bonjour, lorsque je fais cette commande dmesg | grep uvc -i j’ai un message qui contient des erreurs mais je sais pas du tout de quoi ça parle, si c’est grave et surtout comment les regler.
[dubar ~]$ dmesg | grep uvc -i
[ 14.252043] uvcvideo: Found UVC 1.00 device <unnamed> (046d:08ce)
[ 14.308751] input: UVC Camera (046d:08ce) as /class/input/input7
[ 14.395390] usbcore: registered new interface driver uvcvideo
[ 161.654011] uvcvideo: Failed to query (131) UVC control 3 (unit 2) : -32 (exp. 2).
[ 165.060452] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -32 (exp. 26).
[ 171.425053] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[ 175.777099] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[ 177.152103] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[ 178.182162] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[ 182.297739] uvcvideo: Failed to query (135) UVC control 2 (unit 2) : -32 (exp. 2).
[ 184.485006] uvcvideo: Failed to query (131) UVC control 1 (unit 2) : -32 (exp. 2).
[ 189.555006] uvcvideo: Failed to query (130) UVC control 3 (unit 2) : -32 (exp. 2).
[ 1013.454284] uvcvideo: Failed to query (132) UVC control 7 (unit 2) : -32 (exp. 2).
[dubar ~]$ [ 14.252043] uvcvideo: Found UVC 1.00 device <unnamed> (046d:08ce)
bash: syntax error near unexpected token `('
[dubar ~]$ [ 14.308751] input: UVC Camera (046d:08ce) as /class/input/input7
[dubar ~]$ [ 14.395390] usbcore: registered new interface driver uvcvideo
bash: [: missing `]'
[dubar ~]$ [ 161.654011] uvcvideo: Failed to query (131) UVC control 3 (unit 2) : -32 (exp. 2).
[dubar ~]$ [ 165.060452] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -32 (exp. 26).
[dubar ~]$ [ 171.425053] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[dubar ~]$ [ 175.777099] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[dubar ~]$ [ 177.152103] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[dubar ~]$ [ 178.182162] uvcvideo: Failed to query (1) UVC control 1 (unit 0) : -110 (exp. 26).
[dubar ~]$ [ 182.297739] uvcvideo: Failed to query (135) UVC control 2 (unit 2) : -32 (exp. 2).
[dubar ~]$ [ 184.485006] uvcvideo: Failed to query (131) UVC control 1 (unit 2) : -32 (exp. 2).
[dubar ~]$ [ 189.555006] uvcvideo: Failed to query (130) UVC control 3 (unit 2) : -32 (exp. 2).
[dubar ~]$ [ 1013.454284] uvcvideo: Failed to query (132) UVC control 7 (unit 2) : -32 (exp. 2).
je suis sous elive. Merci.
