Voila mon apache2.conf :
[quote]# Based upon the NCSA server configuration files originally by Rob McCool.
Changed extensively for the Debian package by Daniel Stone daniel@sfarc.net
ServerRoot: The top of the directory tree under which the server’s
configuration, error, and log files are kept.
NOTE! If you intend to place this on an NFS (or otherwise network)
mounted filesystem then please read the LockFile documentation
you will save yourself a lot of trouble.
ServerRoot “/etc/apache2”
The LockFile directive sets the path to the lockfile used when Apache
is compiled with either USE_FCNTL_SERIALIZED_ACCEPT or
USE_FLOCK_SERIALIZED_ACCEPT. This directive should normally be left at
its default value. The main reason for changing it is if the logs
directory is NFS mounted, since the lockfile MUST BE STORED ON A LOCAL
DISK. The PID of the main server process is automatically appended to
the filename.
LockFile /var/lock/apache2/accept.lock
PidFile: The file in which the server should record its process
identification number when it starts.
PidFile /var/run/apache2.pid
Timeout: The number of seconds before receives and sends time out.
Timeout 300
KeepAlive: Whether or not to allow persistent connections (more than
one request per connection). Set to “Off” to deactivate.
KeepAlive On
MaxKeepAliveRequests: The maximum number of requests to allow
during a persistent connection. Set to 0 to allow an unlimited amount.
We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
KeepAliveTimeout: Number of seconds to wait for the next request from the
same client on the same connection.
KeepAliveTimeout 15
Server-Pool Size Regulation (MPM specific)
prefork MPM
StartServers … number of server processes to start
MinSpareServers … minimum number of server processes which are kept spare
MaxSpareServers … maximum number of server processes which are kept spare
MaxClients … maximum number of server processes allowed to start
MaxRequestsPerChild … maximum number of requests a server process serves
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 20
MaxRequestsPerChild 0
pthread MPM
StartServers … initial number of server processes to start
MinSpareThreads … minimum number of worker threads which are kept spare
MaxSpareThreads … maximum number of worker threads which are kept spare
ThreadsPerChild … constant number of worker threads in each server process
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
perchild MPM
NumServers … constant number of server processes
StartThreads … initial number of worker threads in each server process
MaxThreadsPerChild … maximum number of worker threads in each server process
MaxRequestsPerChild … maximum number of connections per server process (then it dies)
NumServers 5
StartThreads 5
MinSpareThreads 5
MaxSpareThreads 10
MaxThreadsPerChild 20
AcceptMutex fcntl
User www-data
Group www-data
The following directives define some format nicknames for use with
a CustomLog directive (see below).
LogFormat “%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”” combined
LogFormat “%h %l %u %t “%r” %>s %b” common
LogFormat “%{Referer}i -> %U” referer
LogFormat “%{User-agent}i” agent
Global error log.
ErrorLog /var/log/apache2/error.log
Include module configuration:
Include /etc/apache2/mods-enabled/.load
Include /etc/apache2/mods-enabled/.conf
Include all the user configurations:
Include /etc/apache2/httpd.conf
Include ports listing
Include /etc/apache2/ports.conf
Include generic snippets of statements
Include /etc/apache2/conf.d/[^.#]*
#Let’s have some Icons, shall we?
Alias /icons/ “/usr/share/apache2/icons/”
<Directory “/usr/share/apache2/icons”>
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
Set up the default error docs.
Customizable error responses come in three flavors:
1) plain text 2) local redirects 3) external redirects
Some examples:
#ErrorDocument 500 “The server made a boo boo.”
#ErrorDocument 404 /missing.html
#ErrorDocument 404 “/cgi-bin/missing_handler.pl”
#ErrorDocument 402 example.com/subscription_info.html
Putting this all together, we can Internationalize error responses.
We use Alias to redirect any /error/HTTP_.html.var response to
our collection of by-error message multi-language collections. We use
includes to substitute the appropriate text.
You can modify the messages’ appearance without changing any of the
default HTTP_.html.var files by adding the line;
Alias /error/include/ “/your/include/path/”
which allows you to create your own set of files by starting with the
/usr/local/apache2/error/include/ files and
copying them to /your/include/path/, even on a per-VirtualHost basis.
Alias /error/ "/usr/share/apache2/error/"
<Directory "/usr/share/apache2/error">
AllowOverride None
Options IncludesNoExec
AddOutputFilter Includes html
AddHandler type-map var
Order allow,deny
Allow from all
LanguagePriority en es de fr
ForceLanguagePriority Prefer Fallback
</Directory>
ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
ErrorDocument 410 /error/HTTP_GONE.html.var
ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
ErrorDocument 415 /error/HTTP_SERVICE_UNAVAILABLE.html.var
ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
DirectoryIndex index.html index.cgi index.pl index.php index.xhtml
UserDir is now a module
#UserDir public_html
#UserDir disabled root
#<Directory /home/*/public_html>
AllowOverride FileInfo AuthConfig Limit
Options Indexes SymLinksIfOwnerMatch IncludesNoExec
AccessFileName .htaccess
<Files ~ “^.ht”>
Order allow,deny
Deny from all
UseCanonicalName Off
TypesConfig /etc/mime.types
DefaultType text/plain
HostnameLookups Off
IndexOptions FancyIndexing VersionSort
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
This really should be .jpg.
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif …
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
This is from Matty J’s patch. Anyone want to make the icons?
#AddIcon /icons/dirsymlink.jpg ^^SYMDIR^^
#AddIcon /icons/symlink.jpg ^^SYMLINK^^
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ # HEADER RCS CVS *,t
AddEncoding x-compress Z
AddEncoding x-gzip gz tgz
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .et
AddLanguage fr .fr
AddLanguage de .de
AddLanguage el .el
AddLanguage it .it
AddLanguage ja .ja
AddLanguage pl .po
AddLanguage ko .ko
AddLanguage pt .pt
AddLanguage no .no
AddLanguage pt-br .pt-br
AddLanguage ltz .ltz
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .se
AddLanguage cz .cz
AddLanguage ru .ru
AddLanguage tw .tw
AddLanguage zh-tw .tw
LanguagePriority en da nl et fr de el it ja ko no pl pt pt-br ltz ca es sv tw
#AddDefaultCharset ISO-8859-1
AddCharset ISO-8859-1 .iso8859-1 .latin1
AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
AddCharset ISO-8859-3 .iso8859-3 .latin3
AddCharset ISO-8859-4 .iso8859-4 .latin4
AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
AddCharset ISO-2022-JP .iso2022-jp .jis
AddCharset ISO-2022-KR .iso2022-kr .kis
AddCharset ISO-2022-CN .iso2022-cn .cis
AddCharset Big5 .Big5 .big5
For russian, more than one charset is used (depends on client, mostly):
AddCharset WINDOWS-1251 .cp-1251 .win-1251
AddCharset CP866 .cp866
AddCharset KOI8-r .koi8-r .koi8-ru
AddCharset KOI8-ru .koi8-uk .ua
AddCharset ISO-10646-UCS-2 .ucs2
AddCharset ISO-10646-UCS-4 .ucs4
AddCharset UTF-8 .utf8
AddCharset GB2312 .gb2312 .gb
AddCharset utf-7 .utf7
AddCharset utf-8 .utf8
AddCharset big5 .big5 .b5
AddCharset EUC-TW .euc-tw
AddCharset EUC-JP .euc-jp
AddCharset EUC-KR .euc-kr
AddCharset shift_jis .sjis
#AddType application/x-httpd-php .php
#AddType application/x-httpd-php-source .phps
AddType application/x-tar .tgz
To use CGI scripts outside /cgi-bin/:
#AddHandler cgi-script .cgi
To use server-parsed HTML files
<FilesMatch “.shtml(…+)?$”>
SetOutputFilter INCLUDES
If you wish to use server-parsed imagemap files, use
#AddHandler imap-file map
BrowserMatch “Mozilla/2” nokeepalive
BrowserMatch “MSIE 4.0b2;” nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch “RealPlayer 4.0” force-response-1.0
BrowserMatch “Java/1.0” force-response-1.0
BrowserMatch “JDK/1.0” force-response-1.0
The following directive disables redirects on non-GET requests for
a directory that does not include the trailing slash. This fixes a
problem with Microsoft WebFolders which does not appropriately handle
redirects for folders with DAV methods.
BrowserMatch “Microsoft Data Access Internet Publishing Provider” redirect-carefully
BrowserMatch “^WebDrive” redirect-carefully
BrowserMatch “^gnome-vfs” redirect-carefully
BrowserMatch “^WebDAVFS/1.[012]” redirect-carefully
Change the “.your_domain.com” to match your domain to enable.
#<Location /server-status>
SetHandler server-status
Order deny,allow
Deny from all
Allow from .your_domain.com
Allow remote server configuration reports, with the URL of
#<Location /server-info>
SetHandler server-info
Order deny,allow
Deny from all
Include the virtual host configurations:
Include /etc/apache2/sites-enabled/[^.#]*
Si il y a quelque chose d’anormal, n’hésité pas à me le dire…
