Mise à jour bloquée
la mise à jour d’une Sueeze bloque sur cet écran/message
krb5 (1.8+dfsg~alpha1-1) unstable; urgency=low
This version of MIT Kerberos disables DES and 56-bit RC4 by default.
These encryption types are generally regarded as weak; defeating them
is well within the expected resources of some attackers. However,
some applications, such as OpenAFS or Kerberized NFS, still rely on
DES. To re-enable DES support add allow_weak_crypto=true to the
libdefaults section of /etc/krb5.conf
– Sam Hartman hartmans@debian.org Fri, 08 Jan 2010 22:41:14 -0500
openssh (1:5.4p1-2) unstable; urgency=low
Smartcard support is now available using PKCS#11 tokens. If you were
previously using an unofficial build of Debian’s OpenSSH package with
OpenSC-based smartcard support added, then note that commands like
’ssh-add -s 0’ will no longer work; you need to use ‘ssh-add -s
/usr/lib/opensc-pkcs11.so’ instead.
– Colin Watson cjwatson@debian.org Sat, 10 Apr 2010 01:08:59 +0100
vlc (1.0.6-1) unstable; urgency=low
The rtmp access module has been removed by upstream as it is deemed too buggy.
– Christophe Mutricy xtophe@videolan.org Fri, 23 Apr 2010 11:49:18 +0200
/tmp/tmp_lHCU- (END)
la dernière ligne surlignée en noir clignote et plus rien ne se passe, la mise à jour est bloquée
Je ne sais pas top comment me tirer de cette ornière
Je suis pas bien sur d’avoir tout bien lu mais il me semble que taper q quitte le message d’avertissement ( le " changellog" d’une des applis ) et fait continuer la màj :wink:
EDIT = vérifié ce matin même ( 6/5/2010 ) avec une mise à jour de cron : c’est bien la touche q
