J’ai dans la machine tout ce qu’il faut avoir pour installer le module en question, qui d’ailleurs permettait le fonctionnement du wifi jusqu’à ce que je fasse une bêtise qui serait trop longue à expliquer.
Voilà ce que j’obtiens aujourd’hui :
# dkms build -m acx-mac80211 -v git
Kernel preparation unnecessary for this kernel. Skipping…
Building module:
cleaning build area…
‘make’ all KVERSION=3.8-2-amd64…(bad exit status: 2)
Error! Bad return status for module build on kernel: 3.8-2-amd64 (x86_64)
Consult /var/lib/dkms/acx-mac80211/git/build/make.log for more information.
# tail -30 /var/lib/dkms/acx-mac80211/git/build/make.log
DKMS make.log for acx-mac80211-git for kernel 3.8-2-amd64 (x86_64)
mardi 28 mai 2013, 17:23:50 (UTC+0200)
echo “make is “standalone build”“
make is standalone build
make -C /lib/modules/3.8-2-amd64/build M=/var/lib/dkms/acx-mac80211/git/build CONFIG_ACX_MAC80211=m CONFIG_ACX_MAC80211_PCI=y CONFIG_ACX_MAC80211_USB=m CONFIG_ACX_MAC80211_MEM=m EXTRA_CFLAGS=” -DCONFIG_ACX_MAC80211=1 -DCONFIG_ACX_MAC80211_USB=1 -DCONFIG_ACX_MAC80211_MEM=1 -DCONFIG_ACX_MAC80211_PCI=1 -DACX_GIT_VERSION=\“v20130127\”” modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-3.8-2-amd64 »
/usr/src/linux-headers-3.8-2-common/arch/x86/Makefile:88: stack protector enabled but no compiler support
CC [M] /var/lib/dkms/acx-mac80211/git/build/pci.o
/var/lib/dkms/acx-mac80211/git/build/pci.c:1042:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘acxpci_probe’
/var/lib/dkms/acx-mac80211/git/build/pci.c:1295:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘acxpci_remove’
/var/lib/dkms/acx-mac80211/git/build/pci.c:1507:12: error: ‘acxpci_probe’ undeclared here (not in a function)
/var/lib/dkms/acx-mac80211/git/build/pci.c:1508:2: error: implicit declaration of function ‘__devexit_p’ [-Werror=implicit-function-declaration]
/var/lib/dkms/acx-mac80211/git/build/pci.c:1508:25: error: ‘acxpci_remove’ undeclared here (not in a function)
cc1: some warnings being treated as errors
make[4]: *** [/var/lib/dkms/acx-mac80211/git/build/pci.o] Erreur 1
make[3]: *** [module/var/lib/dkms/acx-mac80211/git/build] Erreur 2
make[2]: *** [sub-make] Erreur 2
make[1]: *** [all] Erreur 2
make[1]: quittant le répertoire « /usr/src/linux-headers-3.8-2-amd64 »
make: *** [all] Erreur 2
Quelqu’un en pense-t-il quelquechose qui m’aiderait ?
