j’ai installé NTFS-3G
Voici la réponse que j’obtiends quand le saisi dans un terminal :
debian:/home/jacques# mount /media/minimir-1_xp
WARNING: Deficient Linux kernel detected. Some driver features are
not available (swap file on NTFS, boot from NTFS by LILO), and
unmount is not safe unless it’s made sure the ntfs-3g process
naturally terminates after calling ‘umount’. If you wish this
message to disappear then you should upgrade to at least kernel
version 2.6.20, or request help from your distribution to fix
the kernel problem. The below web page has more information:
ntfs-3g.org/support.html#fuse26
Mon fichier fstab :
/etc/fstab: static file system information.
proc /proc proc defaults 0 0
/dev/hda5 / ext3 defaults,errors=remount-ro 0 1
/dev/hda7 /home ext3 defaults 0 2
/dev/hda6 none swap sw 0 0
/dev/hdc /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/scd0 /media/cdrom1 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
/dev/sde1 /media/usb0 auto rw,user,noauto 0 0
#partitions windows ntfs
/dev/hda1 /media/minimir-1_xp ntfs-3g rw,user,gid=100,iocharset=iso8859-15,umask=002 0 0
/dev/hdb1 /media/minimir-2_xp ntfs-3g rw,user,gid=100,iocharset=iso8859-15,umqsk=002 0 0
/dev/hdd1 /media/minimir-3_xp ntfs-3g rw,user,gid=100,iocharset=iso8859-15,umask=002 0 0
Comment résoudre mon problème,
