Major rsync upgrade in Debian because of 33 CVEs
Salut, ça faisait plusieurs mois que j’avais pas fait un apt upgrade et pour la première fois de ma vie, je vois un message qui apparaît lors de l’installation des paquets. il s’agit d’un avertissement concernant rsync.
J’aimerais donc savoir ce que dit ce message et pourquoi il mérite un avertissement lors de l’installation du paquet
si je ne me trompe pas, il s’agit de ce message que j’ai retrouvé sur le site lobsters
apt-listchanges --which=both -f text --since=3.4.1+ds1-5+deb13u4
/var/cache/apt/archives/rsync_3.5.0+ds1-0+deb13u1_amd64.deb apt-listchanges: Reading changelogs… apt-listchanges: News
rsync (3.5.0+ds1-0+deb13u1) trixie-security; urgency=medium
In order to fix 33 CVEs, I have decided to bump the package to 3.5.0 rather than backporting all patches individually. After analysing the extra changes from the bump, not included in the CVE fixes, I have concluded this approach carries the lower amount of risk compared to the alternative.
This update contains behavior changes, all of which stems from the CVE fixes themselves, not exclusive to the version bump. The ones most likely to break an existing setup are listed here; /usr/share/doc/rsync/NEWS.md.gz has the full list.
Operator-supplied paths are no longer followed through untrusted symlinks. The destination directory and the arguments to --backup-dir, --temp-dir, --partial-dir, --link-dest, --compare-dest, --copy-dest, --log-file, --password-file, --files-from, --include-from, --exclude-from, --write-batch, --read-batch and --filter merge files are now resolved one component at a time, following a symlink only when it is owned by root or by the user running rsync; one owned by anyone else is refused with « refusing to follow a symlink owned by an untrusted user ». --insecure-links restores the old behaviour, but it is local only and a daemon never honours it. For a single trusted module, set « insecure links = yes » in that module instead.
rrsync now refuses --debug on every invocation. When restricted to a subdirectory it additionally denies --copy-unsafe-links, passes the new --confine-root so the server will not resolve a client-named filter merge file outside that directory, and passes --drop-D when receiving, so an upload can no longer create devices or special files there (« skipping non-regular file »). A plain « rsync -a » otherwise still works.
--chmod=a+s now sets both the setuid and setgid bits, matching chmod(1); it previously set setuid alone.
rsyncd changes that can change who gets in:
  • « proxy protocol = true » without « proxy protocol hosts » now rejects every connection and warns at startup, instead of trusting a client-supplied PROXY header.
  • « hosts deny » now fails closed when a configured hostname cannot be resolved (with « forward lookup », the default), so a host previously admitted by an unresolvable deny entry is now blocked.
  • « auth users » values that start with a comma now split on commas alone, as documented, so a deny or :ro rule naming a group whose name contains a space now takes effect where it was silently ignored.
  • « hosts allow » / « hosts deny » patterns now fold case inside a […] bracket expression as well, so a rule such as [A-Z]* matches hosts it used to miss.
  • A client-requested --compress-threads is capped at 8.
rsync-ssl now verifies the server certificate. The default openssl backend additionally binds it to the requested hostname, so a certificate valid for some other name is now rejected. The stunnel and gnutls backends refuse to run unless RSYNC_SSL_CA_CERT is set, or RSYNC_SSL_ALLOW_INSECURE_STUNNEL=1 / RSYNC_SSL_ALLOW_INSECURE_GNUTLS=1 is set to opt out.
