J’ai une CM intel 5000VSA et j’aimerais savoir la T de mes pross et les vitesses des ventilos.
Voici mes manips:
[code]ATAL: Module i2c_sensor not found.
srvdebian:~# cd /proc/acpi/thermal_zone/
srvdebian:/proc/acpi/thermal_zone# ls
srvdebian:/proc/acpi/thermal_zone# modprobe bmcsensors
FATAL: Module bmcsensors not found.
srvdebian:/proc/acpi/thermal_zone# sensors-detect
sensors-detect revision 4171 (2006-09-24 03:37:01 -0700)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you’re doing.
We can start with probing for (PCI) I2C or SMBus adapters.
Do you want to probe now? (YES/no):
Probing for PCI bus adapters…
Use driver `i2c-i801’ for device 0000:00:1f.3: Intel Enterprise Southbridge - ES B2
We will now try to load each adapter module in turn.
Module `i2c-i801’ already loaded.
If you have undetectable or unsupported adapters, you can have them
scanned by manually loading the modules before running this script.
To continue, we need module i2c-dev' to be loaded. Do you want to loadi2c-dev’ now? (YES/no):
Module loaded successfully.
We are now going to do the I2C/SMBus adapter probings. Some chips may
be double detected; we choose the one with the highest confidence
value in that case.
If you found that the adapter hung after probing a certain address,
you can specify that address to remain unprobed.
Next adapter: bt878 #0 [sw]
Do you want to scan it? (YES/no/selectively):
Client found at address 0x50
Handled by driver tveeprom' (already loaded), chip typetveeprom’
(note: this is probably NOT a sensor chip!)
Client found at address 0x51
Handled by driver eeprom' (already loaded), chip typeeeprom’
Client found at address 0x52
Client found at address 0x53
Client found at address 0x60
Handled by driver tuner' (already loaded), chip typePhilips (SECAM+PAL_BG) (F I1216MF, FM1216MF, FR121’
Next adapter: SMBus I801 adapter at 3000
Some chips are also accessible through the ISA I/O ports. We have to
write to arbitrary I/O ports to probe them. This is usually safe though.
Yes, you do have ISA I/O ports even if you do not have any ISA slots!
Do you want to scan the ISA I/O ports? (YES/no):
Probing for National Semiconductor LM78' at 0x290... No Probing forNational Semiconductor LM78-J’ at 0x290… No
Probing for National Semiconductor LM79' at 0x290... No Probing forWinbond W83781D’ at 0x290… No
Probing for Winbond W83782D' at 0x290... No Probing forWinbond W83627HF’ at 0x290… No
Probing for Silicon Integrated Systems SIS5595'... No Probing forVIA VT82C686 Integrated Sensors’… No
Probing for VIA VT8231 Integrated Sensors'... No Probing forAMD K8 thermal sensors’… No
Probing for IPMI BMC KCS' at 0xca0... Success! (confidence 4, driverbmcsensors’)
Probing for `IPMI BMC SMIC’ at 0xca8… No
Some Super I/O chips may also contain sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family ITE'... Yes Found unknown chip with ID 0xf211 Trying familyNational Semiconductor’… Yes
Found Nat. Semi. PC87427 Super IO Fan Sensors' (but not activated) FoundNat. Semi. PC87427 Super IO Health Sensors’
(but not activated)
Trying family SMSC'... Yes Found unknown chip with ID 0xf211 Trying familyVIA/Winbond/Fintek’… Yes
Probing for Super-I/O at 0x4e/0x4f
Trying family ITE'... No Trying familyNational Semiconductor’… No
Trying family SMSC'... No Trying familyVIA/Winbond/Fintek’… No
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `eeprom’ (should be inserted):
Detects correctly:
- Bus
bt878 #0 [sw]' BusdriverUNKNOWN’, I2C address 0x51
Chip `eeprom’ (confidence: 6) - Bus
bt878 #0 [sw]' BusdriverUNKNOWN’, I2C address 0x52
bt878 #0 [sw]' BusdriverUNKNOWN’, I2C address 0x53
EEPROMs are NOT sensors! They are data storage chips commonly
found on memory modules (SPD), in monitors (EDID), or in some
laptops, for example.
Driver `bmcsensors’ (should be inserted):
Detects correctly:
- ISA bus address 0x0ca0 (Busdriver
i2c-isa') ChipIPMI BMC KCS’ (confidence: 4)
I will now generate the commands needed to load the required modules.
To make the sensors modules behave correctly, add these lines to
/etc/modules:
#----cut here----
I2C adapter drivers
modprobe unknown adapter bt878 #0 [sw]
You must also install and load the IPMI modules
i2c-ipmi
Chip drivers
eeprom
Warning: the required module bmcsensors is not currently installed
on your system. For status of 2.6 kernel ports check
http://www.lm-sensors.org/wiki/Devices. If driver is built
into the kernel, or unavailable, comment out the following line.
bmcsensors
#----cut here----
Do you want to add these lines to /etc/modules automatically? (yes/NO)
No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
Je crois que ma CM et sensors ne s’entendent pas trop.
Existe il autre chose
