voici le résultat des commandes :
fdisk -l
Disk /dev/cciss/c0d0: 146.8 GB, 146778685440 bytes
255 heads, 32 sectors/track, 35132 cylinders
Units = cylinders of 8160 * 512 = 4177920 bytes
Disk identifier: 0x000290ec
/dev/cciss/c0d0p1 * 1 62 248832 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/cciss/c0d0p2 62 35132 143087617 5 Extended
Partition 2 does not end on cylinder boundary.
/dev/cciss/c0d0p5 62 35132 143087616 8e Linux LVM
WARNING: GPT (GUID Partition Table) detected on ‘/dev/cciss/c0d1’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/cciss/c0d1: 900.1 GB, 900129153024 bytes
255 heads, 63 sectors/track, 109434 cylinders
Disk identifier: 0x00000000
/dev/cciss/c0d1p1 1 109435 879032375+ ee GPT
Disk /dev/dm-0: 3988 MB, 3988783104 bytes
255 heads, 63 sectors/track, 484 cylinders
Disk /dev/dm-0 doesn’t contain a valid partition table
Disk /dev/dm-1: 7251 MB, 7251951616 bytes
255 heads, 63 sectors/track, 881 cylinders
Disk /dev/dm-1 doesn’t contain a valid partition table
Disk /dev/dm-2: 439.9 GB, 439911186432 bytes
255 heads, 63 sectors/track, 53482 cylinders
Disk /dev/dm-2 doesn’t contain a valid partition table
Disk /dev/dm-3: 8996 MB, 8996782080 bytes
255 heads, 63 sectors/track, 1093 cylinders
Disk /dev/dm-3 doesn’t contain a valid partition table
Disk /dev/dm-4: 2998 MB, 2998927360 bytes
255 heads, 63 sectors/track, 364 cylinders
Disk /dev/dm-4 doesn’t contain a valid partition table
Disk /dev/dm-5: 5725 MB, 5725224960 bytes
255 heads, 63 sectors/track, 696 cylinders
Disk /dev/dm-5 doesn’t contain a valid partition table
pvdisplay
Incorrect metadata area header checksum
— Physical volume —
PV Name /dev/block/104:17
VG Name dataticea
PV Size 838,31 GiB / not usable 2,02 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 214607
Free PE 109724
Allocated PE 104883
PV UUID 9mXvs0-2NBD-Cw03-WhS4-mvUI-WlKK-uhP5Sy
— Physical volume —
PV Name /dev/block/104:5
VG Name icea
PV Size 136,46 GiB / not usable 2,00 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 34933
Free PE 28028
Allocated PE 6905
PV UUID bis0mh-XUAj-tLXy-Qgv2-8VKF-Nxg1-VtFUvu
“/dev/block/104:1” is a new physical volume of “136,70 GiB”
— NEW Physical volume —
VG Name
PV Size 136,70 GiB
Allocatable NO
PE Size 0
Total PE 0
Free PE 0
Allocated PE 0
PV UUID f7hXXT-zES0-sWNm-ZxlF-TcW4-l49z-iFQjdk
vgdisplay
— Volume group —
VG Name dataticea
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 4
VG Access read/write
VG Status resizable
MAX LV 256
Cur LV 1
Open LV 1
Max PV 256
Cur PV 1
Act PV 1
VG Size 838,31 GiB
PE Size 4,00 MiB
Total PE 214607
Alloc PE / Size 104883 / 409,70 GiB
Free PE / Size 109724 / 428,61 GiB
VG UUID CozfZd-4X71-02et-LxYF-UhIs-KQQ0-MrtiMJ
— Volume group —
VG Name icea
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 11
VG Status resizable
MAX LV 0
Cur LV 5
Open LV 5
Max PV 0
Cur PV 1
Act PV 1
VG Size 136,46 GiB
PE Size 4,00 MiB
Total PE 34933
Alloc PE / Size 6905 / 26,97 GiB
Free PE / Size 28028 / 109,48 GiB
VG UUID LMAagA-OjHY-1Rj7-l2Pt-aptR-vIqn-397yNR
lvdisplay
— Logical volume —
LV Name /dev/dataticea/testlv
VG Name dataticea
LV UUID 47DDDI-kqSU-pOvh-2Rls-u4zQ-gLFF-2mv7Cz
LV Write Access read/write
LV Status available
open 1
LV Size 409,70 GiB
Current LE 104883
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 254:2
— Logical volume —
LV Name /dev/icea/root
VG Name icea
LV UUID v22Q1r-jDyJ-hCQd-6FgF-1nE2-2QvH-cvMAYd
LV Status available
open 1
LV Size 3,71 GiB
Current LE 951
Segments 2
Allocation inherit
Block device 254:0
— Logical volume —
LV Name /dev/icea/usr
VG Name icea
LV UUID MLB63V-jICq-0VPX-xRf6-ObBg-HDPu-lnPXvk
LV Status available
open 1
LV Size 8,38 GiB
Current LE 2145
Segments 1
Allocation inherit
Block device 254:3
— Logical volume —
LV Name /dev/icea/var
VG Name icea
LV UUID ZXQvr3-w1Vz-t8kU-6yTA-AwhW-yTQY-QHUwZ1
LV Status available
open 1
LV Size 2,79 GiB
Current LE 715
Segments 1
Allocation inherit
Block device 254:4
— Logical volume —
LV Name /dev/icea/swap_1
VG Name icea
LV UUID pMf1jG-FfoG-nZ0Q-EjR0-WW1x-wODN-7UUxHQ
LV Status available
open 1
LV Size 6,75 GiB
Current LE 1729
Segments 1
Allocation inherit
Block device 254:1
— Logical volume —
LV Name /dev/icea/tmp
VG Name icea
LV UUID bPSRaH-t1mZ-p6sn-8Qmn-tpoH-7kbp-FvNr5o
LV Status available
open 1
LV Size 5,33 GiB
Current LE 1365
Segments 1
Allocation inherit
Block device 254:5
cat /etc/fstab
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
proc /proc proc defaults 0 0
/dev/mapper/icea-root / ext3 errors=remount-ro 0 1
/boot was on /dev/cciss/c0d0p1 during installation
UUID=f7hXXT-zES0-sWNm-ZxlF-TcW4-l49z-iFQjdk /boot ext2 defaults 0 2
#/dev/mapper/icea-home /home ext3 defaults 0 2
/dev/mapper/icea-tmp /tmp ext3 defaults 0 2
/dev/mapper/icea-usr /usr ext3 defaults 0 2
/dev/mapper/icea-var /var ext3 defaults 0 2
/dev/mapper/icea-swap_1 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/dataticea/testlv /home ext3 defaults 0 2
dans pvdisplay, on voit le 3 ième disque qui n’appartient à aucun VG
Je vais vérifier le matériel , à part megacli il y en d’autres ? car megacli ne fait pas parti de la distrib squeeze ?
