[quote=“misaine”]on ne voit pas de temps de latence sur le bootchart de 22s !?
donne-nous la sortie de dmesg[/quote]
Réponse rapide du bureau, je ferai un retour de la commande en edit de ce message : J’ai l’impression que Bootchart s’est arrêté au lancement de gdm car le temps mesure avec ma montre (à la louche) est d’environ 1m20 entre le lancement de grub et le bureau fonctionnel.
Edit pour retour de la commande : [ 1.796683] Freeing unused kernel memory: 712k freed
[ 1.798862] Freeing unused kernel memory: 684k freed
[ 1.808799] udevd[57]: starting version 175
[ 1.836599] SCSI subsystem initialized
[ 1.847191] libata version 3.00 loaded.
[ 1.848253] ahci 0000:00:1f.2: version 3.0
[ 1.848268] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.848319] ahci 0000:00:1f.2: irq 40 for MSI/MSI-X
[ 1.862998] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.863000] ACPI: Thermal Zone [TZ0] (40 C)
[ 1.863788] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[ 1.863802] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 1.863816] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.872288] scsi0 : ahci
[ 1.872438] scsi1 : ahci
[ 1.872576] scsi2 : ahci
[ 1.872679] scsi3 : ahci
[ 1.872782] scsi4 : ahci
[ 1.872884] scsi5 : ahci
[ 1.873079] ata1: SATA max UDMA/133 abar m2048@0xf7e06000 port 0xf7e06100 irq 40
[ 1.873081] ata2: DUMMY
[ 1.873083] ata3: SATA max UDMA/133 abar m2048@0xf7e06000 port 0xf7e06200 irq 40
[ 1.873085] ata4: DUMMY
[ 1.873086] ata5: DUMMY
[ 1.873087] ata6: DUMMY
[ 2.063510] Refined TSC clocksource calibration: 2394.560 MHz.
[ 2.063521] Switching to clocksource tsc
[ 2.191304] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.193002] ata3.00: ATAPI: MATSHITADVD-RAM UJ8B0, 1.00, max UDMA/100
[ 2.195017] ata3.00: configured for UDMA/100
[ 2.199292] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.254342] ata1.00: ATA-8: ST9500325AS, 0002SDM1, max UDMA/133
[ 2.254352] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.256428] ata1.00: configured for UDMA/133
[ 2.256640] scsi 0:0:0:0: Direct-Access ATA ST9500325AS 0002 PQ: 0 ANSI: 5
[ 2.258680] scsi 2:0:0:0: CD-ROM MATSHITA DVD-RAM UJ8B0 1.00 PQ: 0 ANSI: 5
[ 2.262300] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.262333] sd 0:0:0:0: [sda] Write Protect is off
[ 2.262336] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.262350] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.282796] sda: sda1 sda2 < sda5 sda6 >
[ 2.283165] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.178037] PM: Starting manual resume from disk
[ 3.178040] PM: Hibernation image partition 8:5 present
[ 3.178042] PM: Looking for hibernation image.
[ 3.178345] PM: Image not found (code -22)
[ 3.178347] PM: Hibernation image not present or could not be loaded.
[ 3.256970] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.975849] udevd[314]: starting version 175
[ 6.320781] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
[ 6.320788] ACPI: Power Button [PWRB]
[ 6.320840] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input2
[ 6.320845] ACPI: Sleep Button [SLPB]
[ 6.320902] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input3
[ 6.322022] ACPI: Lid Switch [LID0]
[ 6.322067] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 6.322072] ACPI: Power Button [PWRF]
[ 6.527763] wmi: Mapper loaded
[ 6.584879] jmb38x_ms 0000:03:00.3: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 6.584888] jmb38x_ms 0000:03:00.3: setting latency timer to 64
[ 6.618654] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 6.629804] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 6.629810] ACPI: resource 0000:00:1f.3 [io 0xf040-0xf05f] conflicts with ACPI region SMBI [io 0xf040-0xf04f]
[ 6.629812] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 6.668761] ACPI: AC Adapter [ADP0] (on-line)
[ 6.730559] iTCO_vendor_support: vendor-support=0
[ 6.756038] [drm] Initialized drm 1.1.0 20060810
[ 6.761976] usbcore: registered new interface driver usbfs
[ 6.762001] usbcore: registered new interface driver hub
[ 6.762050] usbcore: registered new device driver usb
[ 6.764253] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 6.764340] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 6.764462] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 6.766373] cfg80211: Calling CRDA to update world regulatory domain
[ 6.784036] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.784060] ehci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 6.784080] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 6.784083] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 6.784106] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 6.784131] ehci_hcd 0000:00:1a.0: debug port 2
[ 6.788015] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 6.788022] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7e08000
[ 6.800387] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 6.800411] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.800414] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.800416] usb usb1: Product: EHCI Host Controller
[ 6.800418] usb usb1: Manufacturer: Linux 3.2.0-1-amd64 ehci_hcd
[ 6.800420] usb usb1: SerialNumber: 0000:00:1a.0
[ 6.800549] hub 1-0:1.0: USB hub found
[ 6.800553] hub 1-0:1.0: 2 ports detected
[ 6.800637] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 6.869379] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 6.869384] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 6.869399] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 6.869433] ehci_hcd 0000:00:1d.0: debug port 2
[ 6.873313] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 6.873330] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7e07000
[ 6.888279] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 6.888333] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.888340] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.888345] usb usb2: Product: EHCI Host Controller
[ 6.888349] usb usb2: Manufacturer: Linux 3.2.0-1-amd64 ehci_hcd
[ 6.888366] usb usb2: SerialNumber: 0000:00:1d.0
[ 6.888469] hub 2-0:1.0: USB hub found
[ 6.888473] hub 2-0:1.0: 2 ports detected
[ 6.988577] sdhci: Secure Digital Host Controller Interface driver
[ 6.988581] sdhci: Copyright(c) Pierre Ossman
[ 7.008423] ACPI: Battery Slot [BAT0] (battery present)
[ 7.032924] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 7.032927] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 7.033099] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 7.133940] sdhci-pci 0000:03:00.1: SDHCI controller found [197b:2392] (rev 90)
[ 7.133959] sdhci-pci 0000:03:00.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 7.134004] sdhci-pci 0000:03:00.1: setting latency timer to 64
[ 7.134017] mmc0: no vmmc regulator found
[ 7.134056] Registered led device: mmc0::
[ 7.135094] mmc0: SDHCI controller on PCI [0000:03:00.1] using DMA
[ 7.135110] sdhci-pci 0000:03:00.2: SDHCI controller found [197b:2391] (rev 90)
[ 7.135123] sdhci-pci 0000:03:00.2: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 7.135127] sdhci-pci 0000:03:00.2: Refusing to bind to secondary interface.
[ 7.135134] sdhci-pci 0000:03:00.2: PCI INT B disabled
[ 7.171838] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 7.236485] jme: JMicron JMC2XX ethernet driver version 1.0.8
[ 7.236525] rtl8192ce 0000:02:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 7.236535] rtl8192ce 0000:02:00.0: setting latency timer to 64
[ 7.236686] jme 0000:03:00.0: PCI INT C -> GSI 17 (level, low) -> IRQ 17
[ 7.236706] jme 0000:03:00.0: setting latency timer to 64
[ 7.237836] jme 0000:03:00.0: eth0: JMC250 Gigabit Ethernet chiprev:35 pcirev:5 macaddr:00:90:f5:c1:bf:f4
[ 7.303935] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 7.303939] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.304375] hub 1-1:1.0: USB hub found
[ 7.304432] hub 1-1:1.0: 6 ports detected
[ 7.415478] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 7.547567] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 7.547571] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.547746] hub 2-1:1.0: USB hub found
[ 7.547815] hub 2-1:1.0: 6 ports detected
[ 7.591969] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 7.591973] i915 0000:00:02.0: setting latency timer to 64
[ 7.593034] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 7.593510] rtlwifi: wireless switch is on
[ 7.630577] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 7.630580] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 7.630951] i915 0000:00:02.0: irq 41 for MSI/MSI-X
[ 7.630956] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 7.630958] [drm] Driver supports precise vblank timestamp query.
[ 7.630986] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.647294] usb 1-1.2: new full-speed USB device number 3 using ehci_hcd
[ 7.742103] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52f
[ 7.742114] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.742119] usb 1-1.2: Product: USB Receiver
[ 7.742124] usb 1-1.2: Manufacturer: Logitech
[ 7.779633] psmouse serio2: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa40000/0xa0000
[ 7.819056] usb 2-1.6: new high-speed USB device number 3 using ehci_hcd
[ 7.821528] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input6
[ 7.964208] usb 2-1.6: New USB device found, idVendor=5986, idProduct=0315
[ 7.964217] usb 2-1.6: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 7.964223] usb 2-1.6: Product: BisonCam, NB Pro
[ 7.964228] usb 2-1.6: Manufacturer: BISON Corporation
[ 8.145736] cfg80211: World regulatory domain updated:
[ 8.145739] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 8.145742] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.145744] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.145746] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.145748] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.145750] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.145903] cfg80211: Calling CRDA for country: EC
[ 8.148819] cfg80211: Regulatory domain changed to country: EC
[ 8.148822] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 8.148825] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 8.148827] cfg80211: (5170000 KHz - 5250000 KHz @ 20000 KHz), (300 mBi, 1700 mBm)
[ 8.148829] cfg80211: (5250000 KHz - 5330000 KHz @ 20000 KHz), (300 mBi, 2300 mBm)
[ 8.148831] cfg80211: (5735000 KHz - 5835000 KHz @ 20000 KHz), (300 mBi, 3000 mBm)
[ 8.162154] fbcon: inteldrmfb (fb0) is primary device
[ 8.348561] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input7
[ 8.348678] generic-usb 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.0-1.2/input0
[ 8.350515] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/input/input8
[ 8.350663] generic-usb 0003:046D:C52F.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.0-1.2/input1
[ 8.350676] usbcore: registered new interface driver usbhid
[ 8.350677] usbhid: USB HID core driver
[ 8.507462] Linux media interface: v0.10
[ 8.523063] Linux video capture interface: v2.00
[ 8.532163] uvcvideo: Found UVC 1.00 device BisonCam, NB Pro (5986:0315)
[ 8.571465] input: BisonCam, NB Pro as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/input/input9
[ 8.571573] usbcore: registered new interface driver uvcvideo
[ 8.571575] USB Video Class driver (1.1.1)
[ 8.589642] Console: switching to colour frame buffer device 170x48
[ 8.593410] fb0: inteldrmfb frame buffer device
[ 8.593411] drm: registered panic notifier
[ 8.600926] acpi device:46: registered as cooling_device4
[ 8.600991] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input10
[ 8.601049] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 8.601113] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 8.601249] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 8.601309] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 8.601336] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 9.164133] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input11
[ 9.185250] HDMI status: Codec=3 Pin=6 Presence_Detect=0 ELD_Valid=0
[ 9.185413] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 9.185606] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 9.185683] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 9.994104] Adding 8200188k swap on /dev/sda5. Priority:-1 extents:1 across:8200188k
[ 9.997099] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 10.288327] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 10.365009] loop: module loaded
[ 11.065633] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 11.980109] RPC: Registered named UNIX socket transport module.
[ 11.980111] RPC: Registered udp transport module.
[ 11.980113] RPC: Registered tcp transport module.
[ 11.980114] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 12.019847] FS-Cache: Loaded
[ 12.043985] FS-Cache: Netfs 'nfs' registered for caching
[ 12.052215] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.678174] fuse init (API version 7.17)
[ 15.682897] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[ 16.026362] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 16.028481] jme 0000:03:00.0: irq 43 for MSI/MSI-X
[ 16.051207] jme 0000:03:00.0: eth0: Link is down
[ 16.051469] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.517562] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[ 19.062184] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input15
[ 19.477716] wlan0: authenticate with 36:2a:f4:30:cc:18 (try 1)
[ 19.479251] wlan0: authenticated
[ 19.499618] wlan0: associate with 36:2a:f4:30:cc:18 (try 1)
[ 19.510480] wlan0: RX AssocResp from 36:2a:f4:30:cc:18 (capab=0x411 status=0 aid=1)
[ 19.510490] wlan0: associated
[ 19.521159] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.794821] alg: No test for __gcm-aes-aesni (__driver-gcm-aes-aesni)
[ 22.321355] Disabling lock debugging due to kernel taint
[ 22.325031] vboxdrv: Found 4 processor cores.
[ 22.325271] vboxdrv: fAsync=0 offMin=0x1bf offMax=0x827a
[ 22.325338] vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
[ 22.325340] vboxdrv: Successfully loaded version 4.1.8_Debian (interface 0x00190000).
[ 22.450522] vboxpci: IOMMU not found (not registered)
[ 32.881539] wlan0: no IPv6 routers present
[ 312.130206] wlan0: deauthenticating from 36:2a:f4:30:cc:18 by local choice (reason=3)
[ 312.285443] cfg80211: Calling CRDA to update world regulatory domain
[ 312.289007] cfg80211: World regulatory domain updated:
[ 312.289011] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 312.289014] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 312.289017] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 312.289020] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 312.289022] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 312.289025] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 313.617760] PM: Syncing filesystems ... done.
[ 313.759618] PM: Preparing system for mem sleep
[ 314.058909] Freezing user space processes ... (elapsed 0.01 seconds) done.
[ 314.074791] Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done.
[ 314.090777] PM: Entering mem sleep
[ 314.090978] Suspending console(s) (use no_console_suspend to debug)
[ 314.091231] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 314.649399] sd 0:0:0:0: [sda] Stopping disk
[ 314.649738] pci 0000:00:1f.3: PCI INT C disabled
[ 314.649801] jmb38x_ms 0000:03:00.3: PCI INT B disabled
[ 314.649828] ehci_hcd 0000:00:1a.0: PCI INT A disabled
[ 314.650809] sdhci-pci 0000:03:00.1: PCI INT B disabled
[ 314.681873] ehci_hcd 0000:00:1d.0: PCI INT A disabled
[ 315.013603] snd_hda_intel 0000:00:1b.0: PCI INT A disabled
[ 315.093359] PM: suspend of devices complete after 1003.806 msecs
[ 315.093511] jme 0000:03:00.0: PME# enabled
[ 315.093516] jme 0000:03:00.0: wake-up capability enabled by ACPI
[ 315.125352] ehci_hcd 0000:00:1d.0: PME# enabled
[ 315.125381] ehci_hcd 0000:00:1d.0: wake-up capability enabled by ACPI
[ 315.141232] ehci_hcd 0000:00:1a.0: PME# enabled
[ 315.141289] ehci_hcd 0000:00:1a.0: wake-up capability enabled by ACPI
[ 315.157255] PM: late suspend of devices complete after 63.972 msecs
[ 315.157433] ACPI: Preparing to enter system sleep state S3
[ 315.177307] PM: Saving platform NVS memory
[ 315.183261] Disabling non-boot CPUs ...
[ 315.284988] CPU 1 is now offline
[ 315.388806] CPU 2 is now offline
[ 315.492652] CPU 3 is now offline
[ 315.493057] Extended CMOS year: 2000
[ 315.493323] ACPI: Low-level resume complete
[ 315.493361] PM: Restoring platform NVS memory
[ 315.494106] Extended CMOS year: 2000
[ 315.494137] Enabling non-boot CPUs ...
[ 315.494256] Booting Node 0 Processor 1 APIC 0x2
[ 315.494258] smpboot cpu 1: start_ip = 98000
[ 315.505268] Calibrating delay loop (skipped) already calibrated this CPU
[ 315.525608] NMI watchdog enabled, takes one hw-pmu counter.
[ 315.525871] CPU1 is up
[ 315.525980] Booting Node 0 Processor 2 APIC 0x1
[ 315.525981] smpboot cpu 2: start_ip = 98000
[ 315.536992] Calibrating delay loop (skipped) already calibrated this CPU
[ 315.557343] NMI watchdog enabled, takes one hw-pmu counter.
[ 315.557614] CPU2 is up
[ 315.557730] Booting Node 0 Processor 3 APIC 0x3
[ 315.557731] smpboot cpu 3: start_ip = 98000
[ 315.568740] Calibrating delay loop (skipped) already calibrated this CPU
[ 315.589256] NMI watchdog enabled, takes one hw-pmu counter.
[ 315.589504] CPU3 is up
[ 315.593272] ACPI: Waking up from system sleep state S3
[ 315.613825] i915 0000:00:02.0: restoring config space at offset 0xf (was 0x100, writing 0x10b)
[ 315.613833] i915 0000:00:02.0: restoring config space at offset 0x1 (was 0x900007, writing 0x900407)
[ 315.613852] pci 0000:00:16.0: restoring config space at offset 0xf (was 0x100, writing 0x10b)
[ 315.613865] pci 0000:00:16.0: restoring config space at offset 0x4 (was 0xfedb0004, writing 0xf7e0a004)
[ 315.613871] pci 0000:00:16.0: restoring config space at offset 0x1 (was 0x180006, writing 0x100006)
[ 315.613892] ehci_hcd 0000:00:1a.0: restoring config space at offset 0xf (was 0x100, writing 0x10b)
[ 315.613907] ehci_hcd 0000:00:1a.0: restoring config space at offset 0x4 (was 0x0, writing 0xf7e08000)
[ 315.613913] ehci_hcd 0000:00:1a.0: restoring config space at offset 0x1 (was 0x2900000, writing 0x2900002)
[ 315.613942] ehci_hcd 0000:00:1a.0: wake-up capability disabled by ACPI
[ 315.613946] ehci_hcd 0000:00:1a.0: PME# disabled
[ 315.613959] snd_hda_intel 0000:00:1b.0: restoring config space at offset 0xf (was 0x100, writing 0x105)
[ 315.613973] snd_hda_intel 0000:00:1b.0: restoring config space at offset 0x3 (was 0x0, writing 0x10)
[ 315.613977] snd_hda_intel 0000:00:1b.0: restoring config space at offset 0x1 (was 0x100000, writing 0x100002)
[ 315.614002] pcieport 0000:00:1c.0: restoring config space at offset 0xf (was 0x100, writing 0x10010b)
[ 315.614013] pcieport 0000:00:1c.0: restoring config space at offset 0x7 (was 0xf0, writing 0x200000f0)
[ 315.614020] pcieport 0000:00:1c.0: restoring config space at offset 0x3 (was 0x810000, writing 0x810010)
[ 315.614025] pcieport 0000:00:1c.0: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614055] pcieport 0000:00:1c.2: restoring config space at offset 0xf (was 0x300, writing 0x100303)
[ 315.614070] pcieport 0000:00:1c.2: restoring config space at offset 0x3 (was 0x810000, writing 0x810010)
[ 315.614075] pcieport 0000:00:1c.2: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614104] pcieport 0000:00:1c.3: restoring config space at offset 0xf (was 0x400, writing 0x10040a)
[ 315.614115] pcieport 0000:00:1c.3: restoring config space at offset 0x7 (was 0x2000d0d0, writing 0xd0d0)
[ 315.614122] pcieport 0000:00:1c.3: restoring config space at offset 0x3 (was 0x810000, writing 0x810010)
[ 315.614127] pcieport 0000:00:1c.3: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614155] ehci_hcd 0000:00:1d.0: restoring config space at offset 0xf (was 0x100, writing 0x10b)
[ 315.614169] ehci_hcd 0000:00:1d.0: restoring config space at offset 0x4 (was 0x0, writing 0xf7e07000)
[ 315.614176] ehci_hcd 0000:00:1d.0: restoring config space at offset 0x1 (was 0x2900000, writing 0x2900002)
[ 315.614201] ehci_hcd 0000:00:1d.0: wake-up capability disabled by ACPI
[ 315.614205] ehci_hcd 0000:00:1d.0: PME# disabled
[ 315.614261] ahci 0000:00:1f.2: restoring config space at offset 0x1 (was 0x2b00007, writing 0x2b00407)
[ 315.614341] rtl8192ce 0000:02:00.0: restoring config space at offset 0xf (was 0x1ff, writing 0x103)
[ 315.614368] rtl8192ce 0000:02:00.0: restoring config space at offset 0x6 (was 0x4, writing 0xf7d00004)
[ 315.614378] rtl8192ce 0000:02:00.0: restoring config space at offset 0x4 (was 0x1, writing 0xe001)
[ 315.614386] rtl8192ce 0000:02:00.0: restoring config space at offset 0x3 (was 0x0, writing 0x10)
[ 315.614396] rtl8192ce 0000:02:00.0: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614444] jme 0000:03:00.0: restoring config space at offset 0xf (was 0x300, writing 0x304)
[ 315.614454] jme 0000:03:00.0: restoring config space at offset 0xc (was 0x0, writing 0xf7c00000)
[ 315.614466] jme 0000:03:00.0: restoring config space at offset 0x8 (was 0x0, writing 0xf7c10000)
[ 315.614472] jme 0000:03:00.0: restoring config space at offset 0x7 (was 0x1, writing 0xd001)
[ 315.614478] jme 0000:03:00.0: restoring config space at offset 0x6 (was 0x1, writing 0xd101)
[ 315.614488] jme 0000:03:00.0: restoring config space at offset 0x3 (was 0x800000, writing 0x800010)
[ 315.614496] jme 0000:03:00.0: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614543] sdhci-pci 0000:03:00.1: restoring config space at offset 0xf (was 0x2ff, writing 0x20b)
[ 315.614569] sdhci-pci 0000:03:00.1: restoring config space at offset 0x4 (was 0x0, writing 0xf7c26000)
[ 315.614575] sdhci-pci 0000:03:00.1: restoring config space at offset 0x3 (was 0x800000, writing 0x800010)
[ 315.614583] sdhci-pci 0000:03:00.1: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614626] pci 0000:03:00.2: restoring config space at offset 0xf (was 0x2ff, writing 0x20b)
[ 315.614652] pci 0000:03:00.2: restoring config space at offset 0x4 (was 0x0, writing 0xf7c25000)
[ 315.614658] pci 0000:03:00.2: restoring config space at offset 0x3 (was 0x800000, writing 0x800010)
[ 315.614666] pci 0000:03:00.2: restoring config space at offset 0x1 (was 0x100000, writing 0x100003)
[ 315.614709] jmb38x_ms 0000:03:00.3: restoring config space at offset 0xf (was 0x2ff, writing 0x20b)
[ 315.614735] jmb38x_ms 0000:03:00.3: restoring config space at offset 0x4 (was 0x0, writing 0xf7c24000)
[ 315.614741] jmb38x_ms 0000:03:00.3: restoring config space at offset 0x3 (was 0x800000, writing 0x800010)
[ 315.614749] jmb38x_ms 0000:03:00.3: restoring config space at offset 0x1 (was 0x100000, writing 0x100007)
[ 315.614814] PM: early resume of devices complete after 1.018 msecs
[ 315.614887] i915 0000:00:02.0: setting latency timer to 64
[ 315.614892] ehci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 315.614896] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 315.614898] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 315.614903] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 315.614923] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 315.614930] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 315.614947] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 315.614951] ahci 0000:00:1f.2: setting latency timer to 64
[ 315.614981] pci 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 315.614995] rtlwifi: wireless switch is on
[ 315.615004] jme 0000:03:00.0: wake-up capability disabled by ACPI
[ 315.615010] jme 0000:03:00.0: PME# disabled
[ 315.615019] sdhci-pci 0000:03:00.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 315.615033] sdhci-pci 0000:03:00.1: setting latency timer to 64
[ 315.615055] jmb38x_ms 0000:03:00.3: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 315.615061] jmb38x_ms 0000:03:00.3: setting latency timer to 64
[ 315.636770] sd 0:0:0:0: [sda] Starting disk
[ 315.949044] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 315.955893] ata3.00: configured for UDMA/100
[ 318.261595] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 318.265607] ata1.00: configured for UDMA/133
[ 318.308973] PM: resume of devices complete after 2698.150 msecs
[ 318.309039] PM: Finishing wakeup.
[ 318.309040] Restarting tasks ... done.
[ 318.314440] video LNXVIDEO:00: Restoring backlight state
[ 318.892483] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[ 319.234314] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 319.235753] jme 0000:03:00.0: irq 43 for MSI/MSI-X
[ 319.260674] jme 0000:03:00.0: eth0: Link is down
[ 319.261481] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 321.918559] wlan0: authenticate with 36:2a:f4:30:cc:18 (try 1)
[ 321.921642] wlan0: authenticated
[ 321.922126] wlan0: associate with 36:2a:f4:30:cc:18 (try 1)
[ 321.946012] wlan0: RX AssocResp from 36:2a:f4:30:cc:18 (capab=0x411 status=0 aid=1)
[ 321.946021] wlan0: associated
[ 321.956748] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 332.212768] wlan0: no IPv6 routers present
Zozo : J’ai moi aussi testé LightDM en machine virtuelle et il est vrai que le temps est très réduit; Je n’ai pas voulu l’installer en dur car je ne trouve pas comment le personnaliser. Une idée ?
kripteks : J’ai lu sur plusieurs forum qu’apparemment ce temps de latence est dû à un chargement important de bibliothèques au démarrage afin d’améliorer la réactivité par la suite.
Merci de vos messages, cela me fait très plaisir que quelqu’un réagisse car c’est trop la misère.
P.S : J’ouvrirai prochainement un Post, car les mises à jour de ma machine sont bloquées (l’outil de mise à jour reste bloqué sur Execution, un aptitude upgrade bloque sur un rapport du bug au sujet de gconf mais je ne trouve pas comment en sortir pour continuer les maj)
