Mon clavier a fourché (dans un de mes posts seulement), je voulais parler de Xgl, bien entendu.
[quote=“misaine”]essaye cette ligne de commande
compiz --replace --sm-disable --ignore-desktop-hints ccp
(c’est la commande utilisée par fusion-icon)[/quote]
Le prompt continue à gueuler, de plus, l’option ignore-desktop-hints semble inconnue.
[code]eric@travail:~$ compiz --replace --sm-disable --ignore-desktop-hints ccp
Checking for Xgl: not present.
xset q doesn’t reveal the location of the log file. Using fallback /var/log/Xorg.0.log
Detected PCI ID for VGA: 01:00.0 0300: 10de:0622 (rev a1) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Checking screen 1Comparing resolution (1680x1050) to maximum 3D texture size (8192): Passed.
Checking for Software Rasterizer: Not present.
Checking for nVidia: present.
Checking for FBConfig: present.
/usr/bin/compiz.real (core) - Error: Plugin ‘core’ has ABI version ‘20090207’, expected ABI version ‘20080424’.
/usr/bin/compiz.real (ccp) - Error: InitObject failed
/usr/bin/compiz.real (core) - Error: Couldn’t activate plugin ‘ccp’
/usr/bin/compiz.real (core) - Warn: Plugin ‘core’ already active
*** glibc detected *** /usr/bin/compiz.real: double free or corruption (!prev): 0x091bd7e8 ***
======= Backtrace: =========
/lib/i686/cmov/libc.so.6[0xf7b841d4]
/lib/i686/cmov/libc.so.6(cfree+0x96)[0xf7b86186]
/usr/lib/libGL.so.1[0xf7cff3e1]
======= Memory map: ========
08048000-0807c000 r-xp 00000000 08:02 178854 /usr/bin/compiz.real
0807c000-0807d000 rw-p 00033000 08:02 178854 /usr/bin/compiz.real
08fba000-092a5000 rw-p 08fba000 00:00 0 [heap]
f6400000-f6421000 rw-p f6400000 00:00 0
f6421000-f6500000 —p f6421000 00:00 0
f6591000-f659d000 r-xp 00000000 08:02 716692 /lib/libgcc_s.so.1
f659d000-f659e000 rw-p 0000c000 08:02 716692 /lib/libgcc_s.so.1
f659e000-f679e000 rw-s 47ece000 00:0d 10042 /dev/nvidia0
f679e000-f67a2000 rw-s 684f9000 00:0d 10042 /dev/nvidia0
f67a2000-f68a2000 rw-s b3d07000 00:0d 10042 /dev/nvidia0
f68a6000-f68a7000 rw-s d0f20000 00:0d 10042 /dev/nvidia0
f68a7000-f68a8000 rw-s fdc06000 00:0d 10042 /dev/nvidia0
f68a8000-f68e8000 rw-s 47f4d000 00:0d 10042 /dev/nvidia0
f68e8000-f6908000 rw-s af80b000 00:0d 10042 /dev/nvidia0
f6a25000-f6a59000 rw-p f6a25000 00:00 0
f6a59000-f6a7a000 rw-s 00000000 00:08 23789568 /SYSV00000000 (deleted)
f6a7a000-f6a7c000 rw-p f6a7a000 00:00 0
f6a7c000-f6a80000 r-xp 00000000 08:02 176313 /usr/lib/libXdmcp.so.6.0.0
f6a80000-f6a81000 rw-p 00003000 08:02 176313 /usr/lib/libXdmcp.so.6.0.0
f6a81000-f6a83000 r-xp 00000000 08:02 171482 /usr/lib/libXau.so.6.0.0
f6a83000-f6a84000 rw-p 00001000 08:02 171482 /usr/lib/libXau.so.6.0.0
f6a84000-f6a85000 r-xp 00000000 08:02 350949 /usr/lib/tls/libnvidia-tls.so.180.44
f6a85000-f6a86000 rw-p 00000000 08:02 350949 /usr/lib/tls/libnvidia-tls.so.180.44
f6a86000-f77a0000 r-xp 00000000 08:02 171504 /usr/lib/libGLcore.so.180.44
f77a0000-f7992000 rwxp 00d19000 08:02 171504 /usr/lib/libGLcore.so.180.44
f7992000-f799e000 rwxp f7992000 00:00 0
f799e000-f799f000 rw-p f799e000 00:00 0
f799f000-f79b7000 r-xp 00000000 08:02 171268 /usr/lib/libxcb.so.1.1.0
f79b7000-f79b8000 rw-p 00017000 08:02 171268 /usr/lib/libxcb.so.1.1.0
f79b8000-f79bb000 r-xp 00000000 08:02 171934 /usr/lib/libxcb-atom.so.1.0.0
f79bb000-f79bc000 rw-p 00002000 08:02 171934 /usr/lib/libxcb-atom.so.1.0.0
f79bc000-f79be000 r-xp 00000000 08:02 172475 /usr/lib/libxcb-event.so.1.0.0
f79be000-f79bf000 rw-p 00001000 08:02 172475 /usr/lib/libxcb-event.so.1.0.0
f79bf000-f79c1000 r-xp 00000000 08:02 171811 /usr/lib/libxcb-aux.so.0.0.0
f79c1000-f79c2000 rw-p 00001000 08:02 171811 /usr/lib/libxcb-aux.so.0.0.0
f79c2000-f79d6000 r-xp 00000000 08:02 172950 /usr/lib/libz.so.1.2.3.3
f79d6000-f79d7000 rw-p 00013000 08:02 172950 /usr/lib/libz.so.1.2.3.3
f79d7000-f79d8000 rw-p f79d7000 00:00 0
f79d8000-f79db000 r-xp 00000000 08:02 716893 /lib/libuuid.so.1.2
f79db000-f79dc000 rw-p 00002000 08:02 716893 /lib/libuuid.so.1.2
f79dc000-f79e4000 r-xp 00000000 08:02 176447 /usr/lib/libXrender.so.1.3.0
f79e4000-f79e5000 rw-p 00007000 08:02 176447 /usr/lib/libXrender.so.1.3.0
f79e5000-f79e7000 r-xp 00000000 08:02 749401 /lib/i686/cmov/libdl-2.9.so
f79e7000-f79e800/usr/bin/compiz: line 455: 21684 Abandon ${COMPIZ_BIN_PATH}${COMPIZ_NAME} $COMPIZ_OPTIONS “$@” $COMPIZ_PLUGINS
metacity: Unknown option --ignore-desktop-hints[/code]
Donc, wait and see.
