Actuelement sous aptitude, un paquet bloque les màj, il concerne virtualbox dont voici le retour:
[quote]dpkg-query: parse error, in file ‘/var/lib/dpkg/status’ near line 7410 package ‘virtualbox’:
error in Version string 1.6.6-35336_Debian_lenny': invalid character in revision number dpkg: parse error, in file '/var/lib/dpkg/status' near line 7410 package 'virtualbox': error in Version string1.6.6-35336_Debian_lenny’: invalid character in revision number
E: Sub-process /usr/bin/dpkg returned an error code (2)
A package failed to install. Trying to recover:
dpkg: parse error, in file ‘/var/lib/dpkg/status’ near line 7410 package ‘virtualbox’:
error in Version string `1.6.6-35336_Debian_lenny’: invalid character in revision number[/quote]
Je suis allé voir le fichier /var/lib/dpkg/status à la ligne 7410: (la ligne 7410 en en gras)
[quote]Package: virtualbox
Status: install ok installed
Priority: optional
Section: misc
Installed-Size: 55120
Maintainer: Sun Microsystems, Inc. info@virtualbox.org
Architecture: amd64
Version: 1.6.6-35336_Debian_lenny
Config-Version: 1.6.6-35336_Debian_lenny
Depends: libc6 (>= 2.7-1), libgcc1 (>= 1:4.1.1), libglib2.0-0 (>= 2.12.0), libidl0, libqt3-mt (>= 3:3.3.8b), libsdl1.2debian (>= 1.2.10-1), libssl0.9.8 (>= 0.9.8f-5), libstdc++6 (>= 4.2.1), libx11-6, libxcursor1 (>> 1.1.2), libxml2 (>= 2.6.27), libxslt1.1 (>= 1.1.18), libxt6, psmisc, adduser
Pre-Depends: debconf (>= 1.1) | debconf-2.0
Recommends: libasound2, libpulse0, libsdl-ttf2.0-0, linux-headers, gcc, make, binutils, bridge-utils, uml-utilities, libhal1 (>= 0.5), pdf-viewer
Conffiles:
/etc/init.d/vboxnet 350fa9e6723b4fabbadf7874fdc70d67
/etc/init.d/vboxdrv 6e3cb8dd230d768740ce0c6e0ae6a86c
Description: Sun xVM VirtualBox
VirtualBox is a powerful PC virtualization solution allowing you to run a
wide range of PC operating systems on your Linux system. This includes
Windows, Linux, FreeBSD, DOS, OpenBSD and others. VirtualBox comes with a broad
feature set and excellent performance, making it the premier virtualization
software solution on the market.[/quote]
J’ai tenté des --reconfigure, remove -f virtualbox voir installer le .deb de la version 3.2 (je suis en 3.1), rien n’a fonctionné, j’ai toujours ce message qui me revient.
Du coup, toutes mes màj sont bloquées, auriez-vous une idée qui permettrait un blocage du bazard, svp?
Cordialement
