Bonjour à tous!
Je ne suis pas certains de moi mais je pense avoir trouvé un bug dans le script de démarrage de mariadb 10 en configuration galera cluster
Ici je veux démarrer un nouveau cluster (étape de création)
voici le résultat de quelques commande et les logs
service mysql stop
service mysql start --wsrep-new-cluster
Job for mysql.service failed. See ‘systemctl status mysql.service’ and ‘journalctl -xn’ for details.
#cat /var/log/syslog
ul 2 09:50:52 debian-OSimage mysqld: 150702 9:50:52 [Note] WSREP: gcomm: connecting to group 'db_wordpress', peer '192.168.8.10:,192.168.8.11:,192.168.8.12:'
Jul 2 09:50:52 debian-OSimage mysqld: 150702 9:50:52 [Warning] WSREP: (0fe9ad31, 'tcp://0.0.0.0:4567') address 'tcp://192.168.8.12:4567' points to own listening address, blacklisting
Jul 2 09:50:55 debian-OSimage mysqld: 150702 9:50:55 [Warning] WSREP: no nodes coming from prim view, prim not possible
Jul 2 09:50:55 debian-OSimage mysqld: 150702 9:50:55 [Note] WSREP: view(view_id(NON_PRIM,0fe9ad31,1) memb {
Jul 2 09:50:55 debian-OSimage mysqld: #0110fe9ad31,0
Jul 2 09:50:55 debian-OSimage mysqld: } joined {
Jul 2 09:50:55 debian-OSimage mysqld: } left {
Jul 2 09:50:55 debian-OSimage mysqld: } partitioned {
Jul 2 09:50:55 debian-OSimage mysqld: })
Jul 2 09:50:56 debian-OSimage mysqld: 150702 9:50:56 [Warning] WSREP: last inactive check more than PT1.5S ago (PT3.87359S), skipping check
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [Note] WSREP: view((empty))
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [ERROR] WSREP: failed to open gcomm backend connection: 110: failed to reach primary view: 110 (Connection timed out)
Jul 2 09:51:26 debian-OSimage mysqld: #011 at gcomm/src/pc.cpp:connect():161
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [ERROR] WSREP: gcs/src/gcs_core.cpp:long int gcs_core_open(gcs_core_t*, const char*, const char*, bool)():206: Failed to open backend connection: -110 (Connection timed out)
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [ERROR] WSREP: gcs/src/gcs.cpp:long int gcs_open(gcs_conn_t*, const char*, const char*, bool)():1379: Failed to open channel 'db_wordpress' at 'gcomm://192.168.8.10,192.168.8.11,192.168.8.12': -110 (Connection timed out)
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [ERROR] WSREP: gcs connect failed: Connection timed out
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [ERROR] WSREP: wsrep::connect() failed: 7
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [ERROR] Aborting
Jul 2 09:51:26 debian-OSimage mysqld: 150702 9:51:26 [Note] WSREP: Service disconnected.
on voit ici que le serveur cherche à se connecter à un cluster éxistant
ce qu’il ne devrait pas faire du tout! (avec l’option --wsrep-new-cluster)
test en direct avec le binaire:
#mysqld --wsrep-new-cluster
150702 10:50:20 [Note] mysqld (mysqld 10.0.20-MariaDB-1~jessie-wsrep-log) starting as process 6763 ...
150702 10:50:20 [Note] WSREP: Read nil XID from storage engines, skipping position init
150702 10:50:20 [Note] WSREP: wsrep_load(): loading provider library '/usr/lib/galera/libgalera_smm.so'
150702 10:50:20 [Note] WSREP: wsrep_load(): Galera 3.9(rXXXX) by Codership Oy <info@codership.com> loaded successfully.
150702 10:50:20 [Note] WSREP: CRC-32C: using "slicing-by-8" algorithm.
150702 10:50:20 [Note] WSREP: Found saved state: 00000000-0000-0000-0000-000000000000:-1
150702 10:50:20 [Note] WSREP: Passing config to GCS: base_host = 192.168.8.12; base_port = 4567; cert.log_conflicts = no; debug = no; evs.auto_evict = 0; evs.delay_margin = PT1S; evs.delayed_keep_period = PT30S; evs.inactive_check_period = PT0.5S; evs.inactive_timeout = PT15S; evs.join_retrans_period = PT1S; evs.max_install_timeouts = 3; evs.send_window = 4; evs.stats_report_period = PT1M; evs.suspect_timeout = PT5S; evs.user_send_window = 2; evs.view_forget_timeout = PT24H; gcache.dir = /var/lib/mysql/; gcache.keep_pages_size = 0; gcache.mem_size = 0; gcache.name = /var/lib/mysql//galera.cache; gcache.page_size = 128M; gcache.size = 128M; gcs.fc_debug = 0; gcs.fc_factor = 1.0; gcs.fc_limit = 16; gcs.fc_master_slave = no; gcs.max_packet_size = 64500; gcs.max_throttle = 0.25; gcs.recv_q_hard_limit = 9223372036854775807; gcs.recv_q_soft_limit = 0.25; gcs.sync_donor = no; gmcast.segment = 0; gmcast.version = 0; pc.announce_timeout = PT3S; pc.checksum = false; pc.ignore_quorum = false; pc.ignore_sb = false; pc.npvo = false; pc.recover
150702 10:50:21 [Note] WSREP: Service thread queue flushed.
150702 10:50:21 [Note] WSREP: Assign initial position for certification: -1, protocol version: -1
150702 10:50:21 [Note] WSREP: wsrep_sst_grab()
150702 10:50:21 [Note] WSREP: Start replication
150702 10:50:21 [Note] WSREP: 'wsrep-new-cluster' option used, bootstrapping the cluster
150702 10:50:21 [Note] WSREP: Setting initial position to 00000000-0000-0000-0000-000000000000:-1
150702 10:50:21 [Note] WSREP: protonet asio version 0
150702 10:50:21 [Note] WSREP: Using CRC-32C for message checksums.
150702 10:50:21 [Note] WSREP: backend: asio
150702 10:50:21 [Warning] WSREP: access file(gvwstate.dat) failed(No such file or directory)
150702 10:50:21 [Note] WSREP: restore pc from disk failed
150702 10:50:21 [Note] WSREP: GMCast version 0
150702 10:50:21 [Note] WSREP: (5f144230, 'tcp://0.0.0.0:4567') listening at tcp://0.0.0.0:4567
150702 10:50:21 [Note] WSREP: (5f144230, 'tcp://0.0.0.0:4567') multicast: , ttl: 1
150702 10:50:21 [Note] WSREP: EVS version 0
150702 10:50:21 [Note] WSREP: gcomm: bootstrapping new group 'db_wordpress'
150702 10:50:21 [Note] WSREP: start_prim is enabled, turn off pc_recovery
150702 10:50:21 [Note] WSREP: Node 5f144230 state prim
150702 10:50:21 [Note] WSREP: view(view_id(PRIM,5f144230,1) memb {
5f144230,0
} joined {
} left {
} partitioned {
150702 10:50:21 [Note] WSREP: save pc into disk
150702 10:50:21 [Note] WSREP: discarding pending addr without UUID: tcp://192.168.8.10:4567
150702 10:50:21 [Note] WSREP: discarding pending addr proto entry 0x7f10e6609500
150702 10:50:21 [Note] WSREP: discarding pending addr without UUID: tcp://192.168.8.11:4567
150702 10:50:21 [Note] WSREP: discarding pending addr proto entry 0x7f10e6609740
150702 10:50:21 [Note] WSREP: discarding pending addr without UUID: tcp://192.168.8.12:4567
150702 10:50:21 [Note] WSREP: discarding pending addr proto entry 0x7f10e6609800
150702 10:50:21 [Note] WSREP: gcomm: connected
150702 10:50:21 [Note] WSREP: Changing maximum packet size to 64500, resulting msg size: 32636
150702 10:50:21 [Note] WSREP: Shifting CLOSED -> OPEN (TO: 0)
150702 10:50:21 [Note] WSREP: Opened channel 'db_wordpress'
150702 10:50:21 [Note] WSREP: Waiting for SST to complete.
150702 10:50:21 [Note] WSREP: New COMPONENT: primary = yes, bootstrap = no, my_idx = 0, memb_num = 1
150702 10:50:21 [Note] WSREP: Starting new group from scratch: 5f6bc890-2097-11e5-afbe-cb017e6de0c0
150702 10:50:21 [Note] WSREP: STATE_EXCHANGE: sent state UUID: 5f6f4693-2097-11e5-ac28-bb5b1c3a5ee8
150702 10:50:21 [Note] WSREP: STATE EXCHANGE: sent state msg: 5f6f4693-2097-11e5-ac28-bb5b1c3a5ee8
150702 10:50:21 [Note] WSREP: STATE EXCHANGE: got state msg: 5f6f4693-2097-11e5-ac28-bb5b1c3a5ee8 from 0 (teststack-db-3374vvwqqb75)
150702 10:50:21 [Note] WSREP: Quorum results:
version = 3,
component = PRIMARY,
conf_id = 0,
members = 1/1 (joined/total),
act_id = 0,
last_appl. = -1,
protocols = 0/7/3 (gcs/repl/appl),
group UUID = 5f6bc890-2097-11e5-afbe-cb017e6de0c0
150702 10:50:21 [Note] WSREP: Flow-control interval: [16, 16]
150702 10:50:21 [Note] WSREP: Restored state OPEN -> JOINED (0)
150702 10:50:21 [Note] WSREP: Member 0.0 (teststack-db-3374vvwqqb75) synced with group.
150702 10:50:21 [Note] WSREP: Shifting JOINED -> SYNCED (TO: 0)
150702 10:50:21 [Note] WSREP: New cluster view: global state: 5f6bc890-2097-11e5-afbe-cb017e6de0c0:0, view# 1: Primary, number of nodes: 1, my index: 0, protocol version 3
150702 10:50:22 [Note] WSREP: SST complete, seqno: 0
150702 10:50:22 [Note] InnoDB: Using mutexes to ref count buffer pool pages
150702 10:50:22 [Note] InnoDB: The InnoDB memory heap is disabled
150702 10:50:22 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
150702 10:50:22 [Note] InnoDB: Memory barrier is not used
150702 10:50:22 [Note] InnoDB: Compressed tables use zlib 1.2.8
150702 10:50:22 [Note] InnoDB: Using Linux native AIO
150702 10:50:22 [Note] InnoDB: Not using CPU crc32 instructions
150702 10:50:22 [Note] InnoDB: Initializing buffer pool, size = 256.0M
150702 10:50:23 [Note] InnoDB: Completed initialization of buffer pool
150702 10:50:23 [Note] InnoDB: Highest supported file format is Barracuda.
150702 10:50:25 [Note] InnoDB: 128 rollback segment(s) are active.
150702 10:50:25 [Note] InnoDB: Waiting for purge to start
150702 10:50:25 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.24-72.2 started; log sequence number 1617051
150702 10:50:31 [Warning] WSREP: last inactive check more than PT1.5S ago (PT4.42184S), skipping check
150702 10:50:39 [Note] Plugin 'FEEDBACK' is disabled.
150702 10:50:40 [Note] Server socket created on IP: '0.0.0.0'.
150702 10:50:42 [Note] Event Scheduler: Loaded 0 events
150702 10:50:43 [Note] Reading of all Master_info entries succeded
150702 10:50:43 [Note] WSREP: wsrep_notify_cmd is not defined, skipping notification.
150702 10:50:43 [Note] Added new Master_info '' to hash table
150702 10:50:43 [Note] mysqld: ready for connections.
Version: '10.0.20-MariaDB-1~jessie-wsrep-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution, wsrep_25.10.r4144
150702 10:50:43 [Note] WSREP: REPL Protocols: 7 (3, 2)
150702 10:50:43 [Note] WSREP: Service thread queue flushed.
150702 10:50:43 [Note] WSREP: Assign initial position for certification: 0, protocol version: 3
150702 10:50:43 [Note] WSREP: Synchronized with group, ready for connections
deux ligne importante:
150702 10:50:21 [Note] WSREP: ‘wsrep-new-cluster’ option used, bootstrapping the cluster
et
150702 10:50:21 [Note] WSREP: gcomm: bootstrapping new group ‘db_wordpress’
donc ce n’est pas un souci de configuration à priori
quelqu’un aurait une idée?
ps: debian 8 jessie
uname -a
Linux teststack-db-3374vvwqqb75 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24) x86_64 GNU/Linux
dpkg -l | grep mariadb
ii libmariadbclient18 10.0.20+maria-1~jessie amd64 MariaDB database client library
ii mariadb-client-10.0 10.0.20+maria-1~jessie amd64 MariaDB database client binaries
ii mariadb-client-core-10.0 10.0.20+maria-1~jessie amd64 MariaDB database core client binaries
ii mariadb-common 10.0.20+maria-1~jessie all MariaDB database common files (e.g. /etc/mysql/conf.d/mariadb.cnf)
ii mariadb-galera-server 10.0.20+maria-1~jessie all MariaDB database server with Galera cluster (metapackage depending on the latest version)
ii mariadb-galera-server-10.0 10.0.20+maria-1~jessie amd64 MariaDB database server with Galera cluster binaries
