MATERIEL : Aucun réseau Wifi détecté avec Wicd
Je suis sous Jessie avec le noyau 3.16.0-4-amd64 et j’uttilise Kde Plasma.
Mon matériel avec la commande lspci:
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02) 00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02) 00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06) 00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05) 00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05) 00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05) 00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5) 00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05) 00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05) 00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05) 00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05) 01:00.0 Ethernet controller: Broadcom Corporation NetLink BCM57780 Gigabit Ethernet PCIe (rev 01) 02:00.0 Network controller: Broadcom Corporation BCM43225 802.11b/g/n (rev 01) ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02) ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02) ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02) ff:02.1 Host bridge: Intel Corporation 1st Generation Core Processor QPI Physical 0 (rev 02) ff:02.2 Host bridge: Intel Corporation 1st Generation Core Processor Reserved (rev 02) ff:02.3 Host bridge: Intel Corporation 1st Generation Core Processor Reserved (rev 02)
Je n’arrive donc pas à détecter de réseaux Wifi avec Wicd. J’ai pourtant bien installé les firmwares de ma carte Wifi dans /lib/firmware.
Merci d’avance pour votre aide ! :smiley:
Tu n’as pas de messages d’erreur dans le dmesg ou dans les logs ?
Tu peux essayer avec wavemon s’il voit des réseaux. Si c’est le cas, le problème vient de wicd, sinon il faut chercher ailleurs.
Je viens de regarder dmesg et il m’affiche cela:
brcmsmac bcma0:0 firmware: failed to load brcm/bcm43xx-0.fw (-2) brcmsmac bcma0:0: Direct firmware load failed with error -2 brcmsmac bcma0:0: Falling back to user helper
Le même message est affiché dix fois avec à sa gauche une suite de nombres à chaque fois différents entre deux crochets.
Je vais essayer de faire une recherche sur Google entre temps !
EDIT: Problème résolu ! J’ai du me planter de pilote lors de l’install.
alarig@HAL9000:~$ apt-file search /lib/firmware/brcm/bcm43xx-0.fw firmware-brcm80211: /lib/firmware/brcm/bcm43xx-0.fw
Tu as bien installé ce paquet ?
