et merci pour ces premières réponses. Je me permets de décliner la proposition de prendre le contrôle de la machine à distance : ma connaissance en réseaux est nettement insuffisante pour que j’envisage de la mettre en oeuvre.
@ vohu : il s’agit d’un freeze (la description d’un kernel panic lue sur wikipedia ne correspond pas). Les deux paquets en question ne sont pas installés.
@ MicP. Voici le contenu (que je ne sais pas interpréter) des fichiers .xsessions-errors :
[code]/etc/gdm3/Xsession: Beginning session setup…
localuser:anonyme being added to access control list
openConnection: connect: Aucun fichier ou dossier de ce type
cannot connect to brltty at :0
Failed to connect to the VirtualBox kernel service
gnome-keyring-daemon: insufficient process capabilities, unsecure memory might get used
GNOME_KEYRING_CONTROL=/home/anonyme/.cache/keyring-aDcymD
GPG_AGENT_INFO=/home/anonyme/.cache/keyring-aDcymD/gpg:0:1
SSH_AUTH_SOCK=/home/anonyme/.cache/keyring-aDcymD/ssh
(gnome-panel:3614): Gtk-CRITICAL **: gtk_accelerator_parse_with_keycode: assertion `accelerator != NULL’ failed
** (gnome-panel:3614): WARNING **: Unable to parse mouse modifier ‘(null)’
(gnome-settings-daemon:3572): color-plugin-WARNING **: failed to get edid: unable to get EDID for output
(gnome-settings-daemon:3572): color-plugin-WARNING **: unable to get EDID for xrandr-default: unable to get EDID for output
(gnome-settings-daemon:3572): color-plugin-WARNING **: failed to reset xrandr-default gamma tables: gamma size is zero
vmware-user: could not open /proc/fs/vmblock/dev
Initializing tracker-miner-fs…
Tracker-Message: Setting up monitor for changes to config file:’/home/anonyme/.config/tracker/tracker-miner-fs.cfg’
Starting log:
File:’/home/anonyme/.local/share/tracker/tracker-miner-fs.log’
Initializing tracker-store…
Tracker-Message: Setting up monitor for changes to config file:’/home/anonyme/.config/tracker/tracker-store.cfg’
Starting log:
File:’/home/anonyme/.local/share/tracker/tracker-store.log’
(tracker-store:3736): Tracker-CRITICAL **: D-Bus service name:‘org.freedesktop.Tracker1’ is already taken, perhaps the daemon is already running?
** Message: applet now removed from the notification area
(gnome-panel:3614): GLib-GObject-WARNING **: /tmp/buildd/glib2.0-2.33.12+really2.32.4/./gobject/gsignal.c:2459: signal size_request' is invalid for instance0x1654240’
** Message: applet now embedded in the notification area[/code]
et .xsessions-errors.old :
GNOME_KEYRING_CONTROL=/home/anonyme/.cache/keyring-tc35CH
GPG_AGENT_INFO=/home/anonyme/.cache/keyring-tc35CH/gpg:0:1
SSH_AUTH_SOCK=/home/anonyme/.cache/keyring-tc35CH/ssh
(gnome-settings-daemon:3603): color-plugin-WARNING **: failed to get edid: unable to get EDID for output
(gnome-panel:3646): Gtk-CRITICAL **: gtk_accelerator_parse_with_keycode: assertion `accelerator != NULL’ failed
** (gnome-panel:3646): WARNING **: Unable to parse mouse modifier ‘(null)’
(gnome-settings-daemon:3603): color-plugin-WARNING **: unable to get EDID for xrandr-default: unable to get EDID for output
(gnome-settings-daemon:3603): color-plugin-WARNING **: failed to reset xrandr-default gamma tables: gamma size is zero
Starting log:
Starting log:
(gnome-panel:3646): GLib-GObject-WARNING **: /tmp/buildd/glib2.0-2.33.12+really2.32.4/./gobject/gsignal.c:2459: signal size_request' is invalid for instance0x2637240’
(gnome-settings-daemon:3603): PackageKit-WARNING **: couldn’t parse execption ‘GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._pk_5ftransaction_5ferror.Code4: GetDistroUpgrades not supported by backend’, please report
(gnome-settings-daemon:3603): updates-plugin-WARNING **: failed to get upgrades: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._pk_5ftransaction_5ferror.Code4: GetDistroUpgrades not supported by backend
(notification-daemon:3724): Gtk-WARNING : gtk_widget_size_allocate(): attempt to allocate widget with width -23 and height 27
Avertissement du gestionnaire de fenêtres : Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x2c00003 (Mise à jo)
Avertissement du gestionnaire de fenêtres : meta_window_activate called by a pager with a 0 timestamp; the pager needs to be fixed.
Avertissement du gestionnaire de fenêtres : Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x1c00003 (S’authenti)
Initializing nautilus-gdu extension
[1410611457,000,xklavier.c:xkl_engine_start_listen/] The backend does not require manual layout management - but it is provided by the application
[1410611458,000,gkbd-status.c:gkbd_status_set_current_page_for_group/] Page for group 0 is not ready
[1410612212,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612212,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612218,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612319,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612343,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612345,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612355,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612357,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612359,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612360,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612363,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612365,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612375,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612375,000,xklavier_evt_xkb.c:xkShutting down nautilus-gdu extension
![1410612376,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612377,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410612379,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 0 is not equal to the current group from the event: 1
![1410613261,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 1 is not equal to the current group from the event: 0
![1410613266,000,xklavier_evt_xkb.c:xkl_xkb_process_x_event/] ATTENTION! Currently cached group 1 is not equal to the current group from the event: 0
! Message: applet now removed from the notification area
(notification-daemon:3724): Gdk-WARNING **: notification-daemon: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(gnome-sound-applet:3722): Gdk-WARNING **: gnome-sound-applet: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(gnome-fallback-mount-helper:3744): Gdk-WARNING **: gnome-fallback-mount-helper: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(bluetooth-applet:3738): Gdk-WARNING **: bluetooth-applet: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(polkit-gnome-authentication-agent-1:3746): Gdk-WARNING **: polkit-gnome-authentication-agent-1: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(gdu-notification-daemon:3729): Gdk-WARNING **: gdu-notification-daemon: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(evolution-alarm-notify:3754): Gdk-WARNING **: evolution-alarm-notify: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(gnome-screensaver:3737): Gdk-WARNING **: gnome-screensaver: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
(nm-applet:3725): Gdk-WARNING **: nm-applet: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
g_dbus_connection_real_closed: Remote peer vanished with error: Erreur lors de la réception du message : Connexion ré-initialisée par le correspondant (g-io-error-quark, 0). Exiting.
Received signal:15->'Complété’
g_dbus_connection_real_closed: Remote peer vanished with error: Underlying GIOStream returned 0 bytes on an async read (g-io-error-quark, 0). Exiting.
OK
(tracker-miner-fs:3723): GVFS-RemoteVolumeMonitor-WARNING **: Owner :1.11 of volume monitor org.gtk.Private.GduVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
(tracker-miner-fs:3723): GLib-GIO-CRITICAL **: Error while sending AddMatch() message: La connexion est fermée
OK
Je précise que je viens de volontairement provoquer un tel freeze ; en particulier, l’accès à une invite de session via Ctrl + Alt +F2 était impossible.
Comme je suis devant le poste, je vais tenter de fouiller un peu plus dans les logs.
