Je précise que je n’ai aucune soucis pour me connecter en ssh pour l’instant avec le port par défaut mais uniquement en local vu que mon fai bloque le port 22 raison pour laquelle je désire modifier ce port et bien sur pour une question de sécurité
Belzebuth voici le résultat de ta commande mais je ne sais pas si je dois réponbdre yes ou no car j’ai un peu de mal avec l’anglais
OpenSSH_6.7p1 Debian-5, OpenSSL 1.0.1k 8 Jan 2015
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 192.168.0.247 [192.168.0.247] port 22.
debug1: Connection established.
debug1: SELinux support disabled
debug1: key_load_public: No such file or directory
debug1: identity file /home/philox47/.ssh/id_rsa type -1
debug1: identity file /home/philox47/.ssh/id_rsa-cert type -1
debug1: identity file /home/philox47/.ssh/id_dsa type -1
debug1: identity file /home/philox47/.ssh/id_dsa-cert type -1
debug1: identity file /home/philox47/.ssh/id_ecdsa type -1
debug1: identity file /home/philox47/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/philox47/.ssh/id_ed25519 type -1
debug1: identity file /home/philox47/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Debian-5
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Debian-5
debug1: match: OpenSSH_6.7p1 Debian-5 pat OpenSSH* compat 0x04000000
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-ctr umac-64-etm@openssh.com none
debug1: kex: client->server aes128-ctr umac-64-etm@openssh.com none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA b9:cd:bf:65:d7:42:6f:19:9f:7f:e2:82:8a:8f:0c:58
The authenticity of host '192.168.0.247 (192.168.0.247)' can't be established.
ECDSA key fingerprint is b9:cd:bf:65:d7:42:6f:19:9f:7f:e2:82:8a:8f:0c:58.
Are you sure you want to continue connecting (yes/no)? yes
avram
En Belgique j’ai une sorte de box qui me donne access a internet d’office sans modifier quoi que ce soit via le cable tv
Par contre je n’ai droit qu’a une ip pour un serveur via une dmz et via des ports au dessus de 1000 pour le ssh ou ftp
quand aux ports http et https le port 80 est bloqué donc je doit utiliser le port 8080 et suivant mais bon tout cela ne me pose pas de soucis a part le fait que le port 8080 etc soit visible sur l’url
pour redémarrer ssh en fait pour être certain qu’il a bien démarré je reboot le pc
merci
