Bjrs a tous,
Je possède deux clef usb, l’une fonctionne correctement et l’autre (la dane elec) refuse de se monter. Le dmsg me donne ceci :
scsi3 : SCSI emulation for USB Mass Storage devices
Vendor: Model: USB Flash Memory Rev: 1.04
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sda: 1001472 512-byte hdwr sectors (513 MB)
sda: assuming Write Enabled
sda: assuming drive cache: write through
/dev/scsi/host3/bus0/target0/lun0: [CUMANA/ADFS] p1<5>Attached scsi removable d isk sda at scsi3, channel 0, id 0, lun 0
USB Mass Storage device found at 6
Buffer I/O error on device sda1, logical block 508378384
Buffer I/O error on device sda1, logical block 508378385
Buffer I/O error on device sda1, logical block 508378386
Buffer I/O error on device sda1, logical block 508378387
Buffer I/O error on device sda1, logical block 508378388
Buffer I/O error on device sda1, logical block 508378389
Buffer I/O error on device sda1, logical block 508378390
Buffer I/O error on device sda1, logical block 508378391
Buffer I/O error on device sda1, logical block 508378392
Buffer I/O error on device sda1, logical block 508378393
Buffer I/O error on device sda1, logical block 508378394
Buffer I/O error on device sda1, logical block 508378395
Buffer I/O error on device sda1, logical block 508378396
Buffer I/O error on device sda1, logical block 508378397
Buffer I/O error on device sda1, logical block 508378398
Buffer I/O error on device sda1, logical block 508378399
usb 1-1: USB disconnect, address 6
J’ai essayé de faire un fdisk dessus (fdisk /dev/sda1) j’ai effacer la partition pour en recréer une et rien n’y fait!
Avez vous déjà eu ce genre de pb? avez vous des pistes de recherche?
Merci a vous
Titi59
