Je l’ai fait, il manquait une librairie : libgtk-x11-2.0.so.0
après recherche, il fallait installer ia32-libs-gtk
je l’installe donc, firefox se lance, mais est étrange (mauvaise gestion graphique, pas de connection à internet…). Voici la sortie du terminal :
[code]$ firefox
(firefox-bin:4221): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/engines/libclearlooks.so: wrong ELF class: ELFCLASS64
LoadPlugin: failed to initialize shared library /usr/lib/mozilla/plugins/librhythmbox-itms-detection-plugin.so [/usr/lib/mozilla/plugins/librhythmbox-itms-detection-plugin.so: wrong ELF class: ELFCLASS64]
LoadPlugin: failed to initialize shared library /usr/lib/totem/gstreamer/libtotem-basic-plugin.so [/usr/lib/totem/gstreamer/libtotem-basic-plugin.so: wrong ELF class: ELFCLASS64]
LoadPlugin: failed to initialize shared library /usr/lib/totem/gstreamer/libtotem-complex-plugin.so [/usr/lib/totem/gstreamer/libtotem-complex-plugin.so: wrong ELF class: ELFCLASS64]
LoadPlugin: failed to initialize shared library /usr/lib/totem/gstreamer/libtotem-gmp-plugin.so [/usr/lib/totem/gstreamer/libtotem-gmp-plugin.so: wrong ELF class: ELFCLASS64]
LoadPlugin: failed to initialize shared library /usr/lib/totem/gstreamer/libtotem-mully-plugin.so [/usr/lib/totem/gstreamer/libtotem-mully-plugin.so: wrong ELF class: ELFCLASS64]
LoadPlugin: failed to initialize shared library /usr/lib/totem/gstreamer/libtotem-narrowspace-plugin.so [/usr/lib/totem/gstreamer/libtotem-narrowspace-plugin.so: wrong ELF class: ELFCLASS64]
LoadPlugin: failed to initialize shared library /usr/lib/flashplugin-nonfree/libflashplayer.so [/usr/lib/flashplugin-nonfree/libflashplayer.so: wrong ELF class: ELFCLASS64]
(firefox-bin:4221): Gtk-WARNING **: Error loading theme icon ‘gtk-dialog-warning’ for stock: Impossible de charger le module de chargement d’images : /usr/lib32/gtk-2.0/2.10.0/loaders/svg_loader.so : /usr/lib32/gtk-2.0/2.10.0/loaders/svg_loader.so: Ne peut ouvrir le fichier d’objet partagé: Aucun fichier ou répertoire de ce type
après avoir vu ce post, il semblerait que faire tourner firefox sur Debian 64 ne soit pas possible… ??
Je ne sais pas si c’est compliqué d’en fournir un version 64 bits, mais au vu de l’évolution des choses, ça m’étonnerait quand même qu’une fondation comme mozilla s’amuse à ne pas porter ses applications sur de telles architectures.
Au passage, j’ai fait un apt-get install apt-file, puis apt-file update pour rechercher la première librairie. Au final, j’ai
Can’t get security.debian.org/dists/lenny/ … s-amd64.gz
Can’t get security.debian.org/dists/squeez … s-amd64.gz
Can’t get ftp.fr.debian.org/debian/dists/l … s-amd64.gz
avec un sources.list donnant les sources depuis lenny jusqu’à expérimental, et le fichier preferences qui vas avec, j’ai aussi réinstallée les clés.
à l’installation, les dépots sécurity n’ont pas pu être atteints. Il y a eu du changement récemment ? c’est normal que je ne puisse atteindre les 3 dépôts précités ?
