Hello
bon j’ai plus acès a a touche Alt-Gr et il on masacrer le dpkg-reconfigure -a car il ne ma pas permis de rechoisir de modifer le clavier:
ce probleme est présent dans un tty ou sous X
# dpkg-reconfigure -a
Stopping process accounting: Turning off process accounting.
acct.
Starting process accounting: Turning on process accounting, file set to '/var/log/account/pacct'.
acct.
Disabling power management....
update-rc.d: warning: acpi-support stop runlevel arguments (1) do not match LSB Default-Stop values (0 1 6)
Checking battery state....
Stopping ACPI services....
Starting ACPI services....
ln: création d'un lien symbolique `/usr/lib/libstlport_gcc.so': Le fichier existe
# cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildd@saens) Sat May 12 22:20:45 UTC 2007
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (randy@juliet2) Sat May 12 15:26:42 PDT 2007
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
# Load "dbe"
# Load "extmod"
# Load "freetype"
# Load "glx"
EndSection
Section "ServerFlags"
Option "Xinerama" "0"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "ch"
Option "XkbVariant" "fr"
#Option "XkbOptions" "lv3:ralt_switch"
les log de la mise a jours et list des paquet (les 2 son en principe semblable l’un fait avec screen l’autre avec script) histoir de pas pourrir le forum.
http://www.panthere-noire.com/fichier/updatesidlog/
uname -a
Linux wboost 2.6.30-2-686-bigmem #1 SMP Sat Sep 26 02:30:18 UTC 2009 i686 GNU/Linux
vu que ce que je connaissait a complètement changer je ne voit pas ou sa peux coinçer ?
