Après de nombreuses recherches sur le Net, je me suis finalement décidé à poster ici, peut-être quelqu’un aura-t-il une solution…
Matériel : PC portable Toshiba L350-D
Distrib : Debian 5.0.3 stable
Kernel : 2.6.26-2-686
Problème : j’ai des messages ACPI qui me pourrissent le kern.log
Nov 15 17:20:47 debian-td kernel: [ 259.723315] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:22:10 debian-td kernel: [ 344.958276] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:22:14 debian-td kernel: [ 348.725638] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:25:08 debian-td kernel: [ 527.744895] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:25:12 debian-td kernel: [ 531.377540] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:27:46 debian-td kernel: [ 690.362732] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:27:53 debian-td kernel: [ 698.103863] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:28:11 debian-td kernel: [ 716.798346] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:28:19 debian-td kernel: [ 724.261571] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:20 debian-td kernel: [ 787.915183] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:24 debian-td kernel: [ 791.640111] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:27 debian-td kernel: [ 795.369694] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:31 debian-td kernel: [ 799.087154] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:35 debian-td kernel: [ 802.791780] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:38 debian-td kernel: [ 806.510959] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:42 debian-td kernel: [ 810.246225] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:29:46 debian-td kernel: [ 814.273318] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:32:07 debian-td kernel: [ 961.222821] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:34:56 debian-td kernel: [ 1137.848497] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:35:00 debian-td kernel: [ 1142.088039] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:35:11 debian-td kernel: [ 1153.426247] ACPI: EC: non-query interrupt received, switching to interrupt mode
Nov 15 17:35:36 debian-td kernel: [ 1179.699796] ACPI: EC: non-query interrupt received, switching to interrupt mode
Je sais d’où ça vient, mais je ne sais pas régler le problème !
Je m’explique.
Il faut savoir que la gestion des ventilateurs sur certains portables Toshiba est catastrophique “en standard” sur Linux. Le ventilateur du processeur reste à l’arrêt jusqu’à 80 degrés, puis s’enclenche à fond… et ne s’arrête jamais, à moins d’éteindre la machine.
Ce problème se règle en ajoutant acpi_osi=“Linux” dans /boot/grub/menu.lst :
kernel /boot/vmlinuz-2.6.26-2-686 root=/dev/sda1 ro quiet acpi_osi="Linux"
Ceci permet une bonne gestion des ventilateurs, mais ça me pourrit le kern.log de messages
La même manip. sur une Ubuntu 9.10 ne pose pas de problème, c.à.d. pas de messages dans le kern.log
La question est donc : pensez-vous que c’est un bug dans le kernel 2.6.26-2 ? Quelqu’un connaît-il une solution à ce problème ?
La prochaine version de Debian réglera peut-être ce problème…
Merci.
