Je viens de supprimer tout le contenu du répertoire /home/user/.cache/sessions/ et redémarer mais rien ne change, un fichier nommé xfce4-session-debian:1 vient d’apparaître avec plusieurs propriétées.
Et j’ai le fichier .xsession-errors avec de nouvelles choses:
[code]localuser:user being added to access control list
openConnection: connect: Aucun fichier ou dossier de ce type
cannot connect to brltty at :0
/usr/bin/x-session-manager: X server already running on display :1
xfce4-session-Message: ssh-agent is already running; starting gpg-agent without ssh support
vmware-user: could not open /proc/fs/vmblock/dev
(nm-applet:2194): libnm-glib-CRITICAL **: nm_secret_agent_register: assertion ‘priv->registered == FALSE’ failed
** (wrapper:2220): WARNING **: Binding ‘XF86AudioLowerVolume’ failed!
** (wrapper:2220): WARNING **: Binding ‘XF86AudioRaiseVolume’ failed!
** (wrapper:2220): WARNING **: Binding ‘XF86AudioMute’ failed!
(Thunar:2186): GLib-CRITICAL **: Source ID 2607 was not found when attempting to remove it
(Thunar:2186): GLib-CRITICAL **: Source ID 2989 was not found when attempting to remove it
(Thunar:2186): GLib-CRITICAL **: Source ID 30809 was not found when attempting to remove it
(Thunar:2186): GLib-CRITICAL **: Source ID 30952 was not found when attempting to remove it
(gedit:2517): Gtk-WARNING **: Calling Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
(xfce4-panel:2187): GLib-WARNING **: GChildWatchSource: Exit status of a child process was requested but ECHILD was received by waitpid(). Most likely the process is ignoring SIGCHLD, or some other thread is invoking waitpid() with a nonpositive first argument; either behavior can break applications that use g_child_watch_add()/g_spawn_sync() either directly or indirectly.
xscreensaver: 23:55:55: SIGHUP received: restarting…
xscreensaver: 23:55:55: running as user/user (1000/1000)
xfsettingsd: Fatal IO error 11 (Ressource temporairement non disponible) on X server :1.0.
Xsession: X session started for user at mardi 29 décembre 2015, 03:47:55 (UTC+0000)
** (wrapper:2194): WARNING **: Binding ‘XF86AudioLowerVolume’ failed!
** (wrapper:2194): WARNING **: Binding ‘XF86AudioRaiseVolume’ failed!
** (wrapper:2194): WARNING **: Binding ‘XF86AudioMute’ failed!
(nm-applet:2172): libnm-glib-CRITICAL **: nm_secret_agent_register: assertion ‘priv->registered == FALSE’ failed
(xfce4-terminal:2334): GLib-WARNING **: (/tmp/buildd/glib2.0-2.42.1/./glib/gerror.c:381):g_error_new_valist: runtime check failed: (domain != 0)
Failed to connect to session manager: Échec de connexion au gestionnaire de session : SESSION_MANAGER environment variable not defined
Xsession: X session started for user at mardi 29 décembre 2015, 03:53:36 (UTC+0000)
** (wrapper:2236): WARNING **: Binding ‘XF86AudioLowerVolume’ failed!
** (wrapper:2236): WARNING **: Binding ‘XF86AudioRaiseVolume’ failed!
** (wrapper:2236): WARNING **: Binding ‘XF86AudioMute’ failed!
(nm-applet:2213): libnm-glib-CRITICAL **: nm_secret_agent_register: assertion ‘priv->registered == FALSE’ failed
(Thunar:2205): GLib-CRITICAL **: Source ID 2108 was not found when attempting to remove it
(Thunar:2205): GLib-CRITICAL **: Source ID 2450 was not found when attempting to remove it
