avez vous une solution pour que mon portable puisse détecter le gpu intel 4000
sous debian jessie à jour
Plus précisément ?
Qu’est ce qui ne va pas ?
Que dit lsmod ?
C’est le module i915, qui doit gérer cette carte.
voici les infos
gilles@i5gilles:~$ screenfetch
,met$$$$$gg. gilles@i5gilles
,g$$$$$$$$$$$$$$$P. OS: Debian 8.10 jessie
,g$$P"" “”“Y$$.”. Kernel: x86_64 Linux 3.16.0-4-amd64
,$$P’ $$$. Uptime: 1d 13h 44m ',$$P ,ggs.$$b: Packages: 1830
d$$' ,$P"' . $$$ Shell: bash 4.3.30 $$P d$' , $$P Resolution: 1600x900 $$: $$. - ,d$$' DE: KDE 4.14.2 $$\; Y$b._ _,d$P' WM: KWin Y$$.."Y$$$$P"' WM Theme: Oxygen$$b "-._ GTK Theme: Not Found [GTK2], Not Found [GTK3]
Y$$ Icon Theme: Not FoundY$$. Font: Not Found
$$b. CPU: Intel Core i5-3320M CPU @ 3.3GHzY$$b. RAM: 1733MB / 3665MB
"Y$b._""""
gilles@i5gilles:~$
Module Size Used by
bnep 17431 2
bluetooth 374455 5 bnep
6lowpan_iphc 16588 1 bluetooth
ctr 12927 2
ccm 17577 2
xt_tcpudp 12527 3
ip6t_rpfilter 12468 1
ip6t_REJECT 12468 2
ipt_REJECT 12465 2
xt_conntrack 12681 7
vmnet 50198 13
vmw_vsock_vmci_transport 25909 0
vsock 30772 1 vmw_vsock_vmci_transport
vmw_vmci 55383 1 vmw_vsock_vmci_transport
vmmon 81251 0
ip6table_nat 12649 1
nf_conntrack_ipv6 13605 5
nf_defrag_ipv6 33358 1 nf_conntrack_ipv6
nf_nat_ipv6 12920 1 ip6table_nat
ip6table_mangle 12540 1
ip6table_security 12548 1
ip6table_raw 12528 1
ip6table_filter 12540 1
ip6_tables 25820 5 ip6table_filter,ip6table_mangle,ip6table_security,ip6table_nat,ip6table_raw
iptable_nat 12646 1
nf_conntrack_ipv4 18448 4
nf_defrag_ipv4 12483 1 nf_conntrack_ipv4
nf_nat_ipv4 12912 1 iptable_nat
nf_nat 18241 4 nf_nat_ipv4,nf_nat_ipv6,ip6table_nat,iptable_nat
nf_conntrack 87424 8 nf_nat,nf_nat_ipv4,nf_nat_ipv6,xt_conntrack,ip6table_nat,iptable_nat,nf_conntrack_ipv4,nf_conntrack_ipv6
iptable_mangle 12536 1
iptable_security 12544 1
iptable_raw 12524 1
iptable_filter 12536 1
ip_tables 21711 5 iptable_security,iptable_filter,iptable_mangle,iptable_nat,iptable_raw
x_tables 27399 15 iptable_security,ip6table_filter,ip6table_mangle,ip6t_rpfilter,ip_tables,xt_tcpudp,ip6table_security,xt_conntrack,iptable_filter,ip6table_raw,ipt_REJECT,iptable_mangle,ip6_tables,iptable_raw,ip6t_REJECT
iTCO_wdt 12831 0
iTCO_vendor_support 12649 1 iTCO_wdt
snd_hda_codec_hdmi 45118 1
snd_hda_codec_realtek 67168 1
snd_hda_codec_generic 63181 1 snd_hda_codec_realtek
x86_pkg_temp_thermal 12951 0
intel_powerclamp 17159 0
intel_rapl 17356 0
coretemp 12820 0
arc4 12536 2
kvm 401116 0
crc32_pclmul 12915 0
iwldvm 135156 0
mac80211 494603 1 iwldvm
aesni_intel 151423 4
iwlwifi 96547 1 iwldvm
aes_x86_64 16719 1 aesni_intel
lrw 12757 1 aesni_intel
gf128mul 12970 1 lrw
glue_helper 12695 1 aesni_intel
ablk_helper 12572 1 aesni_intel
cryptd 14516 2 aesni_intel,ablk_helper
joydev 17063 0
evdev 17445 26
serio_raw 12849 0
pcspkr 12595 0
cfg80211 430212 3 iwlwifi,mac80211,iwldvm
lpc_ich 20768 0
snd_hda_intel 26407 3
mfd_core 12601 1 lpc_ich
snd_hda_controller 26646 1 snd_hda_intel
snd_hda_codec 108596 5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
snd_hwdep 13148 1 snd_hda_codec
snd_pcm 88662 4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
shpchp 31121 0
snd_timer 26720 1 snd_pcm
thinkpad_acpi 69119 1
nvram 13034 1 thinkpad_acpi
wmi 17339 0
i915 845471 3
snd 65338 15 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,thinkpad_acpi
soundcore 13026 2 snd,snd_hda_codec
rfkill 18867 5 cfg80211,thinkpad_acpi,bluetooth
battery 17404 0
tpm_tis 17231 0
ac 12715 0
drm_kms_helper 49210 1 i915
tpm 31511 1 tpm_tis
drm 249998 5 i915,drm_kms_helper
mei_me 17941 0
i2c_algo_bit 12751 1 i915
mei 74977 1 mei_me
video 22169 1 i915
button 12909 1 i915
processor 31813 0
fuse 83350 3
parport_pc 26300 0
ppdev 16782 0
lp 17074 0
parport 35749 3 lp,ppdev,parport_pc
autofs4 35529 2
ext4 490301 1
crc16 12343 2 ext4,bluetooth
mbcache 17171 1 ext4
jbd2 82514 1 ext4
sg 29973 0
sd_mod 44412 3
crc_t10dif 12431 1 sd_mod
crct10dif_generic 12581 0
sr_mod 21903 0
cdrom 47424 1 sr_mod
crct10dif_pclmul 13387 1
crct10dif_common 12356 3 crct10dif_pclmul,crct10dif_generic,crc_t10dif
crc32c_intel 21809 0
psmouse 103345 0
i2c_i801 16965 0
i2c_core 46012 5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
ahci 33334 2
libahci 27158 1 ahci
ehci_pci 12512 0
xhci_hcd 153036 0
libata 177500 2 ahci,libahci
ehci_hcd 69837 1 ehci_pci
sdhci_pci 22097 0
sdhci 35161 1 sdhci_pci
scsi_mod 191405 4 sg,libata,sd_mod,sr_mod
mmc_core 102374 2 sdhci,sdhci_pci
e1000e 212170 0
ptp 17692 1 e1000e
usbcore 195468 3 ehci_hcd,ehci_pci,xhci_hcd
pps_core 17225 1 ptp
thermal 17516 0
usb_common 12440 1 usbcore
thermal_sys 27642 5 video,intel_powerclamp,thermal,processor,x86_pkg_temp_thermal
Architecture : x86_64
Mode(s) opératoire(s) des processeurs : 32-bit, 64-bit
Boutisme : Little Endian
Processeur(s) : 4
Liste de processeur(s) en ligne : 0-3
Thread(s) par cœur : 2
Cœur(s) par socket : 2
Socket(s) : 1
Nœud(s) NUMA : 1
Identifiant constructeur : GenuineIntel
Famille de processeur : 6
Modèle : 58
Nom de modèle : Intel® Core™ i5-3320M CPU @ 2.60GHz
Révision : 9
Vitesse du processeur en MHz : 1265.367
Vitesse maximale du processeur en MHz : 3300,0000
Vitesse minimale du processeur en MHz : 1200,0000
BogoMIPS : 5188.40
Virtualisation : VT-x
Cache L1d : 32K
Cache L1i : 32K
Cache L2 : 256K
Cache L3 : 3072K
Nœud NUMA 0 de processeur(s) : 0-3
Je confirme :
jacques@jacques-t430:~$ lspci -nnk |grep -A 2 -i graphics 00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09) Subsystem: Lenovo Device [17aa:21f3] Kernel driver in use: i915
Qu’est-ce qui te fais penser qu’il y a un problème ?
Merci.
De ce que je vois, le module i915 est bien chargé.
Je ne sais pas si ton problème est réglé, vu que tu ne dis toujours pas ce qui plante ni où, mais il n’y a pas de problème de détection de ta carte, en tous cas.
