depuis que je suis passé de Jessie 8.4 à Jessie 8.7, j’ai ces messages d’erreur au démarrage:
Mar 25 20:33:32 supermicro kernel: [ 10.446750] sd 0:1:0:0: [sda] Unhandled error code
Mar 25 20:33:32 supermicro kernel: [ 10.446755] sd 0:1:0:0: [sda] Unhandled error code
Mar 25 20:33:32 supermicro kernel: [ 10.446762] sd 0:1:0:0: [sda]
Mar 25 20:33:32 supermicro kernel: [ 10.446765] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
Mar 25 20:33:32 supermicro kernel: [ 10.446768] sd 0:1:0:0: [sda] CDB:
Mar 25 20:33:32 supermicro kernel: [ 10.446771] ATA command pass through(16): 85
Mar 25 20:33:32 supermicro kernel: [ 10.446781] sd 0:1:0:0: [sda]
Mar 25 20:33:32 supermicro kernel: [ 10.446786] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
Mar 25 20:33:32 supermicro kernel: [ 10.446790] sd 0:1:0:0: [sda] CDB:
Mar 25 20:33:32 supermicro kernel: [ 10.446793] ATA command pass through(16): 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
Mar 25 20:33:32 supermicro kernel: [ 10.446827] 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
Mar 25 20:33:32 supermicro kernel: [ 10.547826] sd 0:1:2:0: [sdc] Unhandled error code
Mar 25 20:33:32 supermicro kernel: [ 10.547836] sd 0:1:2:0: [sdc]
Mar 25 20:33:32 supermicro kernel: [ 10.547840] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
Mar 25 20:33:32 supermicro kernel: [ 10.547844] sd 0:1:2:0: [sdc] CDB:
Mar 25 20:33:32 supermicro kernel: [ 10.547847] ATA command pass through(16): 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
Mar 25 20:33:32 supermicro kernel: [ 10.768384] sd 0:1:2:0: [sdc] Unhandled error code
Mar 25 20:33:32 supermicro kernel: [ 10.768393] sd 0:1:2:0: [sdc]
Mar 25 20:33:32 supermicro kernel: [ 10.768396] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
Mar 25 20:33:32 supermicro kernel: [ 10.768400] sd 0:1:2:0: [sdc] CDB:
Mar 25 20:33:32 supermicro kernel: [ 10.768403] ATA command pass through(16): 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
Mar 25 20:33:32 supermicro kernel: [ 10.823520] sd 0:1:1:0: [sdb] Unhandled error code
Mar 25 20:33:32 supermicro kernel: [ 10.823530] sd 0:1:1:0: [sdb]
Mar 25 20:33:32 supermicro kernel: [ 10.823533] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
Mar 25 20:33:32 supermicro kernel: [ 10.823537] sd 0:1:1:0: [sdb] CDB:
Mar 25 20:33:32 supermicro kernel: [ 10.823540] ATA command pass through(16): 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
Mar 25 20:33:32 supermicro kernel: [ 10.838471] sd 0:1:2:0: [sdc] Unhandled error code
Mar 25 20:33:32 supermicro kernel: [ 10.838481] sd 0:1:2:0: [sdc]
Mar 25 20:33:32 supermicro kernel: [ 10.838484] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
Mar 25 20:33:32 supermicro kernel: [ 10.838488] sd 0:1:2:0: [sdc] CDB:
Mar 25 20:33:32 supermicro kernel: [ 10.838491] ATA command pass through(16): 85 06 20 00 05 00 fe 00 00 00 00 00 00 40 ef 00
Est-ce normal, car mon système fonctionne correctement.
Willy.
