pour tous
root@home:~# gdisk -l /dev/sda
GPT fdisk (gdisk) version 0.8.5
Partition table scan:
MBR: not present
BSD: not present
APM: not present
GPT: not present
Creating new GPT entries.
Disk /dev/sda: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): C0D35898-E943-49AF-97CF-069495EBE440
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 2048-sector boundaries
Total free space is 3907029101 sectors (1.8 TiB)
Number Start (sector) End (sector) Size Code Name
root@home:~#
root@home:~#
root@home:~# gdisk -l /dev/sdb
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format.
Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 908DB55A-2D13-40C7-B40C-BD5A494B30FE
root@home:~#
root@home:~#
root@home:~# gdisk -l /dev/sdc
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Disk /dev/sdc: 78165360 sectors, 37.3 GiB
Disk identifier (GUID): 42E09DC2-847B-4212-B78E-34FAD0F9A663
First usable sector is 34, last usable sector is 78165326
Total free space is 5421 sectors (2.6 MiB)
1 2048 74897407 35.7 GiB 8300 Linux filesystem
5 74899456 78163967 1.6 GiB 8200 Linux swap
root@home:~#
root@home:~#
root@home:~# gdisk -l /dev/sdd
Caution: invalid main GPT header, but valid backup; regenerating main header
from backup!
Caution! After loading partitions, the CRC doesn’t check out!
Warning! Main partition table CRC mismatch! Loaded backup partition table
instead of main partition table!
Warning! One or more CRCs don’t match. You should repair the disk!
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Disk /dev/sdd: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): DBA23E3E-60F4-4281-B949-3EB725E912BA
Total free space is 2014 sectors (1007.0 KiB)
1 2048 3907029134 1.8 TiB 8300
root@home:~#
root@home:~#
root@home:~# gdisk -l /dev/sde
MBR: not present
BSD: not present
APM: not present
GPT: not present
Disk /dev/sde: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): FA1C945F-50A8-4EFE-A56F-70B75B54902E
root@home:~#
