Vers 5/6 heures ? de travail ?
Aurais-tu un disque externe ou interne susceptible d’accueillir tes sauvegardes / et /home ? ![]()
Et de quelle capacité et filesystem (ext3, ext4 … ?)
Autre chose, sur ta machine local rsync est-il installé ?
$ apt-cache policy rsync
Afin que puisse bénéficier de cette sauvegarde il te faut lancer en tant que root la création d’une clé sur ta machine local.
Nota : ceci est relativement long, alors lances cette dernière dès que possible.
Machine local : Passes en root > #
# mkdir /root/.ssh && cd /root/.ssh
Création d’une clé privée/public, avec une passphrase.
# time ssh-keygen -b 'echo $[1024*16]'
Fais-moi signe quand ceci sera terminé.
Pour ma part, une simulation de la sauvegarde de ta racine :
[code]
[09:42:04] ~ # time rsync -arvzin --stats --partial --del --exclude-from=/root/exclureAR -e ssh root@xxx.xxx.xxx.xxx:/ /mnt/AntoninC_racine/
The authenticity of host ‘xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx)’ can’t be established.
RSA key fingerprint is yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added ‘xxx.xxx.xxx.xxx’ (RSA) to the list of known hosts.
root@xxx.xxx.xxx.xxx’s password:
receiving incremental file list
.d…t… ./
f+++++++++ .lesshst
f+++++++++ .nano_history
f+++++++++ .viminfo
f+++++++++ .vzfifo
f+++++++++ var/www/webalizer/usage_201309.html
f+++++++++ var/www/webalizer/usage_201310.html
f+++++++++ var/www/webalizer/webalizer.hist
Number of files: 4,679,796 (reg: 4,642,222, dir: 30,132, link: 7,404, special: 38)
Number of created files: 4,679,795 (reg: 4,642,222, dir: 30,131, link: 7,400, dev: 4, special: 38)
Number of regular files transferred: 4,642,222
Total file size: 26,308,533,502 bytes
Total transferred file size: 26,308,383,363 bytes
Literal data: 0 bytes
Matched data: 0 bytes
File list size: 75,659,199
File list generation time: 0.002 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 14,069,563
Total bytes received: 94,019,634
sent 14,069,563 bytes received 94,019,634 bytes 117,297.01 bytes/sec
total size is 26,308,533,502 speedup is 243.40 (DRY RUN)
real 15m22.254s
user 2m18.280s
sys 2m16.964s
[09:57:41] ~ #
[09:58:25] ~ # [/code]
Je t’expliquerai la mise en place (rsync) depuis (ton) local en temps voulu.
* edit *
Mon réveil, biologique … Plutôt 5 heures. ![]()
J’ai un DDE de 2To avec énormément de donnée à l’intérieur, 1To je crois et si je ne me trompe pas il est en NTFS ou en FATX. (Je ne sais pas si c’est ça que tu appelles le filesystem ?). Je n’ai rien sous la main puisque je suis dans les locaux de ma formation.
Sur ma local je regarderai ce soir si rsync est installé, mais je ne pense pas, à moins que ce dernier soit inclue par défaut dans les dépôts de Wheezy.
En ce qui concerne la clé je ne peux pas le faire avec la commande :
[quote=“AntoninC”]J’ai un DDE de 2To avec énormément de donnée à l’intérieur, 1To je crois et si je ne me trompe pas il est en NTFS ou en FATX.
?[/quote]
Tu connecteras ton disque externe, puis donnera le retour suivant :
Et :
filesystem > system de fichier >> ext2, ext3, ext4, ntfs, fat32, fat16, …
Sous Wheezy, rsync est installé nativement.
ssh-keygen -t rsa : si tu veux.
Heeu … Ceci m’interpelle, un tant soit peu …
De quel type de serveur (location) s’agit-il dans ton cas ?
[quote=“NUXIT”]Sauvegardes Automatiques
Votre serveur dédié est automatiquement sauvegardé par NUXIT !
En cas de défaillance matérielle grave, d’erreur de manipulation ou de piratage du serveur, votre activité repart facilement et rapidement ![/quote]
[quote]Plan de Reprise d’Activité : nous réalisons régulièrement des sauvegardes automatiques de votre serveur.
Sur simple demande, nous restaurons en un clic votre serveur dans un état antérieur.
Une solution simple et efficace de PRA qui permet de faire repartir votre activité très rapidement en cas de sinistre majeur (piratage du serveur, incident logiciel, erreur de manipulation, etc.)
Standard : un point de restauration est crée chaque semaine
Professionnel : un point de restauration est crée chaque jour[/quote]
[quote]Espace FTP de backup : Parallels® Plesk Panel vous permet de planifier des sauvegardes externalisées qui auront l’avantage d’être stockées sur un serveur FTP distant.
Non seulement vous ne gaspillez pas votre espace disque local, mais en plus vos sauvegardes sont à l’abri sur un serveur indépendant. En un clic, vous restaurez facilement un site ou une base de données.[/quote]
As-tu contacté ces derniers en fonction de l’offre dont tu disposes ?
ps : je n’ai pas approfondi le sujet, hein …
J’avais totalement oublié que j’avais accès à cette option. Pour ce qui est de mon seveur je suis en standard, donc une sauvegarde par semaine. En réfléchissant bien je me souviens avoir déjà fait une demande de restauration de mon serveur en 2010 si je ne me trompe pas.
Il m’avait été fait par par Ticket que ce genre de restauration n’était effectuée qu’une seule fois gratuitement étant donné le temps et la ram que cela peut prendre. Est-ce que leur politique de fonctionnement à changé depuis je n’en sais rien.
EDIT1
Et puis bien entendu que je les ai contactés; ils m’ont conseillés de faire une MAJ du plesk (infructueuse) ou de carrément ré-installer le serveur. Acheter un nouveau mois d’abonnement et faire un transfert dns, fichiers etc… ![]()
EDIT2
Et puis surtout ce qui est important c’est les sauvegarde de mes bases de donnée pour les sites ainsi que leurs fichiers.
Re,
[quote=“AntoninC”]En réfléchissant bien je me souviens avoir déjà fait une demande de restauration de mon serveur en 2010 si je ne me trompe pas.
Ne serait-ce pas ceci …
[quote][11:34:41] ~ # ll /etc/vz/reinstall.d/
total 8.0K
lrwxrwxrwx 1 root root 28 2010-03-10 09:39 51.plesk.reinstall.license.sh -> 50.plesk.reinstall.server.sh
-rwxr-xr-x 1 root root 1.9K 2009-12-30 01:30 50.plesk.reinstall.server.sh
-rwxr-xr-x 1 root root 2.0K 2009-12-30 01:30 52.plesk.reinstall.clients.sh
[11:34:47] ~ # [/quote]
Cela vaudrait très certainement la peine de savoir ce qu’il t’en coûterait à l’heure actuelle.
Car, en l’absence de filesystem … je ne vois pas trop comment je vais pouvoir chrooter cette sauvegarde
et tenter de rétablir (en local) la situation, sereinement …
[11:43:16] ~ # fdisk -l
cannot open /proc/partitions
[11:43:20] ~ #
[11:43:21] ~ # cat /etc/fstab
proc /proc proc defaults 0 0
none /dev/pts devpts rw 0 0
[11:43:29] ~ #
[11:43:30] ~ # cat /etc/mtab
/dev/vzfs / vzfs rw,relatime 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
tmpfs /lib/init/rw tmpfs rw,nosuid,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev,relatime 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime 0 0
tmpfs /opt/psa/handlers/before-local tmpfs rw,relatime 0 0
tmpfs /opt/psa/handlers/before-queue tmpfs rw,relatime 0 0
tmpfs /opt/psa/handlers/before-remote tmpfs rw,relatime 0 0
tmpfs /opt/psa/handlers/info tmpfs rw,relatime 0 0
tmpfs /opt/psa/handlers/spool tmpfs rw,relatime 0 0
[11:43:38] ~ #
[11:43:39] ~ #
[11:43:40] ~ # mount
/dev/vzfs on / type vzfs (rw,relatime)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /lib/init/rw type tmpfs (rw,nosuid,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,relatime)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime)
tmpfs on /opt/psa/handlers/before-local type tmpfs (rw,relatime)
tmpfs on /opt/psa/handlers/before-queue type tmpfs (rw,relatime)
tmpfs on /opt/psa/handlers/before-remote type tmpfs (rw,relatime)
tmpfs on /opt/psa/handlers/info type tmpfs (rw,relatime)
tmpfs on /opt/psa/handlers/spool type tmpfs (rw,relatime)
[11:43:44] ~ #
Serait-ce dû à l’avortement volontaire (Relation --> Chaise/Clavier <-- Toi) lors des différentes tentatives d’upgrade de Lenny -> Squeeze (échec) -> Wheezy (échec) -> retour Lenny … cela me paraît bien plus que probable !
Je vais (très certainement) prendre la liberté d’ouvrir un autre fil, concernant l’absence de tout system de fichier, dans ton cas … Parce que là …
C’est en cours, en local (chez moi).
[quote][10:08:49] ~ # time rsync -arvzi --stats --partial --del --exclude-from=/root/exclureAR -e ssh root@xx.xx.xx.xx
root@xx.xx.xx.xx’s password:
.d…t… ./
f+++++++++ .lesshst
f+++++++++ .viminfo
f+++++++++ .vzfifo
cL+++++++++ aquota.group -> /proc/vz/vzaquota/00000018/aquota.group
cL+++++++++ aquota.user -> /proc/vz/vzaquota/00000018/aquota.user
Bon et bien j’ai toujours le droit à ces sauvegardes, une fois par semaine avec restauration à souhait (dans la limite du raisonnable). Donc je n’ai plus à faire de sauvegarde. Donc pas besoin de configurer le filesystem (y’en a pas mdr).
Il faut juste que je mette mon serveur totalement à jour (ce que tu es en train de faire
) et que je mette à jour les dernières versions de Plesk et de Mumin.
Je n’ai pas d’infogérance dans mon package mais en tout cas le faite d’avoir une sauvegarde hebdomadaire est plutôt sympa. Maintenant je le sais.
Merci de consacré ta journée pour moi, c’est inconcevable et je t’en remercie.
EDIT : il ne me semble pas avoir avorté une MAJ, j’ai plutôt été stoppé par des erreurs lol (je ne suis pas excusable). Et tu peux prendre toute la liberté que tu veux tant que mes sites fonctionnent.
Re,
J’ai exclus le répertoire /var/www/vhosts trop conséquent et sans intérêt pour ce que je veux faire.
[quote]…
f+++++++++ var/qmail/queue.old/mess/19/102850936
f+++++++++ var/qmail/queue.old/mess/19/102850959^C
rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at io.c(521) [receiver=3.1.0]
rsync error: unexplained error (code 130) at rsync.c(632) [generator=3.1.0]
real 238m42.920s
user 6m55.116s
sys 5m15.460s
[14:08:20] ~ #
^Crsync error: unexplained error (code 130) at rsync.c(632) [generator=3.1.0]
real 84m30.619s
user 3m16.124s
sys 2m25.820s
[15:33:13] ~ #
f+++++++++ var/www/webalizer/usage_201308.html
Number of files: 221,121 (reg: 189,690, dir: 24,112, link: 7,282, special: 37)
Number of created files: 3,084 (reg: 1,963, dir: 82, link: 1,038, dev: 1)
Number of regular files transferred: 2,121
Total file size: 8,339,906,919 bytes
Total transferred file size: 470,930,478 bytes
Literal data: 17,364,946 bytes
Matched data: 453,566,577 bytes
File list size: 2,396,495
File list generation time: 0.001 seconds
Total bytes sent: 730,259
Total bytes received: 12,893,409
sent 730,259 bytes received 12,893,409 bytes 73,442.95 bytes/sec
total size is 8,339,906,919 speedup is 612.16
real 3m5.773s
user 0m14.760s
sys 0m21.328s
[16:36:00] ~ # [/quote]
Il te faudra compter plus de 7 h 00 pour ta première sauvegarde.
C’te blague …
[quote]Filesystem Size Used Avail Use% Mounted on
/dev/vzfs 80G 40G 41G 50% /
Filesystem ->> vzfs que je ne connaissais/(oublier
) pas.
Me reste à trouver comment monter le bouzin. ![]()
[17:14:25] ~ # du -h --max-depth=1 /mnt/AntoninC_racine | sort -rh
25G /mnt/AntoninC_racine
21G /mnt/AntoninC_racine/var
1,7G /mnt/AntoninC_racine/opt
1,6G /mnt/AntoninC_racine/usr
95M /mnt/AntoninC_racine/home
11M /mnt/AntoninC_racine/root
11M /mnt/AntoninC_racine/etc
7,2M /mnt/AntoninC_racine/lib
4,9M /mnt/AntoninC_racine/sbin
4,6M /mnt/AntoninC_racine/bin
12K /mnt/AntoninC_racine/tmp
4,0K /mnt/AntoninC_racine/srv
4,0K /mnt/AntoninC_racine/selinux
4,0K /mnt/AntoninC_racine/mnt
4,0K /mnt/AntoninC_racine/media
4,0K /mnt/AntoninC_racine/initrd
4,0K /mnt/AntoninC_racine/boot
[17:17:44] ~ #
Voici les informations concernant mon DDE
[quote]root@AntoninLinux:/home/antonin# fdisk -l
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00002c97
/dev/sda1 * 2048 476231679 238114816 83 Linux
/dev/sda2 476233726 488396799 6081537 5 Extended
/dev/sda5 476233728 488396799 6081536 82 Linux swap / Solaris
Disk /dev/sdb: 2000.4 GB, 2000365289472 b
255 heads, 63 sectors/track, 243197 cylinders, total 3906963456 sectors
Disk identifier: 0xa7ef7cd0
/dev/sdb1 2 3906963455 1953481727 7 HPFS/NTFS/exFAT[/quote]
[quote]root@AntoninLinux:/home/antonin# df -h
Sys. fich. Taille Util. Dispo Uti% Monté sur
rootfs 224G 20G 193G 10% /
udev 10M 0 10M 0% /dev
tmpfs 305M 816K 304M 1% /run
/dev/disk/by-uuid/361314f8-1d12-442e-a0d1-204305750f2b 224G 20G 193G 10% /
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 1,8G 80K 1,8G 1% /run/shm
Laisses ton disque externe branché et relances un df -h.
Maîtrises tu Gparted un tant soit peu ?
As-tu lancé ssh-keygen ?
[quote]antonin@AntoninLinux:~$ df -h
tmpfs 305M 808K 304M 1% /run
tmpfs 1,8G 4,4M 1,8G 1% /run/shm
Gparted me dis quelque chose est-ce comme diskpart sous win ?
Je viens d’executer
C’est très rapide
Je n’ai pas renseigné de passphrase rien du tout j’aurai juste à envoyer ma clé sur mon serveur c’est ça ?
[quote=“AntoninC”]Gparted me dis quelque chose est-ce comme diskpart sous win ?
M$ je ne sais plus ce que c’est, alors diskpart encore moins.
Il te faudra, soit :
-Te procuré un autre disque externe.
-Te débrouillé avec Gparted pour faire de la place, dans la mesure du possible.
Par contre, concernant le partitionnement de ce dernier (filesystem -> vzfs) je ne sais toujours pas de quoi il en retourne … ![]()
Oui, un copié/coller dans le fichier (en dessous/dessus de celle que j’ai déposé) /root/.ssh/authorized_keys puis relances le service ssh pour la prise en compte.
Pour la sauvegarde je vais me débrouiller avec mon serveur pour avoir accès aux copies. Je peux les télécharger il me semble. Donc en fait se sera encore plus simple. Tu en es à quel niveau ? Je vais m’occuper maintenant d’ajouter ma clé.
En stand-bye, je n’ai guère de solution à cette heure concernant ce filesystem “Parallels Virtuozzo” (?) vzfs pour tester quoique ce soit.
Et, ce n’est pas à moi de prendre la responsabilité de tenter l’upgrade sur ton serveur.
Mon conseil : Une sauvegarde local (chez toi) (et destruction de celles en ma possession) , et seulement après, une demande auprès de ton fournisseur pour une restauration en date du …
Sans oublié le nettoyage (/root/.ssh/; .bashrc; sshd_config), changement de mdp, bien sûr.
À toi de voir … on peut également poursuivre en MP, bien sûr. ![]()
* edit *
Post-scriptum : Je devrai peut-être songer à me lancer dans l’infogérance, moi …
Tu me demandais (par MP) comment procéder à la mise à jour, ceci avec et sans autre modification des fichiers que j’ai retouchés dans ce but.
[color=#BF0000]/!\ Tu n’as actuellement aucune sauvegarde local /![/color]
Te voici averti. Et, de part ce fait, tu assumes.
À l’heure actuelle.
[19:37:55] ~ # apt-get -t stable -s install libc6 libc6-i686
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
glibc-doc locales
The following NEW packages will be installed:
libc6-i686
The following packages will be upgraded:
libc6
1 upgraded, 1 newly installed, 0 to remove and 441 not upgraded.
2 not fully installed or removed.
Inst libc6 [2.7-18lenny7] (2.13-38 Debian:7.2/stable)
Conf libc6 (2.13-38 Debian:7.2/stable)
Inst libc6-i686 (2.13-38 Debian:7.2/stable)
Conf clamav-base (0.97.8+dfsg-1 Debian:7.2/stable)
Conf nscd (2.13-38 Debian:7.2/stable)
Conf libc6-i686 (2.13-38 Debian:7.2/stable)
[19:37:57] ~ #
ps : Je te suis !
À mon avis cela devrait passer, mais dans le cas ou … Protèges tes arrières. ![]()
< @LaVoix Paix à son âme > ![]()
Ce fut bref cela ne fonctionne pas lol plus de peur que de mal
Ok ! On reprend demain, là, j’en ai ma claque pour ce soir, mais ne lâche pas l’affaire en cours … ![]()
08:07:29] ~ #
[08:07:29] ~ # apt-get upgrade
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[08:07:32] ~ #
[08:07:33] ~ #
[08:07:34] ~ # acp libc6
libc6:
Installed: 2.7-18lenny7
Candidate: 2.7-18lenny7
Version table:
*** 2.7-18lenny7 0
500 http://archive.debian.org lenny/main Packages
100 /var/lib/dpkg/status
[08:07:50] ~ #
[08:07:52] ~ #
[08:11:54] ~ # apt-get -s install aptitude
The following extra packages will be installed:
libcwidget3 libept0 libsigc++-2.0-0c2a libxapian15
Suggested packages:
tasksel debtags libcwidget-dev xapian-tools
Recommended packages:
aptitude-doc-en aptitude-doc libparse-debianchangelog-perl
aptitude libcwidget3 libept0 libsigc++-2.0-0c2a libxapian15
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Inst libsigc++-2.0-0c2a (2.0.18-2 Debian:5.0.10/oldstable)
Inst libcwidget3 (0.5.12-4 Debian:5.0.10/oldstable)
Inst libxapian15 (1.0.7-4 Debian:5.0.10/oldstable)
Inst libept0 (0.5.22 Debian:5.0.10/oldstable)
Inst aptitude (0.4.11.11-1~lenny2 Debian:5.0.10/oldstable)
Conf libsigc++-2.0-0c2a (2.0.18-2 Debian:5.0.10/oldstable)
Conf libcwidget3 (0.5.12-4 Debian:5.0.10/oldstable)
Conf libxapian15 (1.0.7-4 Debian:5.0.10/oldstable)
Conf libept0 (0.5.22 Debian:5.0.10/oldstable)
Conf aptitude (0.4.11.11-1~lenny2 Debian:5.0.10/oldstable)
[08:11:58] ~ #
Encore quelques petites retouches à faire …
* edit *
08:19:00] ~ #
[08:19:01] ~ # apt-get install locales
locales
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 4432kB of archives.
After this operation, 11.9MB of additional disk space will be used.
Get:1 http://archive.debian.org lenny/main locales 2.7-18lenny7 [4432kB]
Fetched 4432kB in 3s (1430kB/s)
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "fr_FR.UTF-8",
LC_ALL = (unset),
LANG = "fr_FR.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Can't exec "locale": No such file or directory at /usr/share/perl5/Debconf/Encoding.pm line 16.
Use of uninitialized value $Debconf::Encoding::charmap in scalar chomp at /usr/share/perl5/Debconf/Encoding.pm line 17.
Preconfiguring packages ...
dpkg: `ldconfig' not found on PATH.
dpkg: 1 expected program(s) not found on PATH.
NB: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin.
E: Sub-process /usr/bin/dpkg returned an error code (2)
[08:19:11] ~ #
[08:19:37] ~ # acp locales
locales:
Installed: (none)
Version table:
2.11.3-4 0
2.7-18lenny7 0
[08:19:44] ~ #
[08:19:56] ~ # acp aptitude
aptitude:
Installed: (none)
Candidate: 0.4.11.11-1~lenny2
Version table:
0.4.11.11-1~lenny2 0
[08:20:00] ~ #
[08:28:32] ~ # apt-get install locales
locales
Need to get 0B/4432kB of archives.
LC_ALL = (unset),
[08:28:41] ~ #
[08:29:23] ~ # echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/root/pear/bin
[08:29:25] ~ # ![]()
