Ldap et foswiki
bonsoir
j’ai installer le plugin ldap pour foswiki et j’ai ce résultat avec des messages d’erreurs à la fin
quelqu’un pourrait t-il m aider
CPAN is disabled, disabling CPAN
LdapContrib Installer
This installer must be run from the root directory of your Foswiki
installation.
* You can abort the script at any point and re-run it later
* If you answer 'no' to any questions you can always re-run
  the script again later
Checking dependency on Authen::SASL…
Authen::SASL v2.15 loaded
Checking dependency on DB_File…
DB_File v1.82 loaded
Checking dependency on Digest::MD5…
Digest::MD5 v2.39 loaded
Checking dependency on Net::LDAP…
*** LdapContrib depends on cpan package Net::LDAP >=0.33
which is described as “Required”
But when I tried to find it I got this error:
“LDAP_SUCCESS” is not exported by the Net::LDAP::Constant module
"LDAP_COMPARE_TRUE" is not exported by the Net::LDAP::Constant module
"LDAP_COMPARE_FALSE" is not exported by the Net::LDAP::Constant module
Can’t continue after import errors at /usr/share/perl5/Net/LDAP/Message.pm line 7
BEGIN failed–compilation aborted at /usr/share/perl5/Net/LDAP/Message.pm line 7, chunk 1.
Compilation failed
Checking dependency on IO::Socket::SSL…
*** LdapContrib depends on cpan package IO::Socket::SSL >=1.0
which is described as "Optional"
Can’t locate IO/Socket/SSL.pm
Checking dependency on Unicode::MapUTF8…
Unicode::MapUTF8 v1.11 loaded
Archive has already been unpacked.
Installation finished
merci
