Ménage dans xorg.conf
Plop,
En installant fglrx, j’ai remarqué que mon xorg.conf était particulièrement monstrueux. Je voulais savoir s’il y avait moyen de faire un peu de ménage. Voici la totalité de mon xorg.conf :
[code]dunatotatos@PC-Duna:~$ cat /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 “aticonfig-Screen[0]-0” 0 0
InputDevice “Mouse0” "CorePointer"
InputDevice “Keyboard0” "CoreKeyboard"
EndSection
Section “Files”
#FontPath     "/usr/share/fonts/X11/cyrillic"
ModulePath   "/usr/lib/xorg/modules"
FontPath     "/usr/share/fonts/X11/misc"
FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath     "/usr/share/fonts/X11/Type1"
FontPath     "/usr/share/fonts/X11/100dpi"
FontPath     "/usr/share/fonts/X11/75dpi"
FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath     "built-ins"
EndSection
Section "Module"
Load "dri2"
Load "glx"
Load "dbe"
Load "dri"
Load "record"
Load "extmod"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/input/mice"
Option “ZAxisMapping” "4 5 6 7"
EndSection
Section “Monitor”
#DisplaySize	  330   210	# mm
Identifier   "Monitor0"
VendorName   "LPL"
ModelName    "LP154WX4-TLC8"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option “VendorName” "ATI Proprietary Driver"
Option “ModelName” "Generic Autodetecting Monitor"
Option “DPMS” "true"
EndSection
Section “Device”
    ### Available Driver options are:-
    ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
    ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
    ### [arg]: arg optional
    #Option     "NoAccel"            	# [<bool>]
    #Option     "SWcursor"           	# [<bool>]
    #Option     "Dac6Bit"            	# [<bool>]
    #Option     "Dac8Bit"            	# [<bool>]
    #Option     "BusType"            	# [<str>]
    #Option     "CPPIOMode"          	# [<bool>]
    #Option     "CPusecTimeout"      	# <i>
    #Option     "AGPMode"            	# <i>
    #Option     "AGPFastWrite"       	# [<bool>]
    #Option     "AGPSize"            	# <i>
    #Option     "GARTSize"           	# <i>
    #Option     "RingSize"           	# <i>
    #Option     "BufferSize"         	# <i>
    #Option     "EnableDepthMoves"   	# [<bool>]
    #Option     "EnablePageFlip"     	# [<bool>]
    #Option     "NoBackBuffer"       	# [<bool>]
    #Option     "DMAForXv"           	# [<bool>]
    #Option     "FBTexPercent"       	# <i>
    #Option     "DepthBits"          	# <i>
    #Option     "PCIAPERSize"        	# <i>
    #Option     "AccelDFS"           	# [<bool>]
    #Option     "IgnoreEDID"         	# [<bool>]
    #Option     "DisplayPriority"    	# [<str>]
    #Option     "PanelSize"          	# [<str>]
    #Option     "ForceMinDotClock"   	# <freq>
    #Option     "ColorTiling"        	# [<bool>]
    #Option     "VideoKey"           	# <i>
    #Option     "RageTheatreCrystal" 	# <i>
    #Option     "RageTheatreTunerPort" 	# <i>
    #Option     "RageTheatreCompositePort" 	# <i>
    #Option     "RageTheatreSVideoPort" 	# <i>
    #Option     "TunerType"          	# <i>
    #Option     "RageTheatreMicrocPath" 	# <str>
    #Option     "RageTheatreMicrocType" 	# <str>
    #Option     "ScalerWidth"        	# <i>
    #Option     "RenderAccel"        	# [<bool>]
    #Option     "SubPixelOrder"      	# [<str>]
    #Option     "ShowCache"          	# [<bool>]
    #Option     "DynamicClocks"      	# [<bool>]
    #Option     "VGAAccess"          	# [<bool>]
    #Option     "ReverseDDC"         	# [<bool>]
    #Option     "LVDSProbePLL"       	# [<bool>]
    #Option     "AccelMethod"        	# <str>
    #Option     "DRI"                	# [<bool>]
    #Option     "ConnectorTable"     	# <str>
    #Option     "DefaultConnectorTable" 	# [<bool>]
    #Option     "DefaultTMDSPLL"     	# [<bool>]
    #Option     "TVDACLoadDetect"    	# [<bool>]
    #Option     "ForceTVOut"         	# [<bool>]
    #Option     "TVStandard"         	# <str>
    #Option     "IgnoreLidStatus"    	# [<bool>]
    #Option     "DefaultTVDACAdj"    	# [<bool>]
    #Option     "Int10"              	# [<bool>]
    #Option     "EXAVSync"           	# [<bool>]
    #Option     "ATOMTVOut"          	# [<bool>]
    #Option     "R4xxATOM"           	# [<bool>]
Identifier  "Card0"
Driver      "radeon"
VendorName  "ATI Technologies Inc"
BoardName   "Mobility Radeon HD 3650"
BusID       "PCI:1:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection[/code]
Je suppose déjà que les lignes “Option” commentées sont totalement inutiles… Mais le reste ?
Merci d’avance pour votre aide :wink:
Duna
Personnellement, mon xorg.conf a été généré par Xorg. Tu peux copier ton xorg.conf actuel ailleurs et faire un dpkg-reconfigure xserver-xorg qui devrait t’en refaire un plus clean. Pense juste à rajouter ton driver de carte graphique.
Et si tu fais une seule erreur il te faudra plusieurs siècles pour compenser le temps que tu vas gagner si cela marche et seulement quelques centaines d’années pour amortir le temps que tu vas perdre à le faire :006 :006 :006
Une ode anti-optimisation ? C’est joli…
[quote=“ggoodluck47”]Salut,
Et si tu fais une seule erreur il te faudra plusieurs siècles pour compenser le temps que tu vas gagner si cela marche et seulement quelques centaines d’années pour amortir le temps que tu vas perdre à le faire :006 :006 :006[/quote]
Pas grave, je passe tout mon temps à bidouiller mon PC. Je me suis même amusé à faire une jolie présentation du sources.list.
Oki, je tente. Merci.
Une bonne méthode pour savoir ce que tu peux enlever est de regarder ton /var/log/Xorg.0.log,
je parie que tu y verras déjà des lignes du genre loading modules machin already enabled by default , loading anyway (en gros), ce qui veux dire que tu peux enlever les modules correspondant dans ton Xorg.conf.
Chez moi, il n’y a plus de partie modules dans le Xorg.conf, mais dri et glx sont quand même lancés.
Avoir un /var/log/Xorg.0.log sans aucun WW est déjà un bon début d’optimisation. :wink:
J’imagine que tu voulais plutôt faire du ménage dans la partie dans le Xorg.conf qui se situe plus bas
mais avec une carte intel de base, je n’ai jamais eu une telle partie.
En même temps, suffit de faire une sauvegarde du xorg.conf avant, et de revenir dessus en cas de problème…
Depuis quelque temps Xorg (grace a hal et evdev ),gère bien la détection automatique. Il y a peut être à changer “fglrx”, pour un autre.
[quote]Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "fglrx"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
