Hello,
Voilà ce que je veux faire : administrer LDAP à travers MMC
Voilà mon problème : # /etc/init.d/mmc-agent restart
[quote]Restarting Mandriva Management Console XML-RPC Agent: mmc-agent 2.3.2 starting…
Using Python 2.5.5 (r255:77872, Feb 1 2010, 19:53:42)
Using Python Twisted 9.0.0
Running as euid = 0, egid = 0
Importing available MMC plugins
Can’t bind to LDAP: invalid credentials.
Plugin base not loaded.
MMC agent can’t run without the base plugin. Exiting.
-e failed.[/quote]
[quote]/etc/ldap/slapd.conf: line 111: rootdn is always granted unlimited privileges.
/etc/ldap/slapd.conf: line 128: rootdn is always granted unlimited privileges.
config file testing succeeded[/quote]
Voilà mes fichiers de conf :
base.ini
[code][ldap]
LDAP we are connected to
host = 127.0.0.1
LDAP base DN
baseDN = dc=test, dc=com
Users location in the LDAP
baseUsersDN = ou=Users, %(basedn)s
Groups location in the LDAP
baseGroupsDN = ou=Groups, %(basedn)s
LDAP manager
rootName = cn=admin, %(basedn)s
password = secret
If enabled, the MMC will create/move/delete the home of the users
Else will do nothing, but only write user informations into LDAP
userHomeAction = 1
Skeleton directory to populate a new home directory
skelDir = /etc/skel
If set, all new users will belong to this group when created
defaultUserGroup = Domain Users
Default home directory for users
defaultHomeDir = /home
user uid number start
uidStart = 10000
group gid number start
gidStart = 10000
LDAP log file path
logfile = /var/log/ldap.log
FDS log file path
logfile = /opt/fedora-ds/slapd-hostname/logs/access
you can specify here where you can authorized creation of your homedir
default is your defaultHomeDir
example:
authorizedHomeDir = /home, /home2, /mnt/depot/newhome
LDAP user password scheme to use
Possible values are “ssha” and “crypt”
passwordscheme = ssha
[backup-tools]
Path of the backup tools
path = /usr/lib/mmc/backup-tools
Where are put the archives
destpath = /home/archives
User authentication configuration
#[authentication]
Authenticators chain
#method = baseldap externalldap
baseldap authenticator configuration
#[authentication_baseldap]
Set a list of login that will only be authentified using this authenticator
#authonly = root
Externalldap authenticator configuration
#[authentication_externalldap]
Login list that won’t be authenticated with this authenticator
#exclude = root
LDAP server URL
#ldapurl = ldap://192.168.0.1:389
LDAP suffix where to search for user
#suffix = cn=Users,dc=mandriva,dc=com
How to bind to the LDAP. Empty if anonymous
#bindname = cn=account, cn=Users, dc=linboxad, dc=com
#bindpasswd = s3cr3t
#bindname =
#bindpasswd =
User filter
#filter = objectClass=*
User attribute containing her/his login
#attr = cn
User provisioning configuration
#[provisioning]
#method = externalldap
externalldap provisioner configuration
#[provisioning_externalldap]
Login list that won’t be provisioned with this provisioner
#exclude = root
These attributes are mandatory to create a user
#ldap_uid = cn
#ldap_givenName = sn
#ldap_sn = sn
Other attributes to fill in
#ldap_mail = mail
We are able to fill the ACL fields the user logs in according to the value of
an attribute from the external LDAP.
What is the field name ?
#profile_attr =
Here we define two profiles: profile1 and profile2
profile1 allows the user to log in and change her/his password in the web
interface
#profile_acl_profile1= :base#users#passwd/
profile2 disallows the user to do anything (no ACL defined)
#profile_acl_profile2 =
… You can define as much profile_acl_* options as you need
For each profile, we can create a group of user, and put users with a given
profile in the corresponding group automatically when they log in.
Set the next line to True to activate profile to group mapping
#profile_group_mapping = False
A prefix for the created group can be set
#profile_group_prefix =[/code]
slapd.conf
[code]# Allow LDAPv2 binds
allow bind_v2
This is the main slapd configuration file. See slapd.conf(5) for more
info on the configuration options.
Global Directives:
Features to permit
#allow bind_v2
Schema and objectClass definitions
include /etc/ldap/schema/core.schema
include /etc/ldap/schema/cosine.schema
include /etc/ldap/schema/nis.schema
include /etc/ldap/schema/inetorgperson.schema
Where the pid file is put. The init.d script
will not stop the server if you change this.
pidfile /var/run/slapd/slapd.pid
List of arguments that were passed to the server
argsfile /var/run/slapd/slapd.args
Read slapd.conf(5) for possible values
loglevel none
Where the dynamically loaded modules are stored
modulepath /usr/lib/ldap
moduleload back_hdb
The maximum number of entries that is returned for a search operation
sizelimit 500
The tool-threads parameter sets the actual amount of cpu’s that is used
for indexing.
tool-threads 1
Specific Backend Directives for hdb:
Backend specific directives apply to this backend until another
‘backend’ directive occurs
backend hdb
Specific Backend Directives for ‘other’:
#backend
Specific Directives for database #1, of type hdb:
Database specific directives apply to this databasse until another
‘database’ directive occurs
database hdb
The base of your directory in database #1
suffix “dc=test,dc=com”
rootdn directive for specifying a superuser on the database. This is needed
for syncrepl.
rootdn “cn=admin,dc=test,dc=com”
Where the database file are physically stored for database #1
directory “/var/lib/ldap”
The dbconfig settings are used to generate a DB_CONFIG file the first
time slapd starts. They do NOT override existing an existing DB_CONFIG
file. You should therefore change these settings in DB_CONFIG directly
or remove DB_CONFIG and restart slapd for changes to take effect.
For the Debian package we use 2MB as default but be sure to update this
value if you have plenty of RAM
dbconfig set_cachesize 0 2097152 0
Sven Hartge reported that he had to set this value incredibly high
to get slapd running at all. See http://bugs.debian.org/303057 for more
information.
Number of objects that can be locked at the same time.
dbconfig set_lk_max_objects 1500
Number of locks (both requested and granted)
dbconfig set_lk_max_locks 1500
Number of lockers
dbconfig set_lk_max_lockers 1500
Indexing options for database #1
index objectClass eq
Save the time that the entry gets modified, for database #1
lastmod on
Checkpoint the BerkeleyDB database periodically in case of system
failure and to speed slapd shutdown.
checkpoint 512 30
Where to store the replica logs for database #1
replogfile /var/lib/ldap/replog
The userPassword by default can be changed
by the entry owning it if they are authenticated.
Others should not be able to see it, except the
admin entry below
These access lines apply to database #1 only
access to attrs=userPassword,shadowLastChange
by dn=“cn=admin,dc=test,dc=com” write
by anonymous auth
by self write
by * none
Ensure read access to the base for things like
supportedSASLMechanisms. Without this you may
have problems with SASL not knowing what
mechanisms are available and the like.
Note that this is covered by the ‘access to *’
ACL below too but if you change that as people
are wont to do you’ll still need this if you
want SASL (and possible other things) to work
happily.
access to dn.base="" by * read
The admin dn has full write access, everyone else
can read everything.
access to *
by * read
For Netscape Roaming support, each user gets a roaming
profile for which they have write access to
#access to dn=".*,ou=Roaming,o=morsnet"
by dnattr=owner write
Specific Directives for database #2, of type ‘other’ (can be hdb too):
#database
The base of your directory for database #2
#suffix “dc=debian,dc=org”
mon sourcelist, des fois que…
[quote]## squeeze
deb ftp.fr.debian.org/debian/ squeeze main contrib non-free
deb-src ftp.fr.debian.org/debian/ squeeze main contrib non-free
squeeze multimedia
deb mirror.home-dn.net/debian-multimedia squeeze main
deb-src mirror.home-dn.net/debian-multimedia squeeze main
squeeze security
deb security.debian.org/ squeeze/updates main contrib non-free
deb-src security.debian.org/ squeeze/updates main contrib non-free
deb mds.mandriva.org/pub/mds/debian lenny main[/quote]
donc concretement, MMC n’arrive pas à se connecter à LDAP, bien que j’ai paramétré correctement mes identifiants… J’ai essayé plein de choses, je ne vois plus quoi faire
