Tu as la possibilité de mettre un truc dans /etc/network/interfaces, genre:
[code]allow-hotplug lan
iface lan inet static
auto internet
iface internet inet manual
auto dsl-provider
iface dsl-provider inet ppp
pre-up /sbin/ifconfig internet up # line maintained by pppoeconf
provider dsl-provider
allow-hotplug dmz
iface dmz inet static
…[/code]que tu complètes ensuite en faisant un renommage udev et en modifiant /etc/udev/rules.d/z25_persistent-net.rules :
[code]# This file was automatically generated by the /lib/udev/write_net_rules
program, probably run by the persistent-net-generator.rules rules file.
You can modify it, as long as you keep each rule on a single line.
MAC addresses must be written in lowercase.
PCI device 0x10b7:0x9004 (3c59x)
SUBSYSTEM==“net”, DRIVERS=="?*", ATTRS{address}=="##:##:##:##:##:##", NAME=“lan”
PCI device 0x10ec:0x8029 (ne2k-pci)
SUBSYSTEM==“net”, DRIVERS=="?*", ATTRS{address}=="##:##:##:##:##:##", NAME=“internet”
SUBSYSTEM==“net”, DRIVERS=="?*", ATTRS{address}=="##:##:##:##:##:##", NAME=“dmz”
[/code]Non
