après une installation sur une machine neuve et pourtant bien reconnue par debian. J’ai ce message après un upgrade en sid :
Y a-t-il quelque chose à faire ou puis-je l’ignorer (ma machine marche bien) ?W: Possible missing firmware /lib/firmware/timeout for module usbcore
W: Possible missing firmware /lib/firmware/in for module usbcore
W: Possible missing firmware /lib/firmware/milliseconds for module usbcore
W: Possible missing firmware /lib/firmware/(default for module usbcore
W: Possible missing firmware /lib/firmware/5000 for module usbcore
W: Possible missing firmware /lib/firmware/- for module usbcore
W: Possible missing firmware /lib/firmware/5.0 for module usbcore
W: Possible missing firmware /lib/firmware/seconds) for module usbcore
W: Possible missing firmware /lib/firmware/(int) for module usbcore
W: Possible missing firmware /lib/firmware/old_scheme_first:start for module usbcore
W: Possible missing firmware /lib/firmware/with for module usbcore
W: Possible missing firmware /lib/firmware/the for module usbcore
W: Possible missing firmware /lib/firmware/old for module usbcore
W: Possible missing firmware /lib/firmware/device for module usbcore
W: Possible missing firmware /lib/firmware/initialization for module usbcore
W: Possible missing firmware /lib/firmware/scheme for module usbcore
W: Possible missing firmware /lib/firmware/(bool) for module usbcore
W: Possible missing firmware /lib/firmware/use_both_schemes:try for module usbcore
W: Possible missing firmware /lib/firmware/other for module usbcore
W: Possible missing firmware /lib/firmware/if for module usbcore
W: Possible missing firmware /lib/firmware/first for module usbcore
W: Possible missing firmware /lib/firmware/one for module usbcore
W: Possible missing firmware /lib/firmware/fails for module usbcore
W: Possible missing firmware /lib/firmware/autosuspend:default for module usbcore
W: Possible missing firmware /lib/firmware/autosuspend for module usbcore
W: Possible missing firmware /lib/firmware/delay for module usbcore
W: Possible missing firmware /lib/firmware/nousb: for module usbcore
W: Possible missing firmware /lib/firmware/debug:toggle for module hid
W: Possible missing firmware /lib/firmware/HID for module hid
W: Possible missing firmware /lib/firmware/debugging for module hid
W: Possible missing firmware /lib/firmware/messages for module hid
W: Possible missing firmware /lib/firmware/(int) for module hid
W: Possible missing firmware /lib/firmware/mousepoll:Polling for module usbhid
W: Possible missing firmware /lib/firmware/interval for module usbhid
W: Possible missing firmware /lib/firmware/of for module usbhid
W: Possible missing firmware /lib/firmware/mice for module usbhid
W: Possible missing firmware /lib/firmware/(uint) for module usbhid
W: Possible missing firmware /lib/firmware/ignoreled:Autosuspend for module usbhid
W: Possible missing firmware /lib/firmware/with for module usbhid
W: Possible missing firmware /lib/firmware/active for module usbhid
W: Possible missing firmware /lib/firmware/leds for module usbhid
W: Possible missing firmware /lib/firmware/quirks:Add/modify for module usbhid
W: Possible missing firmware /lib/firmware/USB for module usbhid
W: Possible missing firmware /lib/firmware/HID for module usbhid
W: Possible missing firmware /lib/firmware/quirks for module usbhid
W: Possible missing firmware /lib/firmware/by for module usbhid
W: Possible missing firmware /lib/firmware/specifying for module usbhid
W: Possible missing firmware /lib/firmware/quirks=vendorID:productID:quirks for module usbhid
W: Possible missing firmware /lib/firmware/where for module usbhid
W: Possible missing firmware /lib/firmware/vendorID, for module usbhid
W: Possible missing firmware /lib/firmware/productID, for module usbhid
W: Possible missing firmware /lib/firmware/and for module usbhid
W: Possible missing firmware /lib/firmware/are for module usbhid
W: Possible missing firmware /lib/firmware/all for module usbhid
W: Possible missing firmware /lib/firmware/in for module usbhid
W: Possible missing firmware /lib/firmware/0x-prefixed for module usbhid
W: Possible missing firmware /lib/firmware/hex for module usbhid
W: Possible missing firmware /lib/firmware/(array for module usbhid
W: Possible missing firmware /lib/firmware/charp) for module usbhid
W: Possible missing firmware /lib/firmware/auth_hashtable_size:RPC for module sunrpc
W: Possible missing firmware /lib/firmware/credential for module sunrpc
W: Possible missing firmware /lib/firmware/cache for module sunrpc
W: Possible missing firmware /lib/firmware/hashtable for module sunrpc
W: Possible missing firmware /lib/firmware/size for module sunrpc
W: Possible missing firmware /lib/firmware/(hashtbl_sz) for module sunrpc
W: Possible missing firmware /lib/firmware/min_resvport: for module sunrpc
W: Possible missing firmware /lib/firmware/(portnr) for module sunrpc
W: Possible missing firmware /lib/firmware/max_resvport: for module sunrpc
W: Possible missing firmware /lib/firmware/tcp_slot_table_entries: for module sunrpc
W: Possible missing firmware /lib/firmware/(slot_table_size) for module sunrpc
W: Possible missing firmware /lib/firmware/udp_slot_table_entries: for module sunrpc
W: Possible missing firmware /lib/firmware/expired_cred_retry_delay:Timeout for module auth_rpcgss
W: Possible missing firmware /lib/firmware/(in for module auth_rpcgss
W: Possible missing firmware /lib/firmware/seconds) for module auth_rpcgss
W: Possible missing firmware /lib/firmware/until for module auth_rpcgss
W: Possible missing firmware /lib/firmware/the for module auth_rpcgss
W: Possible missing firmware /lib/firmware/RPC for module auth_rpcgss
W: Possible missing firmware /lib/firmware/engine for module auth_rpcgss
W: Possible missing firmware /lib/firmware/retries for module auth_rpcgss
W: Possible missing firmware /lib/firmware/an for module auth_rpcgss
W: Possible missing firmware /lib/firmware/expired for module auth_rpcgss
W: Possible missing firmware /lib/firmware/credential for module auth_rpcgss
W: Possible missing firmware /lib/firmware/(uint) for module auth_rpcgss
W: Possible missing firmware /lib/firmware/defer_lookup: for module fscache
W: Possible missing firmware /lib/firmware/(uint) for module fscache
W: Possible missing firmware /lib/firmware/fscache_defer_lookup:Defer for module fscache
W: Possible missing firmware /lib/firmware/cookie for module fscache
W: Possible missing firmware /lib/firmware/lookup for module fscache
W: Possible missing firmware /lib/firmware/to for module fscache
W: Possible missing firmware /lib/firmware/background for module fscache
W: Possible missing firmware /lib/firmware/thread for module fscache
W: Possible missing firmware /lib/firmware/defer_create: for module fscache
W: Possible missing firmware /lib/firmware/fscache_defer_create:Defer for module fscache
W: Possible missing firmware /lib/firmware/creation for module fscache
W: Possible missing firmware /lib/firmware/debug: for module fscache
W: Possible missing firmware /lib/firmware/fscache_debug:FS-Cache for module fscache
W: Possible missing firmware /lib/firmware/debugging for module fscache
W: Possible missing firmware /lib/firmware/mask for module fscache
W: Possible missing firmware /lib/firmware/nsm_use_hostnames: for module lockd
W: Possible missing firmware /lib/firmware/(bool) for module lockd
W: Possible missing firmware /lib/firmware/nlm_max_connections: for module lockd
W: Possible missing firmware /lib/firmware/(uint) for module lockd
W: Possible missing firmware /lib/firmware/callback_tcpport: for module nfs
W: Possible missing firmware /lib/firmware/(portnr) for module nfs
W: Possible missing firmware /lib/firmware/cache_getent:Path for module nfs
W: Possible missing firmware /lib/firmware/to for module nfs
W: Possible missing firmware /lib/firmware/the for module nfs
W: Possible missing firmware /lib/firmware/client for module nfs
W: Possible missing firmware /lib/firmware/cache for module nfs
W: Possible missing firmware /lib/firmware/upcall for module nfs
W: Possible missing firmware /lib/firmware/program for module nfs
W: Possible missing firmware /lib/firmware/(string) for module nfs
W: Possible missing firmware /lib/firmware/cache_getent_timeout:Timeout for module nfs
W: Possible missing firmware /lib/firmware/(in for module nfs
W: Possible missing firmware /lib/firmware/seconds) for module nfs
W: Possible missing firmware /lib/firmware/after for module nfs
W: Possible missing firmware /lib/firmware/which for module nfs
W: Possible missing firmware /lib/firmware/is for module nfs
W: Possible missing firmware /lib/firmware/assumed for module nfs
W: Possible missing firmware /lib/firmware/have for module nfs
W: Possible missing firmware /lib/firmware/failed for module nfs
W: Possible missing firmware /lib/firmware/(ulong) for module nfs
W: Possible missing firmware /lib/firmware/enable_ino64: for module nfs
W: Possible missing firmware /lib/firmware/(bool) for module nfs
W: Possible missing firmware /lib/firmware/force_pseudohp:Enable for module jme
W: Possible missing firmware /lib/firmware/pseudo for module jme
W: Possible missing firmware /lib/firmware/hot-plug for module jme
W: Possible missing firmware /lib/firmware/feature for module jme
W: Possible missing firmware /lib/firmware/manually for module jme
W: Possible missing firmware /lib/firmware/by for module jme
W: Possible missing firmware /lib/firmware/driver for module jme
W: Possible missing firmware /lib/firmware/instead for module jme
W: Possible missing firmware /lib/firmware/of for module jme
W: Possible missing firmware /lib/firmware/BIOS. for module jme
W: Possible missing firmware /lib/firmware/(int) for module jme
W: Possible missing firmware /lib/firmware/no_pseudohp:Disable for module jme
W: Possible missing firmware /lib/firmware/feature. for module jme
W: Possible missing firmware /lib/firmware/no_extplug:Do for module jme
W: Possible missing firmware /lib/firmware/not for module jme
W: Possible missing firmware /lib/firmware/use for module jme
W: Possible missing firmware /lib/firmware/external for module jme
W: Possible missing firmware /lib/firmware/plug for module jme
W: Possible missing firmware /lib/firmware/signal for module jme
W: Possible missing firmware /lib/firmware/for for module jme
W: Possible missing firmware /lib/firmware/hot-plug. for module jme
W: Possible missing firmware /lib/firmware/use_spi_crc: for module mmc_core
W: Possible missing firmware /lib/firmware/(bool) for module mmc_core
W: Possible missing firmware /lib/firmware/removable:MMC/SD for module mmc_core
W: Possible missing firmware /lib/firmware/cards for module mmc_core
W: Possible missing firmware /lib/firmware/are for module mmc_core
W: Possible missing firmware /lib/firmware/removable for module mmc_core
W: Possible missing firmware /lib/firmware/and for module mmc_core
W: Possible missing firmware /lib/firmware/may for module mmc_core
W: Possible missing firmware /lib/firmware/be for module mmc_core
W: Possible missing firmware /lib/firmware/removed for module mmc_core
W: Possible missing firmware /lib/firmware/during for module mmc_core
W: Possible missing firmware /lib/firmware/suspend for module mmc_core
W: Possible missing firmware /lib/firmware/dev_flags:Given for module scsi_mod
W: Possible missing firmware /lib/firmware/scsi_dev_flags=vendor:model:flags[,v:m:f] for module scsi_mod
W: Possible missing firmware /lib/firmware/add for module scsi_mod
W: Possible missing firmware /lib/firmware/black/white for module scsi_mod
W: Possible missing firmware /lib/firmware/list for module scsi_mod
W: Possible missing firmware /lib/firmware/entries for module scsi_mod
W: Possible missing firmware /lib/firmware/for for module scsi_mod
W: Possible missing firmware /lib/firmware/vendor for module scsi_mod
W: Possible missing firmware /lib/firmware/and for module scsi_mod
W: Possible missing firmware /lib/firmware/model for module scsi_mod
W: Possible missing firmware /lib/firmware/with for module scsi_mod
W: Possible missing firmware /lib/firmware/an for module scsi_mod
W: Possible missing firmware /lib/firmware/integer for module scsi_mod
W: Possible missing firmware /lib/firmware/value for module scsi_mod
W: Possible missing firmware /lib/firmware/of for module scsi_mod
W: Possible missing firmware /lib/firmware/flags for module scsi_mod
W: Possible missing firmware /lib/firmware/to for module scsi_mod
W: Possible missing firmware /lib/firmware/the for module scsi_mod
W: Possible missing firmware /lib/firmware/scsi for module scsi_mod
W: Possible missing firmware /lib/firmware/device for module scsi_mod
W: Possible missing firmware /lib/firmware/info for module scsi_mod
W: Possible missing firmware /lib/firmware/(string) for module scsi_mod
W: Possible missing firmware /lib/firmware/default_dev_flags:scsi for module scsi_mod
W: Possible missing firmware /lib/firmware/default for module scsi_mod
W: Possible missing firmware /lib/firmware/flag for module scsi_mod
W: Possible missing firmware /lib/firmware/(int) for module scsi_mod
W: Possible missing firmware /lib/firmware/max_luns:last for module scsi_mod
W: Possible missing firmware /lib/firmware/LUN for module scsi_mod
W: Possible missing firmware /lib/firmware/(should for module scsi_mod
W: Possible missing firmware /lib/firmware/be for module scsi_mod
W: Possible missing firmware /lib/firmware/between for module scsi_mod
W: Possible missing firmware /lib/firmware/1 for module scsi_mod
W: Possible missing firmware /lib/firmware/2^32-1) for module scsi_mod
W: Possible missing firmware /lib/firmware/(uint) for module scsi_mod
W: Possible missing firmware /lib/firmware/scan:sync, for module scsi_mod
W: Possible missing firmware /lib/firmware/async for module scsi_mod
W: Possible missing firmware /lib/firmware/or for module scsi_mod
W: Possible missing firmware /lib/firmware/none for module scsi_mod
W: Possible missing firmware /lib/firmware/max_report_luns:REPORT for module scsi_mod
W: Possible missing firmware /lib/firmware/LUNS for module scsi_mod
W: Possible missing firmware /lib/firmware/maximum for module scsi_mod
W: Possible missing firmware /lib/firmware/number for module scsi_mod
W: Possible missing firmware /lib/firmware/received for module scsi_mod
W: Possible missing firmware /lib/firmware/16384) for module scsi_mod
W: Possible missing firmware /lib/firmware/inq_timeout:Timeout for module scsi_mod
W: Possible missing firmware /lib/firmware/(in for module scsi_mod
W: Possible missing firmware /lib/firmware/seconds) for module scsi_mod
W: Possible missing firmware /lib/firmware/waiting for module scsi_mod
W: Possible missing firmware /lib/firmware/devices for module scsi_mod
W: Possible missing firmware /lib/firmware/answer for module scsi_mod
W: Possible missing firmware /lib/firmware/INQUIRY. for module scsi_mod
W: Possible missing firmware /lib/firmware/Default for module scsi_mod
W: Possible missing firmware /lib/firmware/is for module scsi_mod
W: Possible missing firmware /lib/firmware/20. for module scsi_mod
W: Possible missing firmware /lib/firmware/Some for module scsi_mod
W: Possible missing firmware /lib/firmware/may for module scsi_mod
W: Possible missing firmware /lib/firmware/need for module scsi_mod
W: Possible missing firmware /lib/firmware/more; for module scsi_mod
W: Possible missing firmware /lib/firmware/most for module scsi_mod
W: Possible missing firmware /lib/firmware/less. for module scsi_mod
W: Possible missing firmware /lib/firmware/scsi_logging_level:a for module scsi_mod
W: Possible missing firmware /lib/firmware/bit for module scsi_mod
W: Possible missing firmware /lib/firmware/mask for module scsi_mod
W: Possible missing firmware /lib/firmware/logging for module scsi_mod
W: Possible missing firmware /lib/firmware/levels for module scsi_mod
W: Possible missing firmware /lib/firmware/acpi_gtf_filter:filter for module libata
W: Possible missing firmware /lib/firmware/mask for module libata
W: Possible missing firmware /lib/firmware/for for module libata
W: Possible missing firmware /lib/firmware/ACPI for module libata
W: Possible missing firmware /lib/firmware/_GTF for module libata
W: Possible missing firmware /lib/firmware/commands, for module libata
W: Possible missing firmware /lib/firmware/set for module libata
W: Possible missing firmware /lib/firmware/to for module libata
W: Possible missing firmware /lib/firmware/filter for module libata
W: Possible missing firmware /lib/firmware/out for module libata
W: Possible missing firmware /lib/firmware/(0x1=set for module libata
W: Possible missing firmware /lib/firmware/xfermode, for module libata
W: Possible missing firmware /lib/firmware/0x2=lock/freeze for module libata
W: Possible missing firmware /lib/firmware/lock, for module libata
W: Possible missing firmware /lib/firmware/0x4=DIPM, for module libata
W: Possible missing firmware /lib/firmware/0x8=FPDMA for module libata
W: Possible missing firmware /lib/firmware/non-zero for module libata
W: Possible missing firmware /lib/firmware/offset, for module libata
W: Possible missing firmware /lib/firmware/0x10=FPDMA for module libata
W: Possible missing firmware /lib/firmware/DMA for module libata
W: Possible missing firmware /lib/firmware/Setup for module libata
W: Possible missing firmware /lib/firmware/FIS for module libata
W: Possible missing firmware /lib/firmware/auto-activate) for module libata
W: Possible missing firmware /lib/firmware/(int) for module libata
W: Possible missing firmware /lib/firmware/force:Force for module libata
W: Possible missing firmware /lib/firmware/ATA for module libata
W: Possible missing firmware /lib/firmware/configurations for module libata
W: Possible missing firmware /lib/firmware/including for module libata
W: Possible missing firmware /lib/firmware/cable for module libata
W: Possible missing firmware /lib/firmware/type, for module libata
W: Possible missing firmware /lib/firmware/link for module libata
W: Possible missing firmware /lib/firmware/speed for module libata
W: Possible missing firmware /lib/firmware/and for module libata
W: Possible missing firmware /lib/firmware/transfer for module libata
W: Possible missing firmware /lib/firmware/mode for module libata
W: Possible missing firmware /lib/firmware/(see for module libata
W: Possible missing firmware /lib/firmware/Documentation/kernel-parameters.txt for module libata
W: Possible missing firmware /lib/firmware/details) for module libata
W: Possible missing firmware /lib/firmware/(string) for module libata
W: Possible missing firmware /lib/firmware/atapi_enabled:Enable for module libata
W: Possible missing firmware /lib/firmware/discovery for module libata
W: Possible missing firmware /lib/firmware/of for module libata
W: Possible missing firmware /lib/firmware/ATAPI for module libata
W: Possible missing firmware /lib/firmware/devices for module libata
W: Possible missing firmware /lib/firmware/(0=off, for module libata
W: Possible missing firmware /lib/firmware/1=on for module libata
W: Possible missing firmware /lib/firmware/[default]) for module libata
W: Possible missing firmware /lib/firmware/atapi_dmadir:Enable for module libata
W: Possible missing firmware /lib/firmware/DMADIR for module libata
W: Possible missing firmware /lib/firmware/bridge for module libata
W: Possible missing firmware /lib/firmware/support for module libata
W: Possible missing firmware /lib/firmware/(0=off for module libata
W: Possible missing firmware /lib/firmware/[default], for module libata
W: Possible missing firmware /lib/firmware/1=on) for module libata
W: Possible missing firmware /lib/firmware/atapi_passthru16:Enable for module libata
W: Possible missing firmware /lib/firmware/ATA_16 for module libata
W: Possible missing firmware /lib/firmware/passthru for module libata
W: Possible missing firmware /lib/firmware/fua:FUA for module libata
W: Possible missing firmware /lib/firmware/ignore_hpa:Ignore for module libata
W: Possible missing firmware /lib/firmware/HPA for module libata
W: Possible missing firmware /lib/firmware/limit for module libata
W: Possible missing firmware /lib/firmware/(0=keep for module libata
W: Possible missing firmware /lib/firmware/BIOS for module libata
W: Possible missing firmware /lib/firmware/limits, for module libata
W: Possible missing firmware /lib/firmware/1=ignore for module libata
W: Possible missing firmware /lib/firmware/using for module libata
W: Possible missing firmware /lib/firmware/full for module libata
W: Possible missing firmware /lib/firmware/disk) for module libata
W: Possible missing firmware /lib/firmware/dma:DMA for module libata
W: Possible missing firmware /lib/firmware/enable/disable for module libata
W: Possible missing firmware /lib/firmware/(0x1==ATA, for module libata
W: Possible missing firmware /lib/firmware/0x2==ATAPI, for module libata
W: Possible missing firmware /lib/firmware/0x4==CF) for module libata
W: Possible missing firmware /lib/firmware/ata_probe_timeout:Set for module libata
W: Possible missing firmware /lib/firmware/probing for module libata
W: Possible missing firmware /lib/firmware/timeout for module libata
W: Possible missing firmware /lib/firmware/(seconds) for module libata
W: Possible missing firmware /lib/firmware/noacpi:Disable for module libata
W: Possible missing firmware /lib/firmware/the for module libata
W: Possible missing firmware /lib/firmware/use for module libata
W: Possible missing firmware /lib/firmware/in for module libata
W: Possible missing firmware /lib/firmware/probe/suspend/resume for module libata
W: Possible missing firmware /lib/firmware/allow_tpm:Permit for module libata
W: Possible missing firmware /lib/firmware/TPM for module libata
W: Possible missing firmware /lib/firmware/commands for module libata
W: Possible missing firmware /lib/firmware/atapi_an:Enable for module libata
W: Possible missing firmware /lib/firmware/AN for module libata
W: Possible missing firmware /lib/firmware/media for module libata
W: Possible missing firmware /lib/firmware/presence for module libata
W: Possible missing firmware /lib/firmware/notification for module libata
W: Possible missing firmware /lib/firmware/(0=0ff for module libata
W: Possible missing firmware /lib/firmware/max_loop:Maximum for module loop
W: Possible missing firmware /lib/firmware/number for module loop
W: Possible missing firmware /lib/firmware/of for module loop
W: Possible missing firmware /lib/firmware/loop for module loop
W: Possible missing firmware /lib/firmware/devices for module loop
W: Possible missing firmware /lib/firmware/(int) for module loop
W: Possible missing firmware /lib/firmware/max_part:Maximum for module loop
W: Possible missing firmware /lib/firmware/partitions for module loop
W: Possible missing firmware /lib/firmware/per for module loop
W: Possible missing firmware /lib/firmware/device for module loop
W: Possible missing firmware /lib/firmware/skip_host_reset:skip for module libahci
W: Possible missing firmware /lib/firmware/global for module libahci
W: Possible missing firmware /lib/firmware/host for module libahci
W: Possible missing firmware /lib/firmware/reset for module libahci
W: Possible missing firmware /lib/firmware/(0=don't for module libahci
W: Possible missing firmware /lib/firmware/skip, for module libahci
W: Possible missing firmware /lib/firmware/1=skip) for module libahci
W: Possible missing firmware /lib/firmware/(int) for module libahci
W: Possible missing firmware /lib/firmware/ignore_sss:Ignore for module libahci
W: Possible missing firmware /lib/firmware/staggered for module libahci
W: Possible missing firmware /lib/firmware/spinup for module libahci
W: Possible missing firmware /lib/firmware/flag for module libahci
W: Possible missing firmware /lib/firmware/ignore, for module libahci
W: Possible missing firmware /lib/firmware/1=ignore) for module libahci
W: Possible missing firmware /lib/firmware/ahci_em_messages:AHCI for module libahci
W: Possible missing firmware /lib/firmware/Enclosure for module libahci
W: Possible missing firmware /lib/firmware/Management for module libahci
W: Possible missing firmware /lib/firmware/Message for module libahci
W: Possible missing firmware /lib/firmware/control for module libahci
W: Possible missing firmware /lib/firmware/(0 for module libahci
W: Possible missing firmware /lib/firmware/= for module libahci
W: Possible missing firmware /lib/firmware/off, for module libahci
W: Possible missing firmware /lib/firmware/1 for module libahci
W: Possible missing firmware /lib/firmware/on) for module libahci
W: Possible missing firmware /lib/firmware/marvell_enable:Marvell for module ahci
W: Possible missing firmware /lib/firmware/SATA for module ahci
W: Possible missing firmware /lib/firmware/via for module ahci
W: Possible missing firmware /lib/firmware/AHCI for module ahci
W: Possible missing firmware /lib/firmware/(1 for module ahci
W: Possible missing firmware /lib/firmware/= for module ahci
W: Possible missing firmware /lib/firmware/enabled) for module ahci
W: Possible missing firmware /lib/firmware/(int) for module ahci
W: Possible missing firmware /lib/firmware/debug_quirks:Force for module sdhci
W: Possible missing firmware /lib/firmware/certain for module sdhci
W: Possible missing firmware /lib/firmware/quirks. for module sdhci
W: Possible missing firmware /lib/firmware/(uint) for module sdhci
W: Possible missing firmware /lib/firmware/act:Disable for module thermal
W: Possible missing firmware /lib/firmware/or for module thermal
W: Possible missing firmware /lib/firmware/override for module thermal
W: Possible missing firmware /lib/firmware/all for module thermal
W: Possible missing firmware /lib/firmware/lowest for module thermal
W: Possible missing firmware /lib/firmware/active for module thermal
W: Possible missing firmware /lib/firmware/trip for module thermal
W: Possible missing firmware /lib/firmware/points. for module thermal
W: Possible missing firmware /lib/firmware/(int) for module thermal
W: Possible missing firmware /lib/firmware/crt:Disable for module thermal
W: Possible missing firmware /lib/firmware/lower for module thermal
W: Possible missing firmware /lib/firmware/critical for module thermal
W: Possible missing firmware /lib/firmware/tzp:Thermal for module thermal
W: Possible missing firmware /lib/firmware/zone for module thermal
W: Possible missing firmware /lib/firmware/polling for module thermal
W: Possible missing firmware /lib/firmware/frequency, for module thermal
W: Possible missing firmware /lib/firmware/in for module thermal
W: Possible missing firmware /lib/firmware/1/10 for module thermal
W: Possible missing firmware /lib/firmware/seconds. for module thermal
W: Possible missing firmware /lib/firmware/nocrt:Set for module thermal
W: Possible missing firmware /lib/firmware/to for module thermal
W: Possible missing firmware /lib/firmware/take for module thermal
W: Possible missing firmware /lib/firmware/no for module thermal
W: Possible missing firmware /lib/firmware/action for module thermal
W: Possible missing firmware /lib/firmware/upon for module thermal
W: Possible missing firmware /lib/firmware/ACPI for module thermal
W: Possible missing firmware /lib/firmware/thermal for module thermal
W: Possible missing firmware /lib/firmware/trips for module thermal
W: Possible missing firmware /lib/firmware/off:Set for module thermal
W: Possible missing firmware /lib/firmware/disable for module thermal
W: Possible missing firmware /lib/firmware/support. for module thermal
W: Possible missing firmware /lib/firmware/psv:Disable for module thermal
W: Possible missing firmware /lib/firmware/passive for module thermal
Traitement des actions différées (« triggers ») pour « menu »...
