Suite à une installe fraîche de Wheezy j’ai des soucis de (dé)connexions intempestives au bout d’un temps aléatoire 15, 32, 50 min.
Soit je boot avec mon GSM branché (Nokia en USB - PC suite) et ppp0 (cf. ifconfig) tombe sans pouvoir se reconnecter malgré la relance des services Networking et Network-manager.
Soit branchement USB à chaud et impossible d’établir une connexion.
Je précise que sur mon autre poste sur Squeeze tout fonctionne.
Du coup j’ai désactiver l’ipv6 mais pas d’amélioration.
Ma config:
Un Lenovo ThinkPad X200 - Gnome 3.4.2 - Network-manager - Téléphones Mobiles GSM Nokia 3G 3G+ connectés en USB en mode PC Suite.
BIOS:
[code]# dmidecode -t bios
dmidecode 2.11
SMBIOS 2.4 present.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: LENOVO
Version: 6DET72WW (3.22 )
Release Date: 10/25/2012
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 8192 kB
Characteristics:
PCI is supported
PC Card (PCMCIA) is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 3.34
Firmware Revision: 1.7
Handle 0x001E, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Abbreviated
Installable Languages: 1
enUS
Currently Installed Language: enUS
Kernel:
Linux x200 3.2.0-4-686-pae #1 SMP Debian 3.2.63-2+deb7u2 i686 GNU/Linux
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0421:02ad Nokia Mobile Phones
Voici un extrait de mon syslog lors de la déconnexion (cf. syslog complet avec boot et connexion internet de 16 min puis déconnexion en PJ):
Jan 5 10:22:33 machine modem-manager[3009]: <info> (ttyS0) closing serial port...
Jan 5 10:22:33 machine modem-manager[3009]: <info> (ttyS0) serial port closed
Jan 5 10:22:33 machine modem-manager[3009]: <info> (ttyS0) opening serial port...
Jan 5 10:22:39 machine modem-manager[3009]: <info> (ttyS0) closing serial port...
Jan 5 10:22:39 machine modem-manager[3009]: <info> (ttyS0) serial port closed
Jan 5 10:22:41 machine goa[3586]: goa-daemon version 3.4.2 starting [main.c:112, main()]
Jan 5 10:23:01 machine modem-manager[3009]: <info> (ttyACM0) opening serial port...
Jan 5 10:23:01 machine modem-manager[3009]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (disabled -> enabling)
Jan 5 10:23:01 machine modem-manager[3009]: <info> (ttyACM0): using text mode for SMS
Jan 5 10:23:01 machine modem-manager[3009]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (enabling -> enabled)
Jan 5 10:23:01 machine NetworkManager[2956]: <info> WWAN now enabled by management service
Jan 5 10:23:01 machine NetworkManager[2956]: <info> Auto-activating connection 'Orange Internet'.
Jan 5 10:23:01 machine NetworkManager[2956]: <info> Activation (ttyACM0) starting connection 'Orange Internet'
Jan 5 10:23:01 machine NetworkManager[2956]: <info> (ttyACM0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Jan 5 10:23:01 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 1 of 5 (Device Prepare) scheduled...
Jan 5 10:23:01 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 1 of 5 (Device Prepare) started...
Jan 5 10:23:01 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 1 of 5 (Device Prepare) complete.
Jan 5 10:23:01 machine modem-manager[3009]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (enabled -> registered)
Jan 5 10:23:02 machine modem-manager[3009]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (registered -> connecting)
Jan 5 10:23:05 machine modem-manager[3009]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (connecting -> connected)
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) scheduled...
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) starting...
Jan 5 10:23:05 machine NetworkManager[2956]: <info> (ttyACM0): device state change: prepare -> config (reason 'none') [40 50 0]
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) successful.
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 3 of 5 (IP Configure Start) scheduled.
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) complete.
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 3 of 5 (IP Configure Start) started...
Jan 5 10:23:05 machine NetworkManager[2956]: <info> (ttyACM0): device state change: config -> ip-config (reason 'none') [50 70 0]
Jan 5 10:23:05 machine NetworkManager[2956]: <info> starting PPP connection
Jan 5 10:23:05 machine NetworkManager[2956]: <info> pppd started with pid 3683
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 3 of 5 (IP Configure Start) complete.
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Jan 5 10:23:05 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Jan 5 10:23:05 machine pppd[3683]: Plugin /usr/lib/pppd/2.4.5/nm-pppd-plugin.so loaded.
Jan 5 10:23:05 machine pppd[3683]: pppd 2.4.5 started by root, uid 0
Jan 5 10:23:05 machine kernel: [ 62.008922] PPP generic driver version 2.4.2
Jan 5 10:23:05 machine pppd[3683]: Using interface ppp0
Jan 5 10:23:05 machine pppd[3683]: Connect: ppp0 <--> /dev/ttyACM0
Jan 5 10:23:05 machine NetworkManager[2956]: SCPlugin-Ifupdown: devices added (path: /sys/devices/virtual/net/ppp0, iface: ppp0)
Jan 5 10:23:05 machine NetworkManager[2956]: SCPlugin-Ifupdown: device added (path: /sys/devices/virtual/net/ppp0, iface: ppp0): no ifupdown configuration found.
Jan 5 10:23:05 machine pppd[3683]: PAP authentication succeeded
Jan 5 10:23:05 machine kernel: [ 62.075094] PPP BSD Compression module registered
Jan 5 10:23:05 machine kernel: [ 62.086654] PPP Deflate Compression module registered
Jan 5 10:23:07 machine pppd[3683]: local IP address 10.199.5.217
Jan 5 10:23:07 machine pppd[3683]: remote IP address 10.6.6.6
Jan 5 10:23:07 machine pppd[3683]: primary DNS address 192.168.10.110
Jan 5 10:23:07 machine NetworkManager[2956]: <info> PPP manager(IP Config Get) reply received.
Jan 5 10:23:07 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Jan 5 10:23:07 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 5 of 5 (IPv4 Commit) started...
Jan 5 10:23:08 machine NetworkManager[2956]: <info> (ttyACM0): device state change: ip-config -> activated (reason 'none') [70 100 0]
Jan 5 10:23:09 machine NetworkManager[2956]: <info> Policy set 'Orange Internet' (ppp0) as default for IPv4 routing and DNS.
Jan 5 10:23:09 machine NetworkManager[2956]: <info> Activation (ttyACM0) successful, device activated.
Jan 5 10:23:09 machine NetworkManager[2956]: <info> Activation (ttyACM0) Stage 5 of 5 (IPv4 Commit) complete.
Jan 5 10:23:09 machine dbus[2540]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jan 5 10:23:09 machine dbus[2540]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 5 10:39:27 machine kernel: [ 1044.100790] usb 2-1: USB disconnect, device number 2
Jan 5 10:39:27 machine pppd[3683]: Modem hangup
Jan 5 10:39:27 machine modem-manager[3009]: <info> (ttyACM0) closing serial port...
Jan 5 10:39:27 machine modem-manager[3009]: <info> (ttyACM0) serial port closed
Jan 5 10:39:27 machine avahi-daemon[2870]: Withdrawing workstation service for usbpn0.
Jan 5 10:39:27 machine pppd[3683]: Connect time 16.4 minutes.
Jan 5 10:39:27 machine pppd[3683]: Sent 220643 bytes, received 687387 bytes.
Jan 5 10:39:27 machine modem-manager[3009]: <info> (tty/ttyACM0): released by modem /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1
Jan 5 10:39:27 machine modem-manager[3009]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (connected -> disabled)
Jan 5 10:39:27 machine NetworkManager[2956]: <info> (ttyACM0): now unmanaged
Jan 5 10:39:27 machine NetworkManager[2956]: <info> (ttyACM0): device state change: activated -> unmanaged (reason 'removed') [100 10 36]
Jan 5 10:39:27 machine pppd[3683]: Connection terminated.
Jan 5 10:39:27 machine avahi-daemon[2870]: Withdrawing workstation service for ppp0.
Jan 5 10:39:28 machine NetworkManager[2956]: <info> (ttyACM0): deactivating device (reason 'removed') [36]
Jan 5 10:39:28 machine NetworkManager[2956]: <warn> could not read ppp stats: No such device
Jan 5 10:39:28 machine NetworkManager[2956]: nm_system_iface_flush_routes: assertion `ifindex > 0' failed
Jan 5 10:39:28 machine NetworkManager[2956]: nm_system_iface_flush_addresses: assertion `ifindex > 0' failed
Jan 5 10:39:28 machine NetworkManager[2956]: <info> (ttyACM0): cleaning up...
Jan 5 10:39:28 machine NetworkManager[2956]: <info> (ttyACM0): taking down device.
Jan 5 10:39:28 machine NetworkManager[2956]: SCPlugin-Ifupdown: devices removed (path: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.10/net/usbpn0, iface: usbpn0)
Jan 5 10:39:28 machine NetworkManager[2956]: SCPlugin-Ifupdown: devices removed (path: /sys/devices/virtual/net/ppp0, iface: ppp0)
Jan 5 10:39:28 machine dbus[2540]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jan 5 10:39:28 machine dbus[2540]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 5 10:40:10 machine kernel: [ 1087.152127] usb 2-1: new high-speed USB device number 3 using ehci_hcd
Jan 5 10:40:11 machine kernel: [ 1087.296437] usb 2-1: device descriptor read/all, error -71
Jan 5 10:40:11 machine kernel: [ 1087.356432] hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 5 10:40:11 machine kernel: [ 1088.060123] usb 2-1: new high-speed USB device number 5 using ehci_hcd
Jan 5 10:40:12 machine kernel: [ 1088.202563] usb 2-1: New USB device found, idVendor=0421, idProduct=02ad
Jan 5 10:40:12 machine kernel: [ 1088.202568] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 5 10:40:12 machine kernel: [ 1088.202572] usb 2-1: Product: 6700s
Jan 5 10:40:12 machine kernel: [ 1088.202574] usb 2-1: Manufacturer: Nokia
Jan 5 10:40:12 machine kernel: [ 1088.202577] usb 2-1: SerialNumber: 354321040144893
Jan 5 10:40:12 machine kernel: [ 1088.204446] cdc_acm 2-1:1.1: ttyACM0: USB ACM device
Jan 5 10:40:12 machine kernel: [ 1088.208906] usb 2-1: bad CDC descriptors
Jan 5 10:40:12 machine kernel: [ 1088.209127] usb 2-1: bad CDC descriptors
Jan 5 10:40:12 machine mtp-probe: checking bus 2, device 5: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1"
Jan 5 10:40:12 machine mtp-probe: bus: 2, device: 5 was an MTP device
Jan 5 10:40:12 machine modem-manager[3009]: <info> (ttyACM0) opening serial port...
Jan 5 10:40:12 machine NetworkManager[2956]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.10/net/usbpn0, iface: usbpn0)
Jan 5 10:40:12 machine NetworkManager[2956]: SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.10/net/usbpn0, iface: usbpn0): no ifupdown configuration found.
Jan 5 10:40:13 machine modem-manager[3009]: <info> (ttyACM0) closing serial port...
Jan 5 10:40:13 machine modem-manager[3009]: <info> (ttyACM0) serial port closed
Jan 5 10:40:13 machine modem-manager[3009]: <info> (ttyACM0) opening serial port...
Jan 5 10:40:13 machine modem-manager[3009]: <info> (Nokia): GSM modem /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1 claimed port ttyACM0
Jan 5 10:40:13 machine NetworkManager[2956]: <warn> (ttyACM0): failed to look up interface index
Jan 5 10:40:13 machine NetworkManager[2956]: <info> WWAN now disabled by management service
Jan 5 10:40:13 machine NetworkManager[2956]: <info> (ttyACM0): new GSM/UMTS device (driver: 'cdc_acm' ifindex: 0)
Jan 5 10:40:13 machine NetworkManager[2956]: <info> (ttyACM0): exported as /org/freedesktop/NetworkManager/Devices/3
Jan 5 10:40:13 machine NetworkManager[2956]: <info> (ttyACM0): now managed
Jan 5 10:40:13 machine NetworkManager[2956]: <info> (ttyACM0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jan 5 10:40:13 machine NetworkManager[2956]: <info> (ttyACM0): deactivating device (reason 'managed') [2]
Jan 5 10:40:13 machine NetworkManager[2956]: nm_system_iface_flush_routes: assertion `ifindex > 0' failed
Jan 5 10:40:13 machine NetworkManager[2956]: nm_system_iface_flush_addresses: assertion `ifindex > 0' failed
Jan 5 10:40:13 machine NetworkManager[2956]: <info> (ttyACM0): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
Un soucis de BIOS et d’USB nomade peut-être selon ce fil:
https://lists.debian.org/debian-user-french/2010/05/msg00308.html
Pb de kernel?
Merci d’avance, si qq’un-e a une idée…
syslog.txt (111 KB)
lsusb.txt (558 Bytes)
