[quote=“marcastro”]ntfs-3g est il installé sur ton système?pour le savoir:
et profite du voyage pour donner ton fstab[/quote]
$ apt-cache policy ntfs-3g
ntfs-3g:
Installed: 1:2012.1.15AR.5-2.1
Candidate: 1:2012.1.15AR.5-2.1
Version table:
*** 1:2012.1.15AR.5-2.1 0
500 ftp.fr.debian.org/debian/ wheezy/main amd64 Packages
100 /var/lib/dpkg/status
fstab
[color=#400080]# /etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda2 during installation
UUID=8f9241fe-1cce-4ee4-a340-2b4311085bfc / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
UUID=DFE0-8A41 /boot/efi vfat defaults 0 1
/home was on /dev/sda4 during installation
UUID=a4d65885-160a-4a4b-977d-86f3a309d123 /home ext4 defaults 0 2
swap was on /dev/sda3 during installation
UUID=e0199dd8-2c7b-4312-87f0-658ea82611f8 none swap sw 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/sdb1 /media/usb0 auto rw,user,noauto 0 0
/dev/sdb2 /media/usb1 auto rw,user,noauto 0 0
/dev/sdb5 /media/usb2 auto rw,user,noauto 0 0
/dev/sdc1 /media/usb3 auto rw,user,noauto 0 0[/color]
Comment ceci pourra-t-il servir?
Merci de tes efforts et de tes prochaines propositions.
Salutations,
