Mon petit qtek
bonjour,
je viens de trouver ca
doc.ubuntu-fr.org/materiel/smartphone
donc ca a l’aire de marcher
mais je n’arrive pas a complier ces fichiers
synce-trayicon synce-gnomevfs synce-software-manager
->http://www.synce.org/index.php/Gnome
et je ne trouve pas de pakage.
qlq1 a t il deja utilisé ca?
merci
voila mon pb lors du ./configure
./configure
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking whether to enable maintainer-specific portions of Makefiles… no
checking for gcc… /usr/bin/gcc-4.1
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether /usr/bin/gcc-4.1 accepts -g… yes
checking for /usr/bin/gcc-4.1 option to accept ISO C89… none needed
checking for style of include used by make… GNU
checking dependency style of /usr/bin/gcc-4.1… gcc3
checking for g++… g++
checking whether we are using the GNU C++ compiler… yes
checking whether g++ accepts -g… yes
checking dependency style of g++… gcc3
checking whether ln -s works… yes
checking for ranlib… ranlib
checking build system type… i686-pc-linux-gnu
checking host system type… i686-pc-linux-gnu
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for ld used by /usr/bin/gcc-4.1… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for /usr/bin/ld option to reload object files… -r
checking for BSD-compatible nm… /usr/bin/nm -B
checking how to recognise dependent libraries… pass_all
checking how to run the C preprocessor… /usr/bin/gcc-4.1 -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking dlfcn.h usability… yes
checking dlfcn.h presence… yes
checking for dlfcn.h… yes
checking how to run the C++ preprocessor… g++ -E
checking for g77… no
checking for xlf… no
checking for f77… no
checking for frt… no
checking for pgf77… no
checking for cf77… no
checking for fort77… no
checking for fl32… no
checking for af77… no
checking for xlf90… no
checking for f90… no
checking for pgf90… no
checking for pghpf… no
checking for epcf90… no
checking for gfortran… no
checking for g95… no
checking for xlf95… no
checking for f95… no
checking for fort… no
checking for ifort… no
checking for ifc… no
checking for efc… no
checking for pgf95… no
checking for lf95… no
checking for ftn… no
checking whether we are using the GNU Fortran 77 compiler… no
checking whether accepts -g… no
checking the maximum length of command line arguments… 32768
checking command to parse /usr/bin/nm -B output from /usr/bin/gcc-4.1 object… ok
checking for objdir… .libs
checking for ar… ar
checking for ranlib… (cached) ranlib
checking for strip… strip
checking if /usr/bin/gcc-4.1 supports -fno-rtti -fno-exceptions… no
checking for /usr/bin/gcc-4.1 option to produce PIC… -fPIC
checking if /usr/bin/gcc-4.1 PIC flag -fPIC works… yes
checking if /usr/bin/gcc-4.1 static flag -static works… yes
checking if /usr/bin/gcc-4.1 supports -c -o file.o… yes
checking whether the /usr/bin/gcc-4.1 linker (/usr/bin/ld) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… no
configure: creating libtool
appending configuration tag “CXX” to libtool
checking for ld used by g++… /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries… yes
checking for g++ option to produce PIC… -fPIC
checking if g++ PIC flag -fPIC works… yes
checking if g++ static flag -static works… yes
checking if g++ supports -c -o file.o… yes
appending configuration tag “F77” to libtool
./configure: line 19328: syntax error near unexpected token VFS,' ./configure: line 19328:PKG_CHECK_MODULES(VFS, gnome-vfs-2.0 >= $GNOME_VFS_REQUIRED gnome-vfs-module-2.0 >= $GNOME_VFS_REQUIRED)’
vous en pensez quoi?
a vous :slightly_smiling:
Tu as bien vérifié si tu avais le gnome-vfs?
Si tu fais un dpkg -l | grep gnomevfs ça donne quoi ?
ii gstreamer0.10-gnomevfs 0.10.10-4 GStreamer plugin for GnomeVFS
ii libgnomevfs2-0 2.14.2-7 GNOME virtual file-system (runtime libraries
ii libgnomevfs2-bin 2.14.2-7 GNOME virtual file-system (support binaries)
ii libgnomevfs2-common 2.14.2-7 GNOME virtual file-system (common files)
ii libgnomevfs2-extra 2.14.2-7 GNOME virtual file-system (extra modules)
j’ai toujours :
checking pkg-config is at least version 0.9.0… yes
checking for VFS… configure: error: Package requirements (gnome-vfs-2.0 >= 2.14.0 gnome-vfs-module-2.0 >= 2.14.0) were not met:
No package ‘gnome-vfs-2.0’ found ->TROUVE PAS
No package ‘gnome-vfs-module-2.0’ found ->IDEM
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables VFS_CFLAGS
and VFS_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
A VOUS
aptitude install libgnomevfs2-dev
B…de M…
je suis fou je viens de tester une ubuntu et ca marche
avec ca -> doc.ubuntu-fr.org/materiel/pocketpc
pourquoi ca ne marche pas avec ma debian?
avez vous des explications?
merci a vous
help je ne veux pas abandonner ma debian… :slightly_smiling:
B…de M…
merci a vous
Tu as toujours la même erreur après avoir effectué ce que dit fran ?
oui bien sur
c’est la raison pourkoi j’ai testé avec une ubuntu
oui excuse !!!
encore j’ai fait une erreur car mon qtek est sous wind 2003 et ce que je voulais faire ete pour le 2005… donc normalement c’est encore plus facile…
regarde ce que j’ai fait sur un ubuntu
je fais la meme sur ma debian
-> erreur de connection et ca bloque a partir de la "synce-pstatus"
j’ai tenté d’autre chose mais rien a faire…
ou est mon erreur :frowning::frowning:
si vous avez des conseils…
ca me rassure un peu
linuxfr.org/forums/43/16472.html
enfin je suis heureux pour lui :slightly_smiling:
