Lenny et la St Valentin
J’ai lu que Lenny passait en stable le 14 fev.
Mon sources.list est un mélange de Lenny,Sid et experimental.
Je voulais savoir si je n’avais pas interret à oter Sid et experimental afin que la transition se passe le mieu possible pour moi, ou si je pouvais laisser mon sources.list tel quel.
mon sources.list (tapez pas je sais que c’est le foutoir :slightly_smiling:)
[list=]#
deb cdrom:[Debian GNU/Linux testing Lenny - Official RC i386 CD Binary-1 20081104-07:57]/ lenny main
deb ftp.fr.debian.org/debian/ lenny main non-free contrib
deb-src ftp.fr.debian.org/debian/ lenny main non-free contrib
deb security.debian.org/ lenny/updates main non-free contrib
deb ftp.fr.debian.org/debian/ lenny-proposed-updates non-free contrib main
deb-src ftp.fr.debian.org/debian/ lenny-proposed-updates non-free contrib main
deb http.fr.debian.org/debian/ sid main contrib non-free
deb-src security.debian.org/ lenny/updates main non-free contrib
Debian experimental Dangerous stuff
deb ftp.fr.debian.org/debian/ experimental main
deb-src ftp.fr.debian.org/debian/ experimental main
#wxWidgets/wxPython repository at apt.wxwidgets.org
#deb apt.wxwidgets.org/ gutsy-wx main
#deb-src apt.wxwidgets.org/ gutsy-wx main
##compizgit###
deb download.tuxfamily.org/shames/de … /unstable/ ./
##xcfa##
deb download.tuxfamily.org/xcfaudio/xcfa dev contrib
deb-src download.tuxfamily.org/xcfaudio/xcfa dev contribdeb
##vlc##
deb download.videolan.org/pub/videolan/debian sid main
deb-src download.videolan.org/pub/videolan/debian sid main
[/list]
mon fichier pref:
[list=]Package: *
Pin: release a=testing
Pin-Priority: 990
Package: *
Pin: release a=apt-build
Pin-Priority: 990
Package: *
Pin: release a=unstable
Pin-Priority: 66
Package: wine
Pin-Priority: 991
Package: libwine
Pin-Priority: 991
Package: *
Pin: origin download.tuxfamily.org
Pin-Priority: 999
Package: *
Pin: origin nightlies.videolan.org
Pin-Priority: 990[/list]
Je ne pense pas que ce soit utile maîtresse. Ton fichier preferences donne la priorité à Lenny.
pour ne plus te poser de questions, passe donc en sid … collègue ! :smt002
Oui c’est aussi ce que je me dit depuis que je suis sur Debian (3-4 mois env).
Faut juste que je modifie mon sources.list et mon preferences, c’est ça ?
J’ai exactemen les mêmes sources listes que toi et un fichier de preferences différent , et je me demande aussi ce qui va se passé le 14fev!
Voici mon fichier de préférence:
Package: *
Pin: release o=Debian,a=unstable
Pin-priority: 90
Package: *
Pin: release o=Debian,a=experimental
Pin-priority: 70
Si vous êtes avec un fichier préférences priorité Lenny, il ne va rien se passer. Vous allez rester en lenny.
Attention, dans votre sources list: si vous souhaiter rester sur la version stable (c’est-à-dire lenny) il faut modifier le fichier le fichier sources.list et le fichier préférence en remplaçant stable, unstable, et testing par les noms des versions. Sinon, si vous laissez testing comme nom dans les sources.list, vous allez vous retrouver avec la prochaine version testing (squeeze) qui risque d’être bien merdique après la sortie de lenny.
bjr,
Donc si je suis ton conseil @ Bedbug105, quand on a Lenny et Sid dans le sources.list il faut les mettre aussi à la place de stable et unstable dans le preferences de Trucs et Astuces ?
