me revoilà !
C’est la journée pour laquelle j’ai décidé d’en finir…
Tout est rebranché, je vais essayer d’aller jusqu’au bout !
J’ai compilé le module, mais pour
/home/manu# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
Voici après ce que me donne
:/home/manu# /etc/init.d/networking restart
Reconfiguring network interfaces...There is already a pid file /var/run/dhclient.eth0.pid with pid 3177
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.0.4
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/eth0/00:e0:29:34:50:43
Sending on LPF/eth0/00:e0:29:34:50:43
Sending on Socket/fallback
DHCPRELEASE on eth0 to 192.168.0.1 port 67
SIOCSIFADDR: No such device
rausb0: ERROR while getting interface flags: No such device
Bind socket to interface: No such device
Failed to bring up rausb0.
done.
nana:/home/manu# gedit /etc/network/interfaces
(gedit:4478): GnomeUI-WARNING **: While connecting to session manager:
Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed.
nana:/home/manu# /etc/init.d/networking restart
Reconfiguring network interfaces...There is already a pid file /var/run/dhclient.eth0.pid with pid 4372
wlan0: ERROR while getting interface flags: No such device
Failed to bring up wlan0.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
DHCPOFFER from 192.168.0.1
DHCPREQUEST on eth0 to 255.255.255.255 port 67
DHCPACK from 192.168.0.1
bound to 192.168.0.3 -- renewal in 38155 seconds.
done.
Et mon /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug eth0
iface eth0 inet dhcp
#wifi
auto wlan0
iface wlan0 inet dhcp
iface rausb0 inet dhcp
Voilà, voilà…
Et au fait, je n’utilise pas de clé wep (réseau non sécurisé).
Un autre petit coup de main ?
