J’ai un petit problème d’envoi de mail avec postfix qui est configuré par iredmail.
Voici les logs de mail.
Je pense que cela viens de clamav mais pas sur.
Avez- vous une piste ?
Mar 15 19:12:37 srv-home postfix-policyd: connecting to mysql database: 127.0.0.1
Mar 15 19:12:37 srv-home postfix-policyd: connected..
Mar 15 19:12:55 srv-home postfix/smtpd[3088]: connect from localhost[127.0.0.1]
Mar 15 19:12:55 srv-home postfix/trivial-rewrite[3090]: warning: do not list domain srv-home.fr in BOTH mydestination and virtual_mailbox_domains
Mar 15 19:12:55 srv-home postfix/smtpd[3088]: 8548E2BE248: client=localhost[127.0.0.1], sasl_method=LOGIN, sasl_username=www@srv-home.fr
Mar 15 19:12:55 srv-home postfix/cleanup[3096]: 8548E2BE248: message-id=<2d245a019d8f77e1ffd284384491081b@srv-home.fr>
Mar 15 19:12:55 srv-home postfix/qmgr[2962]: 8548E2BE248: from=<www@srv-home.fr>, size=515, nrcpt=1 (queue active)
Mar 15 19:12:55 srv-home roundcube: User www@srv-home.fr [192.168.0.4]; Message for prohand20@gmail.com; 250: 2.0.0 Ok: queued as 8548E2BE248
Mar 15 19:12:55 srv-home postfix/smtpd[3088]: disconnect from localhost[127.0.0.1]
Mar 15 19:12:56 srv-home amavis[2828]: (02828-01) (!)ClamAV-clamd: Can't connect to UNIX socket /tmp/clamd.socket: 2, retrying (2)
Mar 15 19:13:02 srv-home amavis[2828]: (02828-01) (!)ClamAV-clamd av-scanner FAILED: run_av error: Too many retries to talk to /tmp/clamd.socket (Can't connect to UNIX socket /tmp/clamd.socket: No$
Mar 15 19:13:02 srv-home amavis[2828]: (02828-01) (!!)WARN: all primary virus scanners failed, considering backups
Mar 15 19:13:03 srv-home amavis[2828]: (02828-01) (!)run_av (ClamAV-clamscan) FAILED - unexpected exit 2, output="WARNING: Ignoring deprecated option --disable-summary\nERROR: Option --tempdir req$
Mar 15 19:13:03 srv-home amavis[2828]: (02828-01) (!)ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan unexpected exit 2, output="WARNING: Ignoring deprecated option --disable-summary\nERROR: O$
Mar 15 19:13:03 srv-home amavis[2828]: (02828-01) (!!)TROUBLE in check_mail: virus_scan FAILED: AV: ALL VIRUS SCANNERS FAILED
Mar 15 19:13:03 srv-home amavis[2828]: (02828-01) (!)PRESERVING EVIDENCE in /var/lib/amavis/tmp/amavis-20110315T191255-02828
$.0.0.1[127.0.0.1] said: 451 4.5.0 Error in processing, id=02828-01, virus_scan FAILED: AV: ALL VIRUS SCANNERS FAILED (in reply to end of DATA command))
