suite à mon post concernant webrtc sur firefox j’ai essayé linphone dans mes recherches pour remplacer skype,mais quand je lance linphone en ligne de commande j’ai le message erreurs suivant:
[code]marc@debian:~$ linphone
(linphone:5107): Gtk-WARNING **: Could not find signal handler 'linphone_gtk_display_wizard’
ALSA lib conf.c:4687:(snd_config_expand) Unknown parameters 0
ALSA lib control.c:951:(snd_ctl_open_noupdate) Invalid CTL default:0
[NULL @ 0xbfce3fdc] Value 4686111960511545344,000000 for parameter ‘b’ out of range
[NULL @ 0xbfce3fdc] Value 4683532506232782848,000000 for parameter ‘ab’ out of range
[NULL @ 0xbfce3fdc] Value 4705844345939427328,000000 for parameter ‘bt’ out of range
[NULL @ 0xbfce3fdc] Value 4617315517961601024,000000 for parameter ‘me_method’ out of range
[NULL @ 0xbfce3fdc] Value 4622945017495814144,000000 for parameter ‘g’ out of range
[NULL @ 0xbfce3fdc] Value 4611686018427387904,000000 for parameter ‘qmin’ out of range
[NULL @ 0xbfce3fdc] Value 4629418941960159232,000000 for parameter ‘qmax’ out of range
[NULL @ 0xbfce3fdc] Value 4613937818241073152,000000 for parameter ‘qdiff’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘wpredp’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘bug’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘er’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘err_detect’ out of range
[NULL @ 0xbfce3fdc] Value 4613937818241073152,000000 for parameter ‘ec’ out of range
[NULL @ 0xbfce3fdc] Value 4620693217682128896,000000 for parameter ‘ildctcmp’ out of range
[NULL @ 0xbfce3fdc] Value 4620693217682128896,000000 for parameter ‘subq’ out of range
[NULL @ 0xbfce3fdc] Value 4696837138094751744,000000 for parameter ‘ibias’ out of range
[NULL @ 0xbfce3fdc] Value 4696837138094751744,000000 for parameter ‘pbias’ out of range
[NULL @ 0xbfce3fdc] Value 4642507528377204736,000000 for parameter ‘lmin’ out of range
[NULL @ 0xbfce3fdc] Value 4660262442142531584,000000 for parameter ‘lmax’ out of range
[NULL @ 0xbfce3fdc] Value 4696130710463840256,000000 for parameter ‘flags2’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘threads’ out of range
[NULL @ 0xbfce3fdc] Value 4620693217682128896,000000 for parameter ‘nssew’ out of range
[NULL @ 0xbfce3fdc] Value -4586705114244317184,000000 for parameter ‘profile’ out of range
[NULL @ 0xbfce3fdc] Value -4586705114244317184,000000 for parameter ‘level’ out of range
[NULL @ 0xbfce3fdc] Value 4623507967449235456,000000 for parameter ‘skipcmp’ out of range
[NULL @ 0xbfce3fdc] Value 4642507528377204736,000000 for parameter ‘mblmin’ out of range
[NULL @ 0xbfce3fdc] Value 4660262442142531584,000000 for parameter ‘mblmax’ out of range
[NULL @ 0xbfce3fdc] Value 4643211215818981376,000000 for parameter ‘mepc’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘bidir_refine’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘cqp’ out of range
[NULL @ 0xbfce3fdc] Value 4627730092099895296,000000 for parameter ‘keyint_min’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘refs’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘directpred’ out of range
[NULL @ 0xbfce3fdc] Value 4618441417868443648,000000 for parameter ‘sc_factor’ out of range
[NULL @ 0xbfce3fdc] Value 4643211215818981376,000000 for parameter ‘mv0_threshold’ out of range
[NULL @ 0xbfce3fdc] Value 4630826316843712512,000000 for parameter ‘b_sensitivity’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘compression_level’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘min_prediction_order’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘max_prediction_order’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘prediction_order_method’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘min_partition_order’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘max_partition_order’ out of range
[NULL @ 0xbfce3fdc] Value 4607182418800017408,000000 for parameter ‘ticks_per_frame’ out of range
[NULL @ 0xbfce3fdc] Value 4611686018427387904,000000 for parameter ‘color_primaries’ out of range
[NULL @ 0xbfce3fdc] Value 4611686018427387904,000000 for parameter ‘color_trc’ out of range
[NULL @ 0xbfce3fdc] Value 4611686018427387904,000000 for parameter ‘colorspace’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘aq_mode’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘rc_lookahead’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘lpc_type’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘lpc_passes’ out of range
[NULL @ 0xbfce3fdc] Value 4613937818241073152,000000 for parameter ‘thread_type’ out of range
[NULL @ 0xbfce3fdc] Value -4616189618054758400,000000 for parameter ‘request_sample_fmt’ out of range
[swscaler @ 0x9608900] Warning: data is not aligned! This can lead to a speedloss
Erreur de segmentation
marc@debian:~$
c’est chez moi que ça déconne ou c’est un bug?
