Mon scanner n'est pas detecté
J’ajoute un fichier avec le résultat de dmesg
Non: L’extension n’est pas autorisée., qu’on me dit. Qui autorise ?
Mets .txt au bout, ou utilise un pastebin: paste.isalo.org/
Celui qui autorise, c’est PhpBB et sa configuration, qui ne facilite pas toujours son utilisation.
la commande dmesg: (partie 1
[quote][ 3.485767] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.419262] usb 1-2: New USB device found, idVendor=0bc2, idProduct=0503
[ 4.419265] usb 1-2: New USB device strings: Mfr=54, Product=69, SerialNumber=95
[ 4.419267] usb 1-2: Product: Seagate External Drive
[ 4.419269] usb 1-2: Manufacturer: Jabil Circuit
[ 4.419270] usb 1-2: SerialNumber: SW070101442
[ 4.532017] usb 1-5: new high-speed USB device number 4 using ehci_hcd
[ 4.665596] usb 1-5: New USB device found, idVendor=059b, idProduct=047a
[ 4.665599] usb 1-5: New USB device strings: Mfr=10, Product=11, SerialNumber=3
[ 4.665600] usb 1-5: Product: eGo USB
[ 4.665602] usb 1-5: Manufacturer: Iomega
[ 4.665603] usb 1-5: SerialNumber: 912000003C21
[ 4.996022] usb 6-3: new low-speed USB device number 2 using ohci_hcd
[ 5.173950] usb 6-3: New USB device found, idVendor=04f3, idProduct=0234
[ 5.173953] usb 6-3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 5.173955] usb 6-3: Product: OM
[ 5.218922] udevd[424]: starting version 175
[ 5.440020] usb 4-1: new full-speed USB device number 2 using ohci_hcd
[ 5.628950] usb 4-1: New USB device found, idVendor=03f0, idProduct=0904
[ 5.628953] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.628954] usb 4-1: Product: DeskJet 845C
[ 5.628956] usb 4-1: Manufacturer: Hewlett-Packard
[ 5.628957] usb 4-1: SerialNumber: TH18E1G8DCSX
[ 5.743546] usb 5-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 5.757553] usb 5-2: New USB device found, idVendor=0951, idProduct=1666
[ 5.757556] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.757558] usb 5-2: Product: DataTraveler 3.0
[ 5.757560] usb 5-2: Manufacturer: Kingston
[ 5.757562] usb 5-2: SerialNumber: 60A44C4138D1BD91D33B4113
[ 5.842623] wmi: Mapper loaded
[ 5.970204] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 5.970209] ACPI: Power Button [PWRB]
[ 5.970253] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 5.970256] ACPI: Power Button [PWRF]
[ 6.313934] ACPI: acpi_idle registered with cpuidle
[ 6.330987] ATK0110 ATK0110:00: Overriding interface detection
[ 6.433715] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 6.480659] parport_pc 00:06: reported by Plug and Play ACPI
[ 6.480727] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 6.481703] hda_intel: Disabling MSI
[ 6.481722] snd_hda_intel 0000:01:00.1: setting latency timer to 64
[ 6.645343] ACPI: resource piix4_smbus [io 0x0b00-0x0b07] conflicts with ACPI region SOR1 [io 0xb00-0xb0f]
[ 6.645345] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 6.674399] SP5100 TCO timer: SP5100 TCO WatchDog Timer Driver v0.01
[ 6.674455] SP5100 TCO timer: mmio address 0xfec000f0 already in use
[ 6.776105] [drm] Initialized drm 1.1.0 20060810
[ 6.808773] powernow-k8: Found 1 AMD FX™-4300 Quad-Core Processor (4 cpu cores) (version 2.20.00)
[ 6.808785] powernow-k8: Core Performance Boosting: on.
[ 6.808825] powernow-k8: 0 : pstate 0 (3800 MHz)
[ 6.808826] powernow-k8: 1 : pstate 1 (3400 MHz)
[ 6.808828] powernow-k8: 2 : pstate 2 (2600 MHz)
[ 6.808829] powernow-k8: 3 : pstate 3 (1800 MHz)
[ 6.808830] powernow-k8: 4 : pstate 4 (1400 MHz)
[ 7.057030] usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x03F0 pid 0x0904
[ 7.057073] usbcore: registered new interface driver usblp
[ 7.134170] input: OM as /devices/pci0000:00/0000:00:12.1/usb6/6-3/6-3:1.0/input/input4
[ 7.134486] generic-usb 0003:04F3:0234.0001: input,hidraw0: USB HID v1.11 Mouse [OM] on usb-0000:00:12.1-3/input0
[ 7.134524] usbcore: registered new interface driver usbhid
[ 7.134529] usbhid: USB HID core driver
[ 7.306483] Initializing USB Mass Storage driver…
[ 7.306742] scsi6 : usb-storage 1-2:1.0
[ 7.307086] scsi7 : usb-storage 1-5:1.0
[ 7.307315] scsi8 : usb-storage 5-2:1.0
[ 7.307454] usbcore: registered new interface driver usb-storage
[ 7.307459] USB Mass Storage support registered.
[ 7.408087] HDMI status: Codec=0 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 7.440087] HDMI status: Codec=1 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 7.472107] HDMI status: Codec=2 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 7.504036] HDMI status: Codec=3 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 7.520211] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input5
[ 7.520372] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input6
[ 7.520511] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input7
[ 7.520650] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input8
[ 7.522018] nouveau 0000:01:00.0: setting latency timer to 64
[ 7.522049] [drm] nouveau 0000:01:00.0: Detected an NV50 generation card (0x0a8280b1)
[ 7.535762] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 7.612098] [drm] nouveau 0000:01:00.0: … appears to be valid
[ 7.612104] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 7.612111] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 7.612117] [drm] nouveau 0000:01:00.0: Bios version 70.18.5f.00
[ 7.612123] [drm] nouveau 0000:01:00.0: TMDS table version 2.0
[ 7.612444] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 7.612446] [drm] nouveau 0000:01:00.0: DCB version 4.0
[ 7.612449] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000302 00020030
[ 7.612450] [drm] nouveau 0000:01:00.0: DCB outp 01: 02000300 00000000
[ 7.612452] [drm] nouveau 0000:01:00.0: DCB outp 02: 02011362 00020010
[ 7.612453] [drm] nouveau 0000:01:00.0: DCB outp 03: 01022310 00000000
[ 7.612455] [drm] nouveau 0000:01:00.0: DCB conn 00: 00001030
[ 7.612456] [drm] nouveau 0000:01:00.0: DCB conn 01: 00002161
[ 7.612458] [drm] nouveau 0000:01:00.0: DCB conn 02: 00000200
[ 7.612462] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD97D
[ 7.672955] [drm] nouveau 0000:01:00.0: 0xDC4A: Condition still not met after 20ms, skipping following opcodes
[ 7.692801] [drm] nouveau 0000:01:00.0: 0xDC4E: Condition still not met after 20ms, skipping following opcodes
[ 7.692821] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xDE28
[ 7.700520] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xE9FB
[ 7.700526] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xEA14
[ 7.743021] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xEAFB
[ 7.743025] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0xEB60
[ 7.762869] [drm] nouveau 0000:01:00.0: 0xD7F1: Condition still not met after 20ms, skipping following opcodes
[ 7.765409] [TTM] Zone kernel: Available graphics memory: 432478 kiB
[ 7.765415] [TTM] Zone highmem: Available graphics memory: 2064994 kiB
[ 7.765418] [TTM] Initializing pool allocator
[ 7.765427] [TTM] Initializing DMA pool allocator
[ 7.765443] [drm] nouveau 0000:01:00.0: Detected 1024MiB VRAM (DDR3)
[ 7.770311] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 7.803308] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 7.803309] [drm] No driver support for vblank timestamp query.
[ 8.120062] [drm] nouveau 0000:01:00.0: 3 available performance level(s)
[ 8.120066] [drm] nouveau 0000:01:00.0: 0: core 135MHz shader 270MHz memory 135MHz voltage 850mV
[ 8.120069] [drm] nouveau 0000:01:00.0: 1: core 405MHz shader 810MHz memory 405MHz voltage 900mV
[ 8.120071] [drm] nouveau 0000:01:00.0: 3: core 589MHz shader 1402MHz memory 600MHz voltage 1000mV
[ 8.120073] [drm] nouveau 0000:01:00.0: c: core 405MHz shader 810MHz memory 405MHz voltage 900mV
[ 8.304437] scsi 8:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[ 8.305454] [drm] nouveau 0000:01:00.0: allocated 1920x1080 fb: 0x310000, bo f7046800
[ 8.305514] fbcon: nouveaufb (fb0) is primary device
[ 8.305660] sd 8:0:0:0: Attached scsi generic sg5 type 0
[ 8.308163] scsi 6:0:0:0: Direct-Access Seagate External Drive PQ: 0 ANSI: 0
[ 8.308293] sd 8:0:0:0: [sde] 15360000 512-byte logical blocks: (7.86 GB/7.32 GiB)
[ 8.310560] sd 8:0:0:0: [sde] Write Protect is off
[ 8.310567] sd 8:0:0:0: [sde] Mode Sense: 2b 80 00 08
[ 8.310706] HDMI hot plug event: Codec=1 Pin=5 Presence_Detect=1 ELD_Valid=0
[ 8.311703] sd 8:0:0:0: [sde] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 8.316013] HDMI status: Codec=1 Pin=5 Presence_Detect=1 ELD_Valid=1
[ 8.319282] sde: sde1
[ 8.322549] sd 8:0:0:0: [sde] Attached SCSI removable disk
[ 8.330914] Console: switching to colour frame buffer device 240x67
[ 8.334104] fb0: nouveaufb frame buffer device
[ 8.334106] drm: registered panic notifier
[ 8.334109] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 8.346616] scsi 7:0:0:0: Direct-Access ST950032 5AS PQ: 0 ANSI: 2 CCS
[ 8.347036] sd 7:0:0:0: Attached scsi generic sg6 type 0
[ 8.347774] sd 6:0:0:0: Attached scsi generic sg7 type 0
[ 8.348396] sd 6:0:0:0: [sdg] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 8.348424] sd 7:0:0:0: [sdf] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 8.349133] sd 7:0:0:0: [sdf] Write Protect is off
[ 8.349141] sd 7:0:0:0: [sdf] Mode Sense: 28 00 00 00
[ 8.349254] sd 6:0:0:0: [sdg] Write Protect is off
[ 8.349264] sd 6:0:0:0: [sdg] Mode Sense: 27 00 00 00
[ 8.349876] sd 7:0:0:0: [sdf] No Caching mode page found
[ 8.349902] sd 7:0:0:0: [sdf] Assuming drive cache: write through
[ 8.350129] sd 6:0:0:0: [sdg] No Caching mode page found
[ 8.350165] sd 6:0:0:0: [sdg] Assuming drive cache: write through
[ 8.359377] sd 7:0:0:0: [sdf] No Caching mode page found
[ 8.359399] sd 7:0:0:0: [sdf] Assuming drive cache: write through
[ 8.359504] sd 6:0:0:0: [sdg] No Caching mode page found
[ 8.359521] sd 6:0:0:0: [sdg] Assuming drive cache: write through
[ 8.391451] sdg: sdg1
[ 8.394372] sd 6:0:0:0: [sdg] No Caching mode page found
[ 8.394396] sd 6:0:0:0: [sdg] Assuming drive cache: write through
[ 8.394415] sd 6:0:0:0: [sdg] Attached SCSI disk
[ 8.426944] sdf: sdf1
[ 8.429627] sd 7:0:0:0: [sdf] No Caching mode page found
[ 8.429647] sd 7:0:0:0: [sdf] Assuming drive cache: write through
[ 8.429662] sd 7:0:0:0: [sdf] Attached SCSI disk
[ 9.092098] HDMI: detected monitor M237WDP at connection type HDMI
[ 9.092106] HDMI: available speakers: FL/FR LFE FC RL/RR RC FLC/FRC RLC/RRC FLW/FRW FLH/FRH TC FCH
[ 9.092114] HDMI: supports coding type AC-3: channels = 6, rates = 32000 44100 48000, max bitrate = 640000
[ 9.092122] HDMI: supports coding type LPCM: channels = 2, rates = 32000 44100 48000, bits = 16 20 24
[ 9.100096] HDMI hot plug event: Codec=1 Pin=5 Presence_Detect=1 ELD_Valid=1
[ 9.108034] HDMI status: Codec=1 Pin=5 Presence_Detect=1 ELD_Valid=1
[ 9.402075] kjournald starting. Commit interval 5 seconds
[ 9.402229] EXT3-fs (sdg1): warning: maximal mount count reached, running e2fsck is recommended
[ 9.403643] EXT3-fs (sdg1): using internal journal
[ 9.403651] EXT3-fs (sdg1): mounted filesystem with ordered data mode
[ 9.888140] HDMI: detected monitor M237WDP at connection type HDMI
[ 9.888149] HDMI: available speakers: FL/FR LFE FC RL/RR RC FLC/FRC RLC/RRC FLW/FRW FLH/FRH TC FCH
[ 9.888157] HDMI: supports coding type AC-3: channels = 6, rates = 32000 44100 48000, max bitrate = 640000
[ 9.888164] HDMI: supports coding type LPCM: channels = 2, rates = 32000 44100 48000, bits = 16 20 24
[ 13.953279] FAT-fs (sde1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 24.476531] FAT-fs (sdf1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 25.419830] Adding 4096536k swap on /dev/sdb1. Priority:-1 extents:1 across:4096536k
[ 25.445658] EXT4-fs (sdb2): re-mounted. Opts: (null)
[ 25.931691] EXT4-fs (sdb2): re-mounted. Opts: errors=remount-ro
[ 26.064641] loop: module loaded
[ 27.547812] EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null)
[ 27.665065] fuse init (API version 7.17)
[ 27.997073] EXT4-fs (sdc3): mounted filesystem with ordered data mode. Opts: (null)
[ 28.116026] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
[ 28.160926] EXT4-fs (sda3): warning: maximal mount count reached, running e2fsck is recommended
[ 28.178604] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 28.302353] kjournald starting. Commit interval 5 seconds
[ 28.302816] EXT3-fs (sdb4): using internal journal
[ 28.302823] EXT3-fs (sdb4): mounted filesystem with ordered data mode
[ 28.337594] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 29.414851] RPC: Registered named UNIX socket transport module.
[ 29.414856] RPC: Registered udp transport module.
[ 29.414859] RPC: Registered tcp transport module.
[ 29.414863] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 29.443649] FS-Cache: Loaded
[ 29.470848] FS-Cache: Netfs ‘nfs’ registered for caching
[ 29.489074] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 29.798349] r8169 0000:03:00.0: firmware: agent aborted loading rtl_nic/rtl8168f-1.fw (not found?)
[ 29.798500] r8169 0000:03:00.0: eth0: unable to load firmware patch rtl_nic/rtl8168f-1.fw (-2)
[ 29.809502] r8169 0000:03:00.0: eth0: link down
[ 29.809513] r8169 0000:03:00.0: eth0: link down
[ 29.809734] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 32.371648] r8169 0000:03:00.0: eth0: link up
[ 32.371847] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.817176] Bluetooth: Core ver 2.16
[ 33.817204] NET: Registered protocol family 31
[ 33.817210] Bluetooth: HCI device and connection manager initialized
[ 33.817216] Bluetooth: HCI socket layer initialized
[ 33.817221] Bluetooth: L2CAP socket layer initialized
[ 33.817231] Bluetooth: SCO socket layer initialized
[ 33.844048] Bluetooth: RFCOMM TTY layer initialized
[ 33.844058] Bluetooth: RFCOMM socket layer initialized
[ 33.844063] Bluetooth: RFCOMM ver 1.11
[ 34.400243] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 34.400249] Bluetooth: BNEP filters: protocol multicast
[ 34.444958] lp0: using parport0 (interrupt-driven).
[ 34.810477] ppdev: user-space parallel port driver
[ 42.824074] eth0: no IPv6 routers present
[ 376.053914] sound-juicer: sending ioctl 2285 to a partition!
[ 376.054014] sound-juicer: sending ioctl 2285 to a partition!
[ 376.054090] sound-juicer: sending ioctl 2285 to a partition!
[ 1003.198319] sound-juicer: sending ioctl 2285 to a partition!
[ 1003.198401] sound-juicer: sending ioctl 2285 to a partition!
Rapporter le message Accepter cette reponse
Haut [/quote]
dmesg, partie 2
[quote]0
[ 1.752607] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.752609] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.752612] usb usb1: Product: EHCI Host Controller
[ 1.752613] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.752615] usb usb1: SerialNumber: 0000:00:12.2
[ 1.752721] hub 1-0:1.0: USB hub found
[ 1.752726] hub 1-0:1.0: 6 ports detected
[ 1.752828] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 1.752837] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 3
[ 1.752845] ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.752866] ehci_hcd 0000:00:13.2: debug port 1
[ 1.752890] ehci_hcd 0000:00:13.2: irq 19, io mem 0xfcfff400
[ 1.760546] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.764053] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.764069] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.764072] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.764073] usb usb3: Product: EHCI Host Controller
[ 1.764075] usb usb3: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.764076] usb usb3: SerialNumber: 0000:00:13.2
[ 1.764153] hub 3-0:1.0: USB hub found
[ 1.764157] hub 3-0:1.0: 6 ports detected
[ 1.764250] pata_atiixp 0000:00:14.1: setting latency timer to 64
[ 1.764518] scsi0 : pata_atiixp
[ 1.765186] scsi1 : pata_atiixp
[ 1.766393] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 1.766397] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 1.766444] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 1.766455] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 4
[ 1.766479] ohci_hcd 0000:00:12.0: irq 16, io mem 0xfcffe000
[ 1.815577] xhci_hcd 0000:02:00.0: irq 44 for MSI/MSI-X
[ 1.815581] xhci_hcd 0000:02:00.0: irq 45 for MSI/MSI-X
[ 1.815585] xhci_hcd 0000:02:00.0: irq 46 for MSI/MSI-X
[ 1.815589] xhci_hcd 0000:02:00.0: irq 47 for MSI/MSI-X
[ 1.815592] xhci_hcd 0000:02:00.0: irq 48 for MSI/MSI-X
[ 1.815649] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.815651] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.815652] usb usb2: Product: xHCI Host Controller
[ 1.815653] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae xhci_hcd
[ 1.815655] usb usb2: SerialNumber: 0000:02:00.0
[ 1.815714] xHCI xhci_add_endpoint called for root hub
[ 1.815715] xHCI xhci_check_bandwidth called for root hub
[ 1.815735] hub 2-0:1.0: USB hub found
[ 1.815740] hub 2-0:1.0: 2 ports detected
[ 1.815782] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.815786] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 5
[ 1.815807] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.815809] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.815810] usb usb5: Product: xHCI Host Controller
[ 1.815812] usb usb5: Manufacturer: Linux 3.2.0-4-686-pae xhci_hcd
[ 1.815813] usb usb5: SerialNumber: 0000:02:00.0
[ 1.815866] xHCI xhci_add_endpoint called for root hub
[ 1.815867] xHCI xhci_check_bandwidth called for root hub
[ 1.815885] hub 5-0:1.0: USB hub found
[ 1.815889] hub 5-0:1.0: 2 ports detected
[ 1.824047] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.824050] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.824051] usb usb4: Product: OHCI Host Controller
[ 1.824053] usb usb4: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.824054] usb usb4: SerialNumber: 0000:00:12.0
[ 1.824139] hub 4-0:1.0: USB hub found
[ 1.824145] hub 4-0:1.0: 3 ports detected
[ 1.824200] ohci_hcd 0000:00:12.1: OHCI Host Controller
[ 1.824206] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 6
[ 1.824218] ohci_hcd 0000:00:12.1: irq 16, io mem 0xfcffd000
[ 1.884043] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.884046] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.884048] usb usb6: Product: OHCI Host Controller
[ 1.884049] usb usb6: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.884050] usb usb6: SerialNumber: 0000:00:12.1
[ 1.884141] hub 6-0:1.0: USB hub found
[ 1.884147] hub 6-0:1.0: 3 ports detected
[ 1.884215] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 1.884222] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 7
[ 1.884241] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfcffc000
[ 1.936448] ata2.00: ATA-8: SAMSUNG HD502HJ, 1AJ100E4, max UDMA/133
[ 1.936450] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.936456] ata2.01: ATAPI: TSSTcorp CDDVDW SH-S223F, SB00, max UDMA/100
[ 1.944021] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.944023] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.944025] usb usb7: Product: OHCI Host Controller
[ 1.944026] usb usb7: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 1.944027] usb usb7: SerialNumber: 0000:00:13.0
[ 1.944374] hub 7-0:1.0: USB hub found
[ 1.944381] hub 7-0:1.0: 3 ports detected
[ 1.944455] ata2.00: configured for UDMA/100
[ 1.944466] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 1.944472] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 8
[ 1.944483] ohci_hcd 0000:00:13.1: irq 18, io mem 0xfcffb000
[ 1.960342] ata2.01: configured for UDMA/100
[ 1.960681] scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD502HJ 1AJ1 PQ: 0 ANSI: 5
[ 1.961364] scsi 1:0:1:0: CD-ROM TSSTcorp CDDVDW SH-S223F SB00 PQ: 0 ANSI: 5
[ 2.004042] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.004045] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.004046] usb usb8: Product: OHCI Host Controller
[ 2.004048] usb usb8: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 2.004049] usb usb8: SerialNumber: 0000:00:13.1
[ 2.004137] hub 8-0:1.0: USB hub found
[ 2.004144] hub 8-0:1.0: 3 ports detected
[ 2.004200] ohci_hcd 0000:00:14.5: OHCI Host Controller
[ 2.004206] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 9
[ 2.004217] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfcffa000
[ 2.064025] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.064026] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.064028] usb usb9: Product: OHCI Host Controller
[ 2.064029] usb usb9: Manufacturer: Linux 3.2.0-4-686-pae ohci_hcd
[ 2.064030] usb usb9: SerialNumber: 0000:00:14.5
[ 2.064120] hub 9-0:1.0: USB hub found
[ 2.064125] hub 9-0:1.0: 2 ports detected
[ 2.064220] ahci 0000:00:11.0: version 3.0
[ 2.064326] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 2.064330] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 2.064730] scsi2 : ahci
[ 2.065029] scsi3 : ahci
[ 2.065156] scsi4 : ahci
[ 2.065256] scsi5 : ahci
[ 2.065377] ata3: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffd00 irq 22
[ 2.065381] ata4: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffd80 irq 22
[ 2.065384] ata5: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffe00 irq 22
[ 2.065387] ata6: SATA max UDMA/133 abar m1024@0xfcfffc00 port 0xfcfffe80 irq 22
[ 2.184023] usb 1-2: new high-speed USB device number 3 using ehci_hcd
[ 2.264022] Refined TSC clocksource calibration: 3817.137 MHz.
[ 2.264025] Switching to clocksource tsc
[ 2.384039] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.556020] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.556041] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.556060] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.556661] ata3.00: ATA-8: SAMSUNG HD161HJ, GF100-07, max UDMA7
[ 2.556664] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.557135] ata5.00: ATA-8: ST3500418AS, CC46, max UDMA/133
[ 2.557137] ata5.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.557303] ata3.00: configured for UDMA/133
[ 2.557387] scsi 2:0:0:0: Direct-Access ATA SAMSUNG HD161HJ GF10 PQ: 0 ANSI: 5
[ 2.558423] ata5.00: configured for UDMA/133
[ 2.558486] scsi 4:0:0:0: Direct-Access ATA ST3500418AS CC46 PQ: 0 ANSI: 5
[ 2.574429] ata6.00: ATA-7: WDC WD3200AAKS-22SBA0, 12.01B01, max UDMA/133
[ 2.574431] ata6.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.575169] ata6.00: configured for UDMA/133
[ 2.575232] scsi 5:0:0:0: Direct-Access ATA WDC WD3200AAKS-2 12.0 PQ: 0 ANSI: 5
[ 2.579804] sd 1:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.583057] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.583059] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.583097] sd 1:0:0:0: [sda] Write Protect is off
[ 2.583100] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.583116] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.583160] sr 1:0:1:0: Attached scsi CD-ROM sr0
[ 2.583420] sd 2:0:0:0: [sdb] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 2.583454] sd 4:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.583465] sd 2:0:0:0: [sdb] Write Protect is off
[ 2.583467] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.583483] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.583489] sd 4:0:0:0: [sdc] Write Protect is off
[ 2.583491] sd 4:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.583498] sd 5:0:0:0: [sdd] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 2.583507] sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.583539] sd 5:0:0:0: [sdd] Write Protect is off
[ 2.583542] sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 2.583559] sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.591501] sda: sda1 sda2 sda3
[ 2.591728] sd 1:0:0:0: [sda] Attached SCSI disk
[ 2.597199] sdb: sdb1 sdb2 sdb3 sdb4
[ 2.597523] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 2.597563] sr 1:0:1:0: Attached scsi generic sg1 type 5
[ 2.597584] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.597600] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 2.597632] sd 4:0:0:0: Attached scsi generic sg3 type 0
[ 2.597664] sd 5:0:0:0: Attached scsi generic sg4 type 0
[ 2.604240] sdd: sdd1 sdd2 < sdd5 >
[ 2.604297] sdc: sdc1 sdc2 sdc3
[ 2.604496] sd 5:0:0:0: [sdd] Attached SCSI disk
[ 2.604603] sd 4:0:0:0: [sdc] Attached SCSI disk
[ 3.444415] PM: Starting manual resume from disk
[ 3.444417] PM: Hibernation image partition 8:17 present
[ 3.444418] PM: Looking for hibernation image.
[ 3.444610] PM: Image not found (code -22)
Haut [/quote]
La sortie n’est pas complète.
Astuce: tu peux enregistrer dans un fichier texte la sortie d’une commande comme suit:
Te restera à joindre le fichier sur ce forum.
Je n’ai pas bien examiné, ton scanner est branché comment ? USB ?
Je vois ton imprimante et des disques durs mais pas repéré de scanner.
Je ne sais pas si J’ai bien compris:
konsole dmesg.txt (67.7 KB)
$ ls -l /dev/sg*
crw-rw----+ 1 root root 21, 2 2014-03-24 10:26 /dev/sg2
On voit clairement chez moi que root est le seul habilité à utiliser mon scanner ! C’est vrai qu’il date d’un peu avant Mathusalem :laughing:
Cool, t’as plein d’erreurs.
[ 714.604108] hub 2-0:1.0: unable to enumerate USB device on port 1 [ 715.008121] hub 2-0:1.0: unable to enumerate USB device on port 1 [ 715.416121] hub 2-0:1.0: unable to enumerate USB device on port 1 [ 715.824108] hub 2-0:1.0: unable to enumerate USB device on port 1 [ 716.240110] hub 2-0:1.0: unable to enumerate USB device on port 1
Mais je récapitule la manip’ que je t’avais indiquée:
  1. Tu ouvres Konsole
  2. Dedans tu tapes: [mono]dmesg > ~/dmesg_nereu.txt[/mono]
  3. Tu vas sur ce forum, et au moment de poster ton message, tu ajoutes une pièce jointe, et tu ajoutes ce fichier dmesg_nereu.txt
ls -l /dev/sg*
crw------- 1 root root 21, 0 mars 26 08:31 /dev/sg0
crw------- 1 root root 21, 1 mars 26 08:31 /dev/sg1
crw------- 1 root root 21, 2 mars 26 08:31 /dev/sg2
crw------- 1 root root 21, 3 mars 26 08:31 /dev/sg3
crw-rw—T+ 1 root cdrom 21, 4 mars 26 08:31 /dev/sg4
crw------- 1 root root 21, 5 mars 26 08:31 /dev/sg5
crw------- 1 root root 21, 6 mars 26 08:50 /dev/sg6
Comment savoir où est le scanner?
dmesg > ~/dmesg_nereu.txt n’a pas d’issue.
[quote=“nereu”]ls -l /dev/sg*
Merci[/quote]
En le branchant/débranchant :slightly_smiling:
Mais pour un essai tu fais en root :
# chmod 666 /dev/sg* et tu vois si ton user accède au scanner :slightly_smiling:
Et pourtant, si tu la tapes texto dans un terminal, ça devrait marcher, et te créer ce fichier (sans broncher, la commande n’est pas bavarde => signe de succès), donc vérifie dans ton répertoire /home/ton_utilisateur/ que tu l’as.
[i]Mais pour un essai tu fais en root :
Code:
chmod 666 /dev/sg*
[/i]
Je l’ai fait et il n’y a aucun changement.
Je l’ai, il me semble (?)
Je l’envoie en annexe.dmesg_nereu.txt (90.3 KB)
[ 4.520026] usb 1-5: new high-speed USB device number 4 using ehci_hcd [ 4.664274] usb 1-5: New USB device found, idVendor=04b8, idProduct=011f [ 4.664277] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.664279] usb 1-5: Product: EPSON Scanner [ 4.664280] usb 1-5: Manufacturer: EPSON [ 4.839163] udevd[408]: starting version 175
Rien d’anormal dans ton dmesg au sujet du scanner. Celui-ci ne bronche pas.
Par contre tu as toujours les erreurs rappellées plus haut, “failed to enumerate blablabla”. Je ne suis pas certain que ce soit elles qui posent problème.
Tu peux rappeller ton modèle de scanner: (quand il est branché)
… puis se renseigner sur la manière de l’installer et se faire une idée du type de déboires.
Mon scanner est un Epson Perfection 1670
[quote]~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 0bc2:0503 Seagate RSS LLC
Bus 001 Device 004: ID 04b8:011f Seiko Epson Corp. Perfection 1670
Bus 006 Device 002: ID 04f3:0234 Elan Microelectronics Corp.
Bus 004 Device 002: ID 03f0:0904 Hewlett-Packard DeskJet 845c
Bus 005 Device 002: ID 0480:a006 Toshiba America Info. Systems, Inc.
Il y avait, jusqu’a Hardy d’Ubuntu un script qui faisait fonctionner ce scanner et que j’envoie comme annexe.
Mais on pouvait aussi faire ces modifications manuellement. Ici, c’est fait. Mais, tel que comme les versions d’Ubuntu après Hardy, ce script -là a cessé de fonctionner.
[quote]#!/bin/bash
#driver epson perfection 1670 photo
zenity --question
–title=“EPSON Perfection 1670 photo”
–text=“Bienvenue dans l’installation scanner EPSON Perfection 1670 photo
Ce programme a été concu pour faciliter l’installation du driver du scanner epson perfection 1670 photo
Installer le driver?”
if [ “$?” = “0” ]; then
#localisation…
echo “10”; sleep 1
echo “# localisation…”; sleep 1
fichier=pwd
#OK
echo “OK”
#création du dossier snapscan…
echo “30”; sleep 1
echo “# création du dossier snapscan…”; sleep 1
gksu mkdir /usr/share/sane/snapscan
#OK
echo “OK”
#copie du driver…
echo “50”; sleep 1
echo “# copie du driver…”; sleep 1
gksu cp $fichier/.driver/ESFW30.BIN /usr/share/sane/snapscan/esfw30.bin
#OK
echo “OK”
#modification du fichier snapcan.conf
echo “75”; sleep 1
echo “# modification du fichier snapcan.conf”; sleep 1
gksu cp $fichier/.driver/snapscan.conf /etc/sane.d/snapscan.conf
#OK
echo “100”; sleep 1
echo “# fin”; sleep 1
zenity --progress
–title=“Installation epson driver”
–text=“Installation…”
–percentage=0
zenity --info
–title=“fin de l’installation”
–text="l’installation est terminée. Vous pouvez maintenant utiliser votre scanner EPSON Perfection 1670 photo. "
exit
else [ “$?” = “1” ] || [ “$?” = “-1” ]
zenity --info
–text="l’installation a été interrompue"
exit
fi
Bien que certains soient méfiants, j’irais voir sue le site du fabricant s’il ne propose pas une solution. AMHA ce n’est pas plus risqué que de suivre les conseils de Ubuntu :slightly_smiling:
Le script Ubuntu fait qqch d’assez simple.
  • Copie du firmware
  • Modification d’un fichier de conf pour qu’il charge ce firmware
Procédure également appliquée sous Debian selon ce topic:
forums.debian.net/viewtopic.php?f=7&t=108688
Récapitulatif,
  • Chopper le bon driver sous forme de .exe sur le site d’Epson
  • Décompresser ce .exe, pour en récupérer le fichier esfw30.bin
  • Copier ce fichier dans [mono]/etc/sane.d[/mono]
  • Editer [mono]/etc/sane.d/snapscan.conf[/mono] et y ajouter une ligne:
  • Voila.
