freedesktop/login1/session/_38: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.Session', {'Active': <false>}, @as [])
/org/freedesktop/login1/seat/seat0: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.Seat', {'ActiveSession': <('', objectpath '/')>}, @as [])
/org/freedesktop/login1/seat/seat0: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.Seat', {'Sessions': <[('10', objectpath '/org/freedesktop/login1/session/_310'), ('8', '/org/freedesktop/login1/session/_38'), ('6', '/org/freedesktop/login1/session/_36')]>}, @as [])
/org/freedesktop/login1: org.freedesktop.login1.Manager.SessionNew ('10', objectpath '/org/freedesktop/login1/session/_310')
/org/freedesktop/login1/user/_1000: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.User', {'Sessions': <[('10', objectpath '/org/freedesktop/login1/session/_310'), ('8', '/org/freedesktop/login1/session/_38'), ('6', '/org/freedesktop/login1/session/_36')]>, 'Display': <('6', objectpath '/org/freedesktop/login1/session/_36')>}, @as [])
/org/freedesktop/login1/seat/seat0: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.Seat', {'Sessions': <[('10', objectpath '/org/freedesktop/login1/session/_310'), ('8', '/org/freedesktop/login1/session/_38'), ('6', '/org/freedesktop/login1/session/_36')]>, 'ActiveSession': <('10', objectpath '/org/freedesktop/login1/session/_310')>}, @as [])
/org/freedesktop/login1: org.freedesktop.login1.Manager.SessionRemoved ('10', objectpath '/org/freedesktop/login1/session/_310')
/org/freedesktop/login1/session/_38: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.Session', {'Active': <true>}, @as [])
/org/freedesktop/login1/seat/seat0: org.freedesktop.DBus.Properties.PropertiesChanged ('org.freedesktop.login1.Seat', {'ActiveSession': <('8', objectpath '/org/freedesktop/login1/session/_38')>}, @as [])
