Ton pager ne serait-il pas [mono]more[/mono] au lieu de [mono]less[/mono] ?
$ man man
[code] -P pager, --pager=pager
Specify which output pager to use. By default, man uses pager -s. This option overrides the $MANPAGER environment variable, which in
turn overrides the $PAGER environment variable. It is not used in conjunction with -f or -k.
The value may be a simple command name or a command with arguments, and may use shell quoting (backslashes, single quotes, or double
quotes). It may not use pipes to connect multiple commands; if you need that, use a wrapper script, which may take the file to display
either as an argument or on standard input.[/code]
Exemple en précisant le pager [mono]less[/mono] pour consulter le manuel de [mono]more[/mono] :
$ man -P less more
[code]
COMMANDS
Interactive commands for more are based on vi(1). Some commands may be preceded by a decimal number, called k in the descriptions below. In the
following descriptions, ^X means control-X.
h or ? Help: display a summary of these commands. If you forget all the other commands, remember this one.
SPACE Display next k lines of text. Defaults to current screen size.
z Display next k lines of text. Defaults to current screen size. Argument becomes new default.
RETURN Display next k lines of text. Defaults to 1. Argument becomes new default.
d or ^D Scroll k lines. Default is current scroll size, initially 11. Argument becomes new default.
q or Q or INTERRUPT
Exit.
s Skip forward k lines of text. Defaults to 1.
f Skip forward k screenfuls of text. Defaults to 1.
b or ^B Skip backwards k screenfuls of text. Defaults to 1. Only works with files, not pipes.
' Go to place where previous search started.
= Display current line number.
/pattern Search for kth occurrence of regular expression. Defaults to 1.
n Search for kth occurrence of last r.e. Defaults to 1.[/code]
Remarque que le contrôle B ne passe pas partout («Only works with files, not pipes »).
