je me dépatouille en vain depuis un bon moment avec mkinitrd-cd .
Son installation m’a occasionné un remove des discover1*, déjà … hum, et j’ai plus gnome-system-monitor qui fonctionne … :
[code]Package: mkinitrd-cd
Priority: extra
Section: admin
Installed-Size: 512
Maintainer: Rene Mayrhofer rene.mayrhofer@gibraltar.at
Architecture: i386
Source: gibraltar-bootcd
Version: 0.52
Depends: libuclibc0 (>= 0.9.17-1), dosfstools, mtools, syslinux (>= 2.00-1), makedev, gcc, make, discover-data, uclibc-toolchain (>= 0.9.26-1), libuclibc-dev (>= 0.9.26-1)
Recommends: mkisofs
Filename: pool/main/g/gibraltar-bootcd/mkinitrd-cd_0.52_i386.deb
MD5sum: 7ac993567a7306dbbd985226a1058135
Description: Creates an initrd image for booting from a live CD-ROM or USB device
This is the package used by the Gibraltar project to create the initrd images
used for booting from CD-ROM or USB sticks. The bootable CD-ROMs or USB
mass storage devices are actual live CD-ROMs respective live filesystems.
That is, the root file system is the CD-ROM or an image on the USB device,
ramdisks are the only things needed for operation without a hard disk.
Although a harddisk can be used for e.g. storing log files permanently or
when the machine acts as a proxy server.
Given a kernel image and the corresponding modules, it creates a complete
boot image that can be written to floppy or be used as El Torito image for
a bootable CD-ROM. Additionally, it is possible to create an initrd image to
be used on a USB stick (e.g. with syslinux). Upon bootup, the initrd image
will try to locate an ATAPI CD-ROM drive or a USB mass storage device. When
this does not succeed, it auto-probes for SCSI adapters and tries to locate
SCSI drives. It also works when multiple CD-ROM drives are installed in the
system by checking if the inserted CD is the correct one for booting.
The package can be of use to developers and packagers who want to create
their own bootable, live Debian CD-ROM or bootable, live Debian USB stick.
It will probably not be of any use to others.
jcode@debian:/etc/xinetd.d$ sudo apt-get install mkinitrd-cd
discover-data dosfstools libuclibc-dev libuclibc0 syslinux uclibc-toolchain
discover1 discover1-data libdiscover1
discover-data dosfstools libuclibc-dev libuclibc0 mkinitrd-cd syslinux uclibc-toolchain
0 mis à jour, 7 nouvellement installés, 3 à enlever et 138 non mis à jour.
Il est nécessaire de prendre 3258ko dans les archives.
Après dépaquetage, 14,3Mo d’espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer [O/n] ?
Réception de : 1 http://ftp.fr.debian.org sarge/main discover-data 2.2005.02.13-1 [244kB]
Réception de : 2 http://ftp.fr.debian.org sarge/main dosfstools 2.11-2 [53,3kB]
Réception de : 3 http://ftp.fr.debian.org sarge/main libuclibc0 0.9.27-1 [352kB]
Réception de : 4 http://ftp.fr.debian.org sarge/main libuclibc-dev 0.9.27-1 [2168kB]
Réception de : 5 http://ftp.fr.debian.org sarge/main syslinux 2.11-0.1 [199kB]
Réception de : 6 http://ftp.fr.debian.org sarge/main uclibc-toolchain 0.9.27-1 [12,6kB]
Réception de : 7 http://ftp.fr.debian.org sarge/main mkinitrd-cd 0.52 [230kB]
3258ko réceptionnés en 10s (312ko/s)
Lecture des champs des paquets… Fait
Lecture de l’état des paquets… Fait
Récupération des rapports de bogue… Fait
Bogues de gravité grave sur dosfstools (-> 2.11-2)
#356273 - dosfstools: [mkfs.vfat] usb format: infinite loop - drains all memory
Résumé :
dosfstools(1 bogue)
Are you sure you want to install/upgrade the above packages? [Y/n/?/…]
(Lecture de la base de données… 119218 fichiers et répertoires déjà installés.)
Suppression de discover1 …
Suppression de libdiscover1 …
Suppression de discover1-data …
Sélection du paquet discover-data précédemment désélectionné.
(Lecture de la base de données… 119150 fichiers et répertoires déjà installés.)[/code]
Je lis dans le README : [quote]I usually simply do
dpkg-deb -X kernel-image-__i386.deb /tmp
mkinitrd-cd /tmp/lib/modules/ /tmp/initrd.img
mkbootimg 1440 /tmp/boot/vmlinuz- /tmp/initrd.img /tmp/boot.img
to get a fully working boot image for the Gibraltar project CD-ROMs.
[/quote] ben bonjour, chez moi c’est pas simply done …
Comme j’ai eu des messages d’erreur en utilisant /tmp du style :
[quote]Copying structure to image file … cp: ne peut créer le lien symbolique `/tmp/tmp.TIsOTc7798/usr/i386-uclibc-linux/lib/libc.so’: Aucun espace disponible sur le périphérique[/quote] je me suis dit que j’allais faire le ménage dans /tmp, là, surprise, aprés avoir réussi à suprimer le repertoire /tmp/boot :
debian:/tmp# ls -l /tmp
total 3679
drwx------ 3 jcode jcode 1024 2006-08-14 11:57 gconfd-jcode
drwx------ 3 root root 1024 2006-08-14 11:57 gconfd-root
drwx------ 2 jcode jcode 1024 2006-08-14 11:57 keyring-d8gKtb
drwxr-xr-x 3 root root 1024 2006-05-27 12:22 lib
drwxr-xr-x 2 root root 12288 2006-05-11 01:28 lost+found
srwxr-xr-x 1 jcode jcode 0 2006-08-14 11:57 mapping-jcode
drwx------ 2 jcode jcode 2048 2006-08-14 17:36 orbit-jcode
drwx------ 2 root root 1024 2006-08-14 11:57 orbit-root
drwx------ 2 jcode jcode 1024 2006-08-14 11:57 ssh-eybMRA2441
drwx------ 2 jcode jcode 1024 2006-08-14 11:57 ssh-mPSvrx2441
drwx------ 12 root root 1024 2006-08-14 17:14 tmp.AUueUd7097
drwx------ 12 root root 1024 2006-08-14 17:27 tmp.aYRZMq7420
drwxr-xr-x 13 root root 1024 2006-08-14 17:30 tmp.DfVUkz7696
drwxr-xr-x 13 root root 1024 2006-08-14 17:27 tmp.EYGZcU7419
-rw------- 1 root root 924672 2006-08-14 17:27 tmp.HIkNEt7418
drwx------ 12 root root 1024 2006-08-14 17:34 tmp.iYhIDc7799
-rw------- 1 root root 924672 2006-08-14 17:30 tmp.MVghud7695
-rw------- 1 root root 924672 2006-08-14 17:14 tmp.Nvglmg7095
drwxr-xr-x 2 root root 7168 2006-08-14 15:29 tmp.PetsUn4673
-rw------- 1 root root 924672 2006-08-14 17:34 tmp.rdPTjH7797
drwx------ 12 root root 1024 2006-08-14 17:30 tmp.soRhRt7697
drwxr-xr-x 13 root root 1024 2006-08-14 17:34 tmp.TIsOTc7798
drwxr-xr-x 13 root root 1024 2006-08-14 17:14 tmp.UvbSeS7096
drwxr-xr-x 3 root root 1024 2006-05-27 12:22 usr
drwx------ 2 jcode jcode 1024 2006-08-14 11:57 virtual-jcode.nHaGsL
-rw------- 1 jcode jcode 8686 2006-08-14 13:07 zmanX229Rp
debian:/tmp# rm -rf lib
debian:/tmp# rm -rf tmp.*
rm: ne peut détruire le répertoire `tmp.DfVUkz7696': Périphérique ou ressource occupé
rm: ne peut détruire le répertoire `tmp.EYGZcU7419': Périphérique ou ressource occupé
rm: ne peut détruire le répertoire `tmp.PetsUn4673': Périphérique ou ressource occupé
rm: ne peut détruire le répertoire `tmp.TIsOTc7798': Périphérique ou ressource occupé
rm: ne peut détruire le répertoire `tmp.UvbSeS7096': Périphérique ou ressource occupé
debian:/tmp# ls -l
total 41
drwxr-xr-x 2 root root 1024 2006-08-14 17:36 tmp.DfVUkz7696
drwxr-xr-x 2 root root 1024 2006-08-14 17:36 tmp.EYGZcU7419
drwxr-xr-x 2 root root 1024 2006-08-14 17:36 tmp.TIsOTc7798
drwxr-xr-x 2 root root 1024 2006-08-14 17:36 tmp.UvbSeS7096
Qu’est ce donc que ce périphérique … ?
Aprés différent essais infructueux, je me dis que je vais tout faire dans /home/tmp, là, je suis sur qu’il y a de la place :
debian:/tmp# mkinitrd-cd /home/tmp/lib/modules/2.6.16camiptables /home/tmp/initrd.img full
Creating file structure ... done
Creating device files ... done
Copying modules ...
ide-floppy ... skipped
loop ... copied
paride ... skipped
sx8 ... skipped
binfmt_aout ... skipped
binfmt_misc ... skipped
fat ... copied
msdos ... skipped
ntfs ... skipped
reiserfs ... copied
vfat ... copied
usblp ... skipped
usbcore ... copied
ehci-hcd ... copied
uhci-hcd ... skipped
usbhid ... skipped
usbkbd ... skipped
usbmouse ... skipped
ov511 ... skipped
pwc ... skipped
usb-storage ... copied
done
The largest module will need 244916 bytes to be unzipped.
Creating / copying binaries and libraries ...
Installing binaries in temporary file structure ... done
Creating config files in temporary file structure ... done
Copying uClibc ... done
Copying bootup files ... done
The image will take 3047 kb (including 339 kb of free space for temp files).
Creating image file ... done
Copying structure to image file ... done
Compressing image file ... done
Cleaning up ... done
debian:/tmp# ls -l
total 951
drwxr-xr-x 13 root root 1024 2006-08-14 17:42 tmp.oanwLR8111
drwx------ 12 root root 1024 2006-08-14 17:42 tmp.tTupkI8112
-rw------- 1 root root 924672 2006-08-14 17:42 tmp.ZvpeWR8110
debian:/tmp# ls -l /home/tmp
total 900
drwxr-xr-x 2 root root 4096 2006-05-27 12:22 boot
-rw------- 1 root root 902104 2006-08-14 17:43 initrd.img
drwxr-xr-x 3 root root 4096 2006-05-27 12:22 lib
drwxr-xr-x 3 root root 4096 2006-05-27 12:22 usr
debian:/tmp# mkbootimg 2880 /home/tmp/boot/vmlinuz-2.6.16camiptables /home/tmp/initrd.img /home/tmp/boot.img
Creating image file with FAT file system (2880 kB)... done
Mounting ... done
Copying linux kernel ... done
Copying initrd image ... done
Copying configuration ... done
total 3784
-rw------- 1 root root 2949120 2006-08-14 17:49 boot.img
Bon et maintenant je sais plus quoi faire avec ça … je fais quoi ? si tant est que c’est exploitable …
Quelqu’un a déjà utilisé mkinitrd-cd et pourrait me dire où le bas blaisse ?
Pourquoi des modules sont skipped ?
ça manque singulièrement de doc ce truc ? aucun how-to sur le net … nada …
