Je viens de monter une machine Debian v6 sus VMWare pour pouvoir faire ma dernière activité pour mon examen.
J’ai décidé de faire un contrôleur de domaine avec Samba.
J’ai installé Samba puis suivi le tutoriel suivant:
tux-planet.fr/un-controleur- … vec-samba/
Une fois configurer comme il est dit, je fais un testparm qui me renvoi:
[code]root@debian:/home/arnaud# testparm
Load smb config files from /etc/samba/smb.conf
rlimit_max: rlimit_max (1024) below minimum Windows limit (16384)
Processing section "[homes]"
Processing section "[netlogon]"
Processing section "[public]"
Processing section "[private]"
Processing section "[printers]"
Processing section "[print$]"
Loaded services file OK.
Server role: ROLE_DOMAIN_PDC
Press enter to see a dump of your service definitions
[global]
workgroup = CNED
server string = %h
obey pam restrictions = Yes
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = Enter\snew\s\spassword:* %n\n Retype\snew\s\spassword:* %n\n password\supdated\ssuccessfully .
unix password sync = Yes
syslog = 0
log file = /var/log/samba/log.%m
max log size = 1000
name resolve order = lmhosts host wins bcast
time server = Yes
add user script = /usr/sbin/useradd -d /srv/samba/home/%u -G dom_user -s /bin/false -m %u
add machine script = /usr/sbin/useradd -d /dev/null -G dom_pc -s /bin/false -M %m$
logon script = logon.bat
domain logons = Yes
preferred master = Yes
domain master = Yes
dns proxy = No
panic action = /usr/share/samba/panic-action %d
[homes]
comment = Home Directories
valid users = %S
read only = No
create mask = 0700
directory mask = 0700
browseable = No
[netlogon]
comment = Network Logon Service
path = /home/samba/netlogon
write list = @dom_admin
[public]
comment = Repertoir public sur le serveur
path = /srv/samba/public
read only = No
guest ok = Yes
[private]
comment = Repertoire private du serveur
path = /srv/samba/private
valid users = @dom_users
read only = No
[printers]
comment = All Printers
path = /var/spool/samba
create mask = 0700
printable = Yes
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
Donc je ne vois pas de soucis à première vue.
Je vais donc sur ma machine sous W7, fait un ping sur l’ip de debian, qui réussit. Mais là, impossible de le joindre au domaine…
Je met “CNED” dans domaine, puis il me demande un ID/MDP, je met root et le MDP correspondant puis il me renvoi:
L'erreur suivant s'est produite lors de la tentative de jonction au domaine "CNED" :
Le domaine spécifié n'existe pas ou n'a pas pu être contacté.
J’ai bien modifié la clé de registre qu’il fallait.
Une idée?
