j’ ai essayé de lire un cd audio dans le lecteur dvd situé en /dev/hdd avec vlc par la console (je ne sais pas comment lancer vlc autrement…!!!) et voici ce qu’ il m’ affiche dans la console :
VLC media player 0.8.2-svn Janus
Gdk-CRITICAL **: file gdkgc.c: line 689 (gdk_gc_set_clip_rectangle): assertion `gc != NULL’ failed.
Gdk-CRITICAL **: file gdkdraw.c: line 90 (gdk_draw_rectangle): assertion `gc != NULL’ failed.
Gdk-CRITICAL **: file gdkgc.c: line 689 (gdk_gc_set_clip_rectangle): assertion gc != NULL' failed. [00000246] main playlist: adding playlist itemdvd:///dev/hdd’ ( dvd:///dev/hdd )
libdvdnav: Using dvdnav version 0.1.9 from dvd.sf.net
libdvdread: Using libdvdcss version 1.2.9 for DVD access
libdvdnav: Can’t read name block. Probably not a DVD-ROM device.
libdvdnav: Unable to find map file '/root/.dvdnav/.map’
libdvdread: Can’t open file VIDEO_TS.IFO.
libdvdnav: vm: faild to read VIDEO_TS.IFO
title[0] start=11625
title[0] end=16725
title[1] start=16725
title[1] end=24600
title[2] start=24600
title[2] end=28125
title[3] start=28125
title[3] end=34500
title[4] start=34500
title[4] end=39150
title[5] start=39150
title[5] end=55275
title[6] start=55275
title[6] end=61950
title[7] start=61950
title[7] end=74550
title[8] start=74550
title[8] end=82350
title[9] start=82350
title[9] end=89550
title[10] start=89550
title[10] end=101775
title[11] start=101775
title[11] end=110175
title[12] start=110175
title[12] end=119625
title[13] start=119625
title[13] end=133500
title[14] start=133500
title[14] end=143550
title[15] start=143550
title[15] end=152400
title[16] start=152400
title[16] end=161925
title[17] start=161925
title[17] end=171150
title[18] start=171150
title[18] end=184800
title[19] start=184800
title[19] end=198225
[00000257] vcd access error: invalid entry points number
[00000246] main playlist: nothing to play
conclusion : le lecteur se lance mais rien n’ en sort …! j’ ai l’ impression qu’ il tourne en rond.
