Bonjour à tous
- j’ai un souci pour la configuration du Lecteur de bande OnStream DI-30 IDE . après plusieurs tentatives je cal …
Voir ma config. ci-dessous .
- Questions ? Quels softs utilisé pour faire les sauvegardes (systèmes et données) ? mondo ,bacula …etc ?
rasta@lampsvr:~$ uname -a
Linux lampsvr 2.6.18-4-k7 #1 SMP Wed May 9 23:42:01 UTC 2007 i686 GNU/Linux
lampsvr:~# dmesg | grep hd
Kernel command line: root=/dev/hda3 ro
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:DMA
hda: Maxtor 6Y160P0, ATA DISK drive
hdc: OnStream DI-30, ATAPI TAPE drive
hdd: _NEC DVD_RW ND-2500A, ATAPI CD/DVD-ROM drive
hda: max request size: 512KiB
hda: 320173056 sectors (163928 MB) w/7936KiB Cache, CHS=19929/255/63, UDMA(133)
hda: cache flushes supported
hda: hda1 hda2 hda3 hda4 < hda5 hda6 hda7 hda8 hda9 hda10 hda11 hda12 >
hdd: ATAPI 32X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Adding 987956k swap on /dev/hda10. Priority:-1 extents:1 across:987956k
EXT3 FS on hda3, internal journal
EXT3 FS on hda9, internal journal
EXT3 FS on hda8, internal journal
EXT3 FS on hda6, internal journal
EXT3 FS on hda7, internal journal
lampsvr:~# ls -ld /proc/ide/*
-r–r--r-- 1 root root 0 2007-09-01 19:44 /proc/ide/drivers
lrwxrwxrwx 1 root root 8 2007-09-01 19:44 /proc/ide/hda -> ide0/hda
lrwxrwxrwx 1 root root 8 2007-09-01 19:44 /proc/ide/hdc -> ide1/hdc
lrwxrwxrwx 1 root root 8 2007-09-01 19:44 /proc/ide/hdd -> ide1/hdd
dr-xr-xr-x 3 root root 0 2007-09-01 19:44 /proc/ide/ide0
dr-xr-xr-x 4 root root 0 2007-09-01 19:44 /proc/ide/ide1
rasta@lampsvr:~$ cat /etc/fstab
/etc/fstab: static file system information.
proc /proc proc defaults 0 0
/dev/hda3 / ext3 defaults,errors=remount-ro 0 1
/dev/hda9 /home ext3 defaults 0 2
/dev/hda8 /tmp ext3 defaults 0 2
/dev/hda6 /usr ext3 defaults 0 2
/dev/hda7 /var ext3 defaults 0 2
/dev/hda10 none swap sw 0 0
/dev/hdd /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
/dev/sda1 /mnt/cle vfat defaults,rw,user,noauto 0 0
/dev/hdc /mnt/stream vfat defaults,rw,user,noauto 0 0
Merci d’avance pour vos reponses
