ide_cd_mod: Unknown parameter `ide_cd_mod’
oui, la je ne sais plus …
dmesg | grep ata
pata
dmesg | grep ata
pata
# dmesg | grep ata
[ 0.000000] BIOS-e820: 000000007ffb0000 - 000000007ffbe000 (ACPI data)
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] PERCPU: Embedded 29 pages at ffff880001706000, static data 86368 bytes
[ 0.000000] Memory: 2050788k/2096832k available (3657k kernel code, 452k absent, 45592k reserved, 1679k data, 700k init)
[ 0.510094] Write protecting the kernel read-only data: 4752k
[ 0.698737] libata version 3.00 loaded.
[ 0.765481] ata1: SATA max UDMA/133 abar m1024@0xf9fff800 port 0xf9fff900 irq 22
[ 0.765485] ata2: SATA max UDMA/133 abar m1024@0xf9fff800 port 0xf9fff980 irq 22
[ 0.765488] ata3: SATA max UDMA/133 abar m1024@0xf9fff800 port 0xf9fffa00 irq 22
[ 0.765492] ata4: SATA max UDMA/133 abar m1024@0xf9fff800 port 0xf9fffa80 irq 22
[ 1.248517] ata3: softreset failed (device not ready)
[ 1.248574] ata3: applying SB600 PMP SRST workaround and retrying
[ 1.248590] ata4: softreset failed (device not ready)
[ 1.248645] ata4: applying SB600 PMP SRST workaround and retrying
[ 1.248661] ata2: softreset failed (device not ready)
[ 1.248715] ata2: applying SB600 PMP SRST workaround and retrying
[ 1.248731] ata1: softreset failed (device not ready)
[ 1.248785] ata1: applying SB600 PMP SRST workaround and retrying
[ 1.412051] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.412056] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.412092] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.412095] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.414009] ata3.00: ATA-8: SAMSUNG HD321KJ, CP100-12, max UDMA7
[ 1.414012] ata3.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.414027] ata3.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.414150] ata2.00: ATA-7: Maxtor 6B200M0, BANC1BM0, max UDMA/133
[ 1.414153] ata2.00: 398297088 sectors, multi 0: LBA48 NCQ (not used)
[ 1.414160] ata2.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.415992] ata3.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.415995] ata3.00: configured for UDMA/133
[ 1.417124] ata2.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.417127] ata2.00: configured for UDMA/133
[ 1.417442] ata1.00: ATA-7: SAMSUNG HD250HJ, FH100-06, max UDMA7
[ 1.417444] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.417458] ata1.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.422851] ata1.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.422853] ata1.00: configured for UDMA/133
[ 1.442278] ata4.00: ATA-8: Hitachi HDP725032GLA360, GM3OA52A, max UDMA/133
[ 1.442281] ata4.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.442296] ata4.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.443122] ata4.00: SB600 AHCI: limiting to 255 sectors per cmd
[ 1.443125] ata4.00: configured for UDMA/133
[ 1.933293] EXT3-fs: mounted filesystem with ordered data mode.
[ 20.428981] EXT3-fs: mounted filesystem with ordered data mode.
[ 21.868649] EXT3-fs: mounted filesystem with ordered data mode.
[ 21.909157] EXT3-fs: mounted filesystem with ordered data mode.
[ 21.977162] EXT3-fs: mounted filesystem with ordered data mode.
Si je suis la piste du module manquant, je vais devoir changer le titre du fil. Mais un module manquant pour un lecteur de CD… c’est possible, ça ?
Et comment le retrouver ?
Je vois à peu près qu’un module, c’est un truc (logiciel) qui fait fonctionner un machin (matériel) mais je n’ai jamais eu besoin d’en ajouter/enlever jusqu’à présent (les drivers Nvidia sont hors jeu).
Il me restait le côté matériel à vérifier.
Je n’y croyais pas trop mais comme je n’avais rien à perdre…
Depuis que j’avais enlevé le dernier disque IDE de ma machine, il ne me restait que le lecteur CD en IDE et il était resté comme à l’origine : en esclave. Un esclave sans maître, ça peut paraître un peu bizarre, sans doute mais comme ça n’avait jamais posé problème, je n’avais touché à rien.
J’ai bien fait de me poser la question, finalement parce que, une fois remis en maître et proprement renommé en /dev/hda dans mon fstab, le noyau 2.6.31 le reconnaît sans l’ombre d’une hésitation !
$ uname -r
2.6.31-1-amd64
$ dmesg | grep CD
[ 1.508435] hda: Optiarc DVD RW AD-5200A, ATAPI CD/DVD-ROM drive
[ 2.931414] ide-cd: hda: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 974kB Cache
[ 2.931421] Uniform CD-ROM driver Revision: 3.20
Me voilà fière comme un p’tit banc.
Si les p’tits cochons ne me mangent pas, on finira par faire quelque chose de moi.
Bravo,
il fallait aller le chercher ce truc là… Bon à retenir.
Tu as peur des petits cochons ? Pas du grand méchant loup ?
le p’tit cochon (qui sommeille) n’a rien de bien effrayant.
Quant au grand méchant loup… il n’est pas si difficile à apprivoiser.
(smiley approximatif !)
