Bonjour.
Depuis le noyau 2.6.37 , les ports usb ne marchent plus. J’espérais une amélioration avec le 38, mais en vain.
Voici ce que me dis le système :
dmesg | grep -i usb
[ 4.170950] usbcore: registered new interface driver usbfs
[ 4.171230] usbcore: registered new interface driver hub
[ 4.175032] usbcore: registered new device driver usb
[ 4.177888] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.178033] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 4.196122] ehci_hcd 0000:00:12.2: applying AMD SB600/SB700 USB freeze workaround
[ 4.219938] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.220159] ehci_hcd 0000:00:12.2: USB bus 1 deregistered
[ 4.236511] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 1
[ 4.248317] ehci_hcd 0000:00:13.2: applying AMD SB600/SB700 USB freeze workaround
[ 4.272351] ehci_hcd 0000:00:13.2: USB bus 1 deregistered
[ 4.292423] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 1
[ 12.304254] ohci_hcd 0000:00:12.0: USB HC takeover failed! (BIOS/SMM bug)
[ 12.304361] ohci_hcd 0000:00:12.0: USB bus 1 deregistered
[ 12.320396] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 1
[ 20.320259] ohci_hcd 0000:00:12.1: USB HC takeover failed! (BIOS/SMM bug)
[ 20.320366] ohci_hcd 0000:00:12.1: USB bus 1 deregistered
[ 20.336421] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 1
[ 28.352251] ohci_hcd 0000:00:13.0: USB HC takeover failed! (BIOS/SMM bug)
[ 28.352352] ohci_hcd 0000:00:13.0: USB bus 1 deregistered
[ 28.368373] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 1
[ 36.380253] ohci_hcd 0000:00:13.1: USB HC takeover failed! (BIOS/SMM bug)
[ 36.380358] ohci_hcd 0000:00:13.1: USB bus 1 deregistered
Les sujets en lien que j’ai trouvé sur la toile ne parlent que de recompiler le noyau, chose que je ne sais pas faire et que j’aimerais autant éviter…
Des idées?
. PArce que là, j’en ai marre
