Message d'erreur owncloud
hello all :slightly_smiling:
j’ai 2 message d’erreur
j’ai trouver la solution pour l’erreur 2
stackoverflow.com/questions/241 … y-on-https
mais cela na pas fonctionner …
mon fichier
[code]# Version: 8.1.4
SetEnvIfNoCase ^Authorization$ “(.+)” XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
# Add security and privacy related headers Header set Strict-Transport-Security "max-age=31536000" env=HTTPS Header set X-Content-Type-Options "nosniff" Header set X-XSS-Protection "1; mode=block" Header set X-Robots-Tag "none" Header set X-Frame-Options "SAMEORIGIN" SetEnv modHeadersAvailable true
Add cache control for CSS and JS files
<FilesMatch “.(css|js)$”>
Header set Cache-Control "max-age=7200, public"
php_value upload_max_filesize 513M
php_value post_max_size 513M
php_value memory_limit 512M
php_value mbstring.func_overload 0
php_value always_populate_raw_post_data -1
php_value default_charset 'UTF-8’
php_value output_buffering off
SetEnv htaccessWorking true
RewriteEngine on
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^.well-known/host-meta /public.php?service=host-meta [QSA,L]
RewriteRule ^.well-known/host-meta.json /public.php?service=host-meta-json [QSA,L]
RewriteRule ^.well-known/carddav /remote.php/carddav/ [R=301,L]
RewriteRule ^.well-known/caldav /remote.php/caldav/ [R=301,L]
RewriteRule ^apps/calendar/caldav.php remote.php/caldav/ [QSA,L]
RewriteRule ^apps/contacts/carddav.php remote.php/carddav/ [QSA,L]
RewriteRule ^remote/(.) remote.php [QSA,L]
RewriteRule ^(build|tests|config|lib|3rdparty|templates)/.
- [R=404,L]
RewriteRule ^(.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
DirectoryIndex index.php index.html
AddDefaultCharset utf-8
Options -Indexes
ModPagespeed Off
pour l’autre erreur j’aimerais en savoir plus sur comment le résoudre
merci
Hello,
Pour le premier message il faut installer memcache (apt-get install memcached php5-memcache devrait suffire, src -> packages.debian.org/search?sear … p-memcache
Pour le deuxième configure désactive l’env que tu as mis :
en
Si ça marche par tu pourras donner le résultat d’un curl -I -v .
Ton bout de conf c’est du virtualhost ou du vhost ?
Merci,
j’ai regarder vite fait pour l’erreur 2 et cela na pas fonctionner p.s le Fichier est le .htaccess du dossier owncloud
p.s 2 j’ai pas eu le temps pour le moment de regarder l’érreur 1
mais j’ai une question les erreur nui t’elle a la sécurité des données et du serveur ?
merci d’avance
Non c’est que de la gestion de cache. Le premier message c’est pour la configuration de memcache php, ça augmentera tes perf et chargera moins du serveur php.net/manual/fr/book.memcache.php
Le deuxième message c’est “pour forcer l’https”. Ça indique au client web, si ils en ont la possibilité, d’utiliser l’https au lieu de l’https. Il fera des appels en https directement. C’est un peu comme une rewrite mais côté cache du client navigateur fr.wikipedia.org/wiki/HTTP_Stri … t_Security
bon j’arrive peut être un peu tard mais je viens de résoudre le problème de mon coté pour le message 2 et au pire, cela pourra servir pour d’autres personnes :wink:
il faut ajouter ce header
dans /etc/apache2/sites-available/default-ssl.conf dans la section
Puis restart de apache.
Si le message persiste, un petit a2enmod headers + restart apache devrait en venir à bout :wink:
