Montage usb Sansa View video mp3 player ?
hello
je ne sais pas comment monter le lecteur mp3, :question: don le modèle est le suivant :
Sansa View video mp3 player 16GB
M$ le détecte comme une clef usb
voici un lsusb version courte
lsusb
Bus 002 Device 002: ID 0665:5161
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 008: ID 0781:74b0 SanDisk Corp.
Bus 001 Device 004: ID 046d:c051 Logitech, Inc. G3 (MX518) Optical Mouse
Bus 001 Device 002: ID 05e3:0605 Genesys Logic, Inc. USB 2.0 Hub [ednet]
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
un lsusb -vvv en root
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0781 SanDisk Corp.
  idProduct          0x74b0
  bcdDevice            7.20
  iManufacturer           1 SanDisk
  iProduct                2 Sansa View
  iSerial                 3 035344534431364780a00351b800823f00000000
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    bConfigurationValue   128
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk (Zip)
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval              16
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass       255 Vendor Specific Subclass
  bDeviceProtocol       255 Vendor Specific Protocol
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
merci d’avance
Bon apparemment sa bug aux niveau du kernel, on dirait qu’il le trouve puis qu’il ce deconnect:
un dmseg
149.389723] usb 2-1.1: new high speed USB device using ehci_hcd and address 5
[  149.560916] usb 2-1.1: configuration #128 chosen from 1 choice
[  149.575342] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  149.575342] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  149.575342] usb 2-1.1: Product: Sansa View
[  149.575342] usb 2-1.1: Manufacturer: SanDisk
[  149.575342] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  149.627502] Initializing USB Mass Storage driver...
[  149.627502] scsi6 : SCSI emulation for USB Mass Storage devices
[  149.627502] usbcore: registered new interface driver usb-storage
[  149.627502] USB Mass Storage support registered.
[  149.628010] usb-storage: device found at 5
[  149.628013] usb-storage: waiting for device to settle before scanning
[  154.934256] usb-storage: device scan complete
[  160.944384] usb 2-1.1: reset high speed USB device using ehci_hcd and address 5
[  171.824539] usb 2-1.1: reset high speed USB device using ehci_hcd and address 5
[  171.954882] scsi 6:0:0:0: Device offlined - not ready after error recovery
[  171.954882] usb 2-1.1: USB disconnect, address 5
[  183.109375] usb 2-1.1: new high speed USB device using ehci_hcd and address 6
[  183.220083] usb 2-1.1: configuration #128 chosen from 1 choice
[  183.229612] scsi7 : SCSI emulation for USB Mass Storage devices
[  183.233597] usb-storage: device found at 6
[  183.233597] usb-storage: waiting for device to settle before scanning
[  183.229612] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  183.229612] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  183.229612] usb 2-1.1: Product: Sansa View
[  183.229612] usb 2-1.1: Manufacturer: SanDisk
[  183.229612] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  188.705411] usb-storage: device scan complete
[  194.520628] usb 2-1.1: reset high speed USB device using ehci_hcd and address 6
[  205.049080] usb 2-1.1: reset high speed USB device using ehci_hcd and address 6
[  205.174754] scsi 7:0:0:0: Device offlined - not ready after error recovery
[  205.176350] usb 2-1.1: USB disconnect, address 6
[  217.438131] usb 2-1.1: new high speed USB device using ehci_hcd and address 7
[  217.534319] usb 2-1.1: configuration #128 chosen from 1 choice
[  217.547512] scsi8 : SCSI emulation for USB Mass Storage devices
[  217.551512] usb-storage: device found at 7
[  217.551512] usb-storage: waiting for device to settle before scanning
[  217.547512] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  217.547512] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  217.547512] usb 2-1.1: Product: Sansa View
[  217.547512] usb 2-1.1: Manufacturer: SanDisk
[  217.547512] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  222.662535] usb-storage: device scan complete
[  228.468535] usb 2-1.1: reset high speed USB device using ehci_hcd and address 7
[  239.091365] usb 2-1.1: reset high speed USB device using ehci_hcd and address 7
[  239.205705] scsi 8:0:0:0: Device offlined - not ready after error recovery
[  239.206578] usb 2-1.1: USB disconnect, address 7
[  250.877864] usb 2-1.1: new high speed USB device using ehci_hcd and address 8
[  250.972903] usb 2-1.1: configuration #128 chosen from 1 choice
[  250.981607] scsi9 : SCSI emulation for USB Mass Storage devices
[  250.985606] usb-storage: device found at 8
[  250.985606] usb-storage: waiting for device to settle before scanning
[  250.981607] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  250.981607] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  250.981607] usb 2-1.1: Product: Sansa View
[  250.981607] usb 2-1.1: Manufacturer: SanDisk
[  250.981607] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  256.263288] usb-storage: device scan complete
[  262.152597] usb 2-1.1: reset high speed USB device using ehci_hcd and address 8
[  272.897962] usb 2-1.1: reset high speed USB device using ehci_hcd and address 8
[  273.022861] scsi 9:0:0:0: Device offlined - not ready after error recovery
[  273.025768] usb 2-1.1: USB disconnect, address 8
[  285.698204] usb 2-1.1: new high speed USB device using ehci_hcd and address 9
[  285.793894] usb 2-1.1: configuration #128 chosen from 1 choice
[  285.801894] scsi10 : SCSI emulation for USB Mass Storage devices
[  285.805421] usb-storage: device found at 9
[  285.805421] usb-storage: waiting for device to settle before scanning
[  285.801894] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  285.801894] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  285.801894] usb 2-1.1: Product: Sansa View
[  285.801894] usb 2-1.1: Manufacturer: SanDisk
[  285.801894] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  291.121874] usb-storage: device scan complete
[  296.981241] usb 2-1.1: reset high speed USB device using ehci_hcd and address 9
[  307.557693] usb 2-1.1: reset high speed USB device using ehci_hcd and address 9
[  307.678800] scsi 10:0:0:0: Device offlined - not ready after error recovery
[  307.681530] usb 2-1.1: USB disconnect, address 9
[  317.721931] usb 2-1.1: new high speed USB device using ehci_hcd and address 10
[  317.814432] usb 2-1.1: configuration #128 chosen from 1 choice
[  317.824157] scsi11 : SCSI emulation for USB Mass Storage devices
[  317.828157] usb-storage: device found at 10
[  317.828157] usb-storage: waiting for device to settle before scanning
[  317.824157] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  317.824157] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  317.824157] usb 2-1.1: Product: Sansa View
[  317.824157] usb 2-1.1: Manufacturer: SanDisk
[  317.824157] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  322.905700] usb-storage: device scan complete
[  328.766298] usb 2-1.1: reset high speed USB device using ehci_hcd and address 10
[  339.255491] usb 2-1.1: reset high speed USB device using ehci_hcd and address 10
[  339.370820] scsi 11:0:0:0: Device offlined - not ready after error recovery
[  339.371693] usb 2-1.1: USB disconnect, address 10
[  351.264936] usb 2-1.1: new high speed USB device using ehci_hcd and address 11
[  351.360353] usb 2-1.1: configuration #128 chosen from 1 choice
[  351.369857] scsi12 : SCSI emulation for USB Mass Storage devices
[  351.373856] usb-storage: device found at 11
[  351.373856] usb-storage: waiting for device to settle before scanning
[  351.369857] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  351.369857] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  351.369857] usb 2-1.1: Product: Sansa View
[  351.369857] usb 2-1.1: Manufacturer: SanDisk
[  351.369857] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  356.723032] usb-storage: device scan complete
[  362.805807] usb 2-1.1: reset high speed USB device using ehci_hcd and address 11
[  373.629503] usb 2-1.1: reset high speed USB device using ehci_hcd and address 11
[  373.743950] scsi 12:0:0:0: Device offlined - not ready after error recovery
[  373.745213] usb 2-1.1: USB disconnect, address 11
[  383.914154] usb 2-1.1: new high speed USB device using ehci_hcd and address 12
[  384.008949] usb 2-1.1: configuration #128 chosen from 1 choice
[  384.017872] scsi13 : SCSI emulation for USB Mass Storage devices
[  384.021866] usb-storage: device found at 12
[  384.021866] usb-storage: waiting for device to settle before scanning
[  384.017872] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  384.017872] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  384.017872] usb 2-1.1: Product: Sansa View
[  384.017872] usb 2-1.1: Manufacturer: SanDisk
[  384.017872] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  389.312356] usb-storage: device scan complete
[  395.318730] usb 2-1.1: reset high speed USB device using ehci_hcd and address 12
[  406.144280] usb 2-1.1: reset high speed USB device using ehci_hcd and address 12
[  406.277343] scsi 13:0:0:0: Device offlined - not ready after error recovery
[  406.279474] usb 2-1.1: USB disconnect, address 12
[  418.571678] usb 2-1.1: new high speed USB device using ehci_hcd and address 13
[  418.680916] usb 2-1.1: configuration #128 chosen from 1 choice
[  418.689424] scsi14 : SCSI emulation for USB Mass Storage devices
[  418.689657] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  418.689657] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  418.689657] usb 2-1.1: Product: Sansa View
[  418.689657] usb 2-1.1: Manufacturer: SanDisk
[  418.689657] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  418.689657] usb-storage: device found at 13
[  418.689657] usb-storage: waiting for device to settle before scanning
[  424.300286] usb-storage: device scan complete
[  430.432244] usb 2-1.1: reset high speed USB device using ehci_hcd and address 13
[  441.908113] usb 2-1.1: reset high speed USB device using ehci_hcd and address 13
[  442.027891] scsi 14:0:0:0: Device offlined - not ready after error recovery
[  442.027891] usb 2-1.1: USB disconnect, address 13
[  452.993681] usb 2-1.1: new high speed USB device using ehci_hcd and address 14
[  453.101343] usb 2-1.1: configuration #128 chosen from 1 choice
[  453.109890] scsi15 : SCSI emulation for USB Mass Storage devices
[  453.113593] usb-storage: device found at 14
[  453.113593] usb-storage: waiting for device to settle before scanning
[  453.109890] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  453.109890] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  453.109890] usb 2-1.1: Product: Sansa View
[  453.109890] usb 2-1.1: Manufacturer: SanDisk
[  453.109890] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  458.735922] usb-storage: device scan complete
[  464.569431] usb 2-1.1: reset high speed USB device using ehci_hcd and address 14
[  475.305244] usb 2-1.1: reset high speed USB device using ehci_hcd and address 14
[  475.422635] scsi 15:0:0:0: Device offlined - not ready after error recovery
[  475.424989] usb 2-1.1: USB disconnect, address 14
[  486.005451] usb 2-1.1: new high speed USB device using ehci_hcd and address 15
[  486.101208] usb 2-1.1: configuration #128 chosen from 1 choice
[  486.109937] scsi16 : SCSI emulation for USB Mass Storage devices
[  486.113936] usb-storage: device found at 15
[  486.113936] usb-storage: waiting for device to settle before scanning
[  486.109937] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  486.109937] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  486.109937] usb 2-1.1: Product: Sansa View
[  486.109937] usb 2-1.1: Manufacturer: SanDisk
[  486.109937] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  491.219034] usb-storage: device scan complete
[  497.050142] usb 2-1.1: reset high speed USB device using ehci_hcd and address 15
[  507.602120] usb 2-1.1: reset high speed USB device using ehci_hcd and address 15
[  507.715376] scsi 16:0:0:0: Device offlined - not ready after error recovery
[  507.716637] usb 2-1.1: USB disconnect, address 15
[  518.824699] usb 2-1.1: new high speed USB device using ehci_hcd and address 16
[  518.916700] usb 2-1.1: configuration #128 chosen from 1 choice
[  518.925522] scsi17 : SCSI emulation for USB Mass Storage devices
[  518.929522] usb-storage: device found at 16
[  518.929522] usb-storage: waiting for device to settle before scanning
[  518.925522] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  518.925522] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  518.925522] usb 2-1.1: Product: Sansa View
[  518.925522] usb 2-1.1: Manufacturer: SanDisk
[  518.925522] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  525.035086] usb-storage: device scan complete
[  531.158977] usb 2-1.1: reset high speed USB device using ehci_hcd and address 16
[  542.007610] usb 2-1.1: reset high speed USB device using ehci_hcd and address 16
[  542.119834] scsi 17:0:0:0: Device offlined - not ready after error recovery
[  542.119834] usb 2-1.1: USB disconnect, address 16
[  553.131132] usb 2-1.1: new high speed USB device using ehci_hcd and address 17
[  553.225799] usb 2-1.1: configuration #128 chosen from 1 choice
[  553.234883] scsi18 : SCSI emulation for USB Mass Storage devices
[  553.238883] usb-storage: device found at 17
[  553.238883] usb-storage: waiting for device to settle before scanning
[  553.234883] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  553.234883] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  553.234883] usb 2-1.1: Product: Sansa View
[  553.234883] usb 2-1.1: Manufacturer: SanDisk
[  553.234883] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  558.775458] usb-storage: device scan complete
[  565.131975] usb 2-1.1: reset high speed USB device using ehci_hcd and address 17
[  576.305933] usb 2-1.1: reset high speed USB device using ehci_hcd and address 17
[  576.421774] scsi 18:0:0:0: Device offlined - not ready after error recovery
[  576.421774] usb 2-1.1: USB disconnect, address 17
[  587.807633] usb 2-1.1: new high speed USB device using ehci_hcd and address 18
[  587.902549] usb 2-1.1: configuration #128 chosen from 1 choice
[  587.911318] scsi19 : SCSI emulation for USB Mass Storage devices
[  587.915317] usb-storage: device found at 18
[  587.915317] usb-storage: waiting for device to settle before scanning
[  587.911318] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  587.911318] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  587.911318] usb 2-1.1: Product: Sansa View
[  587.911318] usb 2-1.1: Manufacturer: SanDisk
[  587.911318] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  593.217053] usb-storage: device scan complete
[  599.348966] usb 2-1.1: reset high speed USB device using ehci_hcd and address 18
[  612.071845] usb 2-1.1: reset high speed USB device using ehci_hcd and address 18
[  612.199900] scsi 19:0:0:0: Device offlined - not ready after error recovery
[  612.202875] usb 2-1.1: USB disconnect, address 18
[  624.441294] usb 2-1.1: new high speed USB device using ehci_hcd and address 19
[  624.550896] usb 2-1.1: configuration #128 chosen from 1 choice
[  624.558748] scsi20 : SCSI emulation for USB Mass Storage devices
[  624.562405] usb 2-1.1: New USB device found, idVendor=0781, idProduct=74b0
[  624.562405] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  624.562405] usb 2-1.1: Product: Sansa View
[  624.562405] usb 2-1.1: Manufacturer: SanDisk
[  624.562405] usb 2-1.1: SerialNumber: 035344534431364780a00351b800823f00000000
[  624.562405] usb-storage: device found at 19
[  624.562405] usb-storage: waiting for device to settle before scanning
[  630.660739] usb-storage: device scan complete
[  637.342263] usb 2-1.1: reset high speed USB device using ehci_hcd and address 19
uname -a
Linux pcfix 2.6.26-1-686-bigmem #1 SMP Mon Dec 15 18:58:47 UTC 2008 i686 GNU/Linux
:smt089
