salut,
voici un problème concernant AWN: j’ai installé AWN (avant-window-navigator, un programme de dock à la MACOSX, sous gnome je crois) à partir de synaptic, et ça marchait.
mais j’ai éteint l’ordi et au démarrage je n’avais plus le dock.
j’ai donc tapé “avant-window-navigator” dans une console et j’obtiens une erreur:
[quote]debian:/home/lolveley# avant-window-navigator
curves_symmetry unset, setting now
curviness unset, setting now
** (avant-window-navigator:3403): WARNING **: Failed to make connection to session bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
** (avant-window-navigator:3403): CRITICAL **: dbus_g_proxy_new_for_name: assertion `connection != NULL’ failed
** (avant-window-navigator:3403): CRITICAL **: dbus_g_proxy_call: assertion `DBUS_IS_G_PROXY (proxy)’ failed
** (avant-window-navigator:3403): WARNING **: There was an error requesting the name: Did not receive a reply. Possible causes include: the remote ly. Possible causes include: the remote ly. Possible causes include: the remote ly. Possible causes include: the remote ly. Possible causes include:
*** glibc detected *** avant-window-navigator: double free or corruption (top): 0x08e208a0 ***
======= Backtrace: =========
/lib/i686/cmov/libc.so.6[0xb77c2624]
/lib/i686/cmov/libc.so.6(cfree+0x96)[0xb77c4826]
/usr/lib/libglib-2.0.so.0(g_free+0x36)[0xb7a20426]
/usr/lib/libglib-2.0.so.0(g_error_free+0x29)[0xb7a07ff9]
avant-window-navigator[0x804f1c1]
/lib/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb776a455]
avant-window-navigator[0x804e261]
======= Memory map: ========
08048000-08065000 r-xp 00000000 08:01 236455 /usr/bin/avant-window-navigator
08065000-08066000 rw-p 0001d000 08:01 236455 /usr/bin/avant-window-navigator
08ceb000-08e3d000 rw-p 08ceb000 00:00 0 [heap]
b6900000-b6921000 rw-p b6900000 00:00 0
b6921000-b6a00000 —p b6921000 00:00 0
b6a37000-b6a43000 r-xp 00000000 08:01 24236 /lib/libgcc_s.so.1
b6a43000-b6a44000 rw-p 0000b000 08:01 24236 /lib/libgcc_s.so.1
b6a53000-b6b57000 rw-p b6a53000 00:00 0
b6b57000-b6bec000 r–p 00000000 08:01 41479 /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
b6bec000-b6bf2000 r–s 00000000 08:01 185737 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.cache-2
b6bf2000-b6c10000 r–p 00000000 08:01 407080 /usr/share/locale/fr/LC_MESSAGES/libc.mo
b6c10000-b6c35000 r–p 00000000 08:01 409575 /usr/share/locale/fr/LC_MESSAGES/gtk20-properties.mo
b6c35000-b6c3f000 r-xp 00000000 08:01 32840 /lib/i686/cmov/libnss_files-2.7.so
b6c3f000-b6c41000 rw-p 00009000 08:01 32840 /lib/i686/cmov/libnss_files-2.7.so
b6c41000-b6c4a000 r-xp 00000000 08:01 32842 /lib/i686/cmov/libnss_nis-2.7.so
b6c4a000-b6c4c000 rw-p 00008000 08:01 32842 /lib/i686/cmov/libnss_nis-2.7.so
b6c4c000-b6c53000 r-xp 00000000 08:01 32838 /lib/i686/cmov/libnss_compat-2.7.so
b6c53000-b6c55000 rw-p 00006000 08:01 32838 /lib/i686/cmov/libnss_compat-2.7.so
b6c57000-b6c59000 r-xp 00000000 08:01 57801 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b6c59000-b6c5a000 rw-p 00001000 08:01 57801 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b6c5a000-b6c5d000 r–s 00000000 08:01 185745 /var/cache/fontconfig/6eb3985aa4124903f6ff08ba781cd364-x86.cache-2
b6c5d000-b6c64000 r–s 00000000 08:01 185744 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.cache-2
b6c64000-b6c75000 r–p 00000000 08:01 409574 /usr/share/locale/fr/LC_MESSAGES/gtk20.mo
b6c75000-b6daf000 r–p 00000000 08:01 1384 /usr/lib/locale/locale-archive
b6daf000-b6db2000 rw-p b6daf000 00:00 0
b6db2000-b6e18000 r-xp 00000000 08:01 406319 /usr/lib/libgcrypt.so.11.4.4
b6e18000-b6e1a000 rw-p 00066000 08:01 406319 /usr/lib/libgcrypt.so.11.4.4
b6e1a000-b6e1d000 r-xp 00000000 08:01 406321 /usr/lib/libgpg-error.so.0.3.0
b6e1d000-b6e1e000 rw-p 00002000 08:01 406321 /usr/lib/libgpg-error.so.0.3.0
b6e1e000-b6e1f000 rw-p b6e1e000 00:00 0
b6e1f000-b6e2e000 r-xp 00000000 08:01 406328 /usr/lib/libtasn1.so.3.0.15
b6e2e000-b6e2f000 rw-p 0000e000 08:01 406328 /usr/lib/libtasn1.so.3.0.15
b6e2f000-b6e46000 r-xp 00000000 08:01 24241 /lib/libselinux.so.1
b6e46000-b6e48000 rw-p 00016000 08:01 24241 /lib/libselinux.so.1
b6e48000-b6e4a000 r-xp 00000000 08:01 32850 /lib/i686/cmov/libutilAbandon
savez-vous comment avoir à nouveau le dock?
comment lancer le programme au démarrage?
question annexe : comment savoir si KDE est installé sur debian (je voudrais installer un time-tracker nommé KArm qui fonctionne avec KDE mais je crois que je n’ai que gnome.)
olivier.
